I2C - which library to use for hardware I2C
i998
Post by i998 »
Hi All,
What is the correct way to use hardware and software I2C on Maple Mini board with the Roger Clark's core ?
There are
Wire.h (that apparently has an issue 858
Wire_slave.h that was recommended as a solution ( update - tested and works)
and
TwoWire that I use as a hardware I2C as follows (tested and works too):
    //Setup I2C interface
    TwoWire I2C_FAST=TwoWire(1,I2C_FAST_MODE); //I2C1
    //Instantiate a device library
    DeviceLibrary  Device = DeviceLibrary(&I2C_FAST, 0x40);  //a pointer to I2C interface and I2C address
Just would like to confirm which ones are a right use and which one is for hardware and software I2C?
Regards, i998
