[SOLVED] analogWrite not working on DAC Pins on NUCLEO G071RB
phil_o_matic
Post by phil_o_matic »
I’m running into issues with the DACs on my NUCLEO-G071RB.
According to the STM32Duino API documentation https://github.com/stm32duino/wiki/wiki ... nalogWrite command on Pins PA4 and PA5 (DAC outputs) should result in an analog voltage at the pin driven by the internal DAC.
I tried the Arduino fade example replacing the D13 pin declaration with either PA4 or PA5 but only get a constant 0V at the Pins (LED jumper desoldered).
One possibility would be a missing HAL_DAC_MODULE_ENABLED definition for the STM32G071RB. Is this possible and how do I check this?
Thanks!
Phil
tested code:
//original source:  http://www.arduino.cc/en/Tutorial/Fade
int OutPin = PA5;
int brightness = 0;
int fadeAmount = 5;
  analogWriteResolution(12);
  pinMode(OutPin, OUTPUT);
  analogWrite(OutPin, brightness);
  brightness = brightness + fadeAmount;
  if (brightness <= 0 || brightness >= 4095) {
    fadeAmount = -fadeAmount;
  delay(1);
tested with and without analogWriteResolution
phil_o_matic
Re: analogWrite not working on DAC Pins on NUCLEO G071RB
Thanks for that hint. I created an buildopt.h and added the -DHAL_DAC_MODULE_ENABLED line.
Sadly I don't get any output from the DAC
phil_o_matic
Re: [SOLVED] analogWrite not working on DAC Pins on NUCLEO G071RB
Update:
I tried running the DAC with the STM32CubeIDE. The DAC_DataOut Registers had the correct value without any voltage at the output.
Got really frustradet. Had a break and an idea.
The Nucleo I used was used by a colleage before who desoldered the juper for the reference voltage and Vref was therefore at 0V... I thought it was a brand new board and therefore didn't even think about that.
On the other hand it works just fine by now. Thanks for your help!
