What is the correct way to use hardware and software I2C on Maple Mini board with the Roger Clark's core ?
There are
Wire.h (that apparently has an issue 858
Wire_slave.h that was recommended as a solution ( update - tested and works)
and
TwoWire that I use as a hardware I2C as follows (tested and works too):
//Setup I2C interface
TwoWire I2C_FAST=TwoWire(1,I2C_FAST_MODE); //I2C1
//Instantiate a device library
DeviceLibrary Device = DeviceLibrary(&I2C_FAST, 0x40); //a pointer to I2C interface and I2C address
Regards, i998
