MCP CAN and MPU650 bite each other
thala
Post by thala »
Hi , im currently building a connection from stm32f4 via canbus to arduino mega. Actually it works well, i had made two different programms and programmed Can message Sending and MPU Data logging.But if i want to use them both in the same script, the MPU throws zeros insteadt of normal values. If i commentate the MCP code out, it works again. Did someone having same isues and give me a idea where to search?.
#include <Arduino.h>
#include <TinyMPU6050.h>
#include <can.h>
#include <mcp2515.h>
#include <SPI.h>
MPU6050 mpu(Wire);
struct can_frame canMsg1;
struct can_frame canMsg2;
MCP2515 mcp2515(PC1);                                  // Set CS to pin 10
int rpm = 2;
{SPI.setMOSI(PA7);
SPI.setMISO(PA6);
SPI.setSCLK(PA5);
SPI.begin();
  mcp2515.reset();
  mcp2515.setBitrate(CAN_500KBPS,MCP_8MHZ);
  mcp2515.setNormalMode();
  mpu.Initialize();
  // Calibration
  Serial.println("=====================================");
  Serial.println("Starting calibration...");
  mpu.Calibrate();
  Serial.println("Calibration complete!");
  mpu.Execute();
  delay(100);
int a = ((int)((mpu.GetAccX())));
int b = (int)((mpu.GetAccY()));
int c = (int)((mpu.GetAccZ()));
int d = (int)((mpu.GetGyroX()));
int e = (int)((mpu.GetGyroY()));
int f =  (int)((mpu.GetGyroZ()));
delay(100);
Serial.println(a);
Serial.println(b);
Serial.println(c);
Serial.println(d);
Serial.println(e);
Serial.println(f);
  canMsg1.can_id  = 0x0F6;
  canMsg1.can_dlc = 8;
  canMsg1.data[0] = a;
  canMsg1.data[1] = b;
  canMsg1.data[2] = c;
  canMsg1.data[3] = d;
  canMsg1.data[4] = e;
  canMsg1.data[5] = f;
  canMsg1.data[6] = 0xBE;
  canMsg1.data[7] = 0x86;
  canMsg2.can_id  = 0x036;
  canMsg2.can_dlc = 8;
  canMsg2.data[2] = a;
  canMsg2.data[6] = 0x00;
  canMsg2.data[7] = 0xA0;
    mcp2515.sendMessage(&canMsg1);
  delay(1000);                       // send dat  int b = (int)a;
if i commentate this out it works:
Sry for my bad english, didnt wrote for a whole lot of time in english.
Would be verry thanksfull if someone has an idea
Re: MCP CAN and MPU650 bite each other
hard to tell.
Which STMF4 exactly you used ?
Maybe a conflict with both library? Pins conflict? Interrupt ?
The program run but you get only 0 ?
thala
Post by thala »
Yes. If i watch it on serial interface and outcommentate the mcp line everything is fine. If i commentate it in, there are only series for the accs and yaws.
STMF407G-DISC1
What i dont understand, it is with all mpu6050 libraries. Currently im Using Tiny MPU6050 and Libmaster can
Truely im far away from knowingenought , to search errors into the library code.
what i saw, both included arduino.h. but i dindt find if somewhere the i2c is new declared.
in my opinion the two libraries couldnt bite each other, cause one goes over spi and one over i2c?
Well hard to say.
Could you give us the libraries you used.
thala
Post by thala »
Hi i tried myself by searching.
First i threw out the MPU Librarie and hardcoded the mpu part
So actual code is:
#include <can.h>
#include <SPI.h>
int gyro_x, gyro_y, gyro_z;
long acc_x, acc_y, acc_z, acc_total_vector;
int temperature;
long gyro_x_cal, gyro_y_cal, gyro_z_cal;
long loop_timer;
int lcd_loop_counter;
float angle_pitch, angle_roll, angle_yaw;
int angle_pitch_buffer, angle_roll_buffer, angle_yaw_buffer;
//boolean set_gyro_angles;
float angle_roll_acc, angle_pitch_acc, angle_yaw_acc;
float angle_pitch_output, angle_roll_output, angle_yaw_output;
int rpm = 2;
  wire.begin();
   Serial.begin(9600);//not needed
    Wire.begin();
    delay(250);
  SPI.setMOSI(PA7);
SPI.setMISO(PA6);
SPI.setSCLK(PA5);
SPI.begin();
 setup_mpu_6050_registers();
void read_mpu_6050_data() {                                             //Subroutine for reading the raw gyro and accelerometer data
    Wire.beginTransmission(0x68);                                        //Start communicating with the MPU-6050
    Wire.write(0x3B);                                                    //Send the requested starting register
    Wire.endTransmission();                                              //End the transmission
    Wire.requestFrom(0x68, 14);                                           //Request 14 bytes from the MPU-6050
    while (Wire.available() < 14);                                        //Wait until all the bytes are received
    acc_x = Wire.read() << 8 | Wire.read();                                  //Add the low and high byte to the acc_x variable
    acc_y = Wire.read() << 8 | Wire.read();                                  //Add the low and high byte to the acc_y variable
    acc_z = Wire.read() << 8 | Wire.read();                                  //Add the low and high byte to the acc_z variable
    temperature = Wire.read() << 8 | Wire.read();                            //Add the low and high byte to the temperature variable
    gyro_x = Wire.read() << 8 | Wire.read();                                 //Add the low and high byte to the gyro_x variable
    gyro_y = Wire.read() << 8 | Wire.read();                                 //Add the low and high byte to the gyro_y variable
    gyro_z = Wire.read() << 8 | Wire.read();                                 //Add the low and high byte to the gyro_z variable
void setup_mpu_6050_registers() {
    //Activate the MPU-6050
    wire.beginTransmission(0x68);                                        //Start communicating with the MPU-6050
    wire.write(0x6B);                                                    //Send the requested starting register
    wire.write(0x00);                                                    //Set the requested starting register
    wire.endTransmission();                                              //End the transmission
    //Configure the accelerometer (+/-8g)
    wire.write(0x1C);                                                    //Send the requested starting register
    wire.write(0x10);                                                    //Set the requested starting register
    //Configure the gyro (500dps full scale)
    wire.write(0x1B);                                                    //Send the requested starting register
    wire.write(0x08);                                                    //Set the requested starting register
  read_mpu_6050_data();
int a = (int)(acc_x);
int b = (int)(acc_y);
int c = (int)(acc_z);
int d = (int)(gyro_x);
int e = (int)(gyro_y);
int f =  (int)(gyro_z);
delay(100);
Serial.print("X = ");
    Serial.println(gyro_x);
    Serial.print("Y = ");
    Serial.println(gyro_y);
    Serial.print("Z = ");
    Serial.println();
    delay(250);
For me it looks like the mcp can library deactivates the i2c interface
Cause if i commentate the
out, the imu is giving data which are plausible. With this in, the imu doesnt throw any changing data.
MCP Library :https://github.com/autowp/arduino-mcp2515
Or is it that kind of problem: viewtopic.php?f=18&t=630&p=4101&hilit=i2c+spi#p4101 --> I tryed to redefine , but nothing changend
fawadansari89
Post by fawadansari89 »
Hi I need
help with using MCP2515 library, this is my sketch my BLUEPILL is not responding to it
kindly guide me also what pins to use for SPI communication
#include <SPI.h> //Library for using SPI Communication
#include <mcp2515.h> //Library for using CAN Communication
struct can_frame canMsg;
MCP2515 mcp2515(PA4);
while (!Serial);
SPI.begin(); //Begins SPI communication
mcp2515.reset();
mcp2515.setBitrate(CAN_500KBPS,MCP_8MHZ); //Sets CAN at speed 500KBPS and Clock 8MHz
canMsg.can_id = 0x036; //CAN id as 0x036
canMsg.can_dlc = 1; //CAN data length as 8
int pot = analogRead(A3);
pot = map(pot,0, 1023, 0, 255);
canMsg.data[0] = pot; //Update humidity value in [0]
mcp2515.sendMessage(&canMsg); //Sends the CAN message
