Use of global/static objects
hreintke
Post by hreintke »
LS,
Is there a limitation on the usage of static/global objects ?
When instantiating a global object from my local library the board freezes (both stm32f103 & stm32f411)'
Minimal sketch :
#include "CommandProcessing.h"
CommandHandler* commandHandler = new CommandHandler; -> Fails
CommandHanlder commandHandler;                       -> Fails
CommandHandler* commandHandler; // + new in setup -> OK.
//  commandHandler = new CommandHandler;
  pinMode(PC13,OUTPUT);
  digitalWrite(PC13,HIGH);
  delay(500);
  digitalToggle(PC13);
The CommandHandler class has low memory usgae.
Did not get into the implementation details as I would like to know the eventual limitations first.
Re: Use of global/static objects
I don't know which library you used any you cannot use new at global.
For the second, I gues the constructor execute some code that's probably why it's failed.
Try to define global the CommandHandler* commandHandler;
then do the new in the setup().
hreintke
Post by hreintke »
Initializing it that way is working OK.
The library is my own, I am using it extensive in my esp8266 & esp32 projects without the limitation of only "new in setup".
No big constructor either.
Trying to find the root cause, so I can prevent future identical issues.
If there are no known limitations I will get into the details and hopefully get to a small sketch.
Could you share your library ?
hreintke
Post by hreintke »
Yes, I can share but overall it is a complex one with combined esp/stm support.
Let me first try to make a minimal version of it by stripping and shortcutting.
hreintke
Post by hreintke »
I found the root cause.
In the constructor I had and old debug print statement to Serial1.
For completeness, I have options
- USB support : None
- U(S)ART : Enabled (generic Serial)
Small sketch to reproduce the issue
#include "Arduino.h"
#include "srcWrapper.h"
class CommandHandler
public:
	CommandHandler()
//		Serial1.printf("test");  //--> Instantiation fails when uncommented
CommandHandler commandHandler;
	pinMode(LED_BUILTIN,OUTPUT);
	digitalWrite(LED_BUILTIN,LOW);
	delay(500);
	digitalToggle(LED_BUILTIN);
I do not (yet) have the detailed knowledge of the stm32duino core to investigate further.
But if you can give some hints on where to look, maybe I can help/
Thanks for feedback.
You canno't use Serial at this time as instantiation is done before the sytem init (hal init, clock config) and also Serial1 can simply not be instantiate at this time and also not configureed by the Serial.begin()...
Answers: 8
This is why a good practice is to define an init() function for the class where you want to insert debug code.
