Serial.print not works
Answers: 91
Re: Serial.print not works
Which core you used? For stm32core you have to enable the USB CDC in the menu.
Answers: 25
did you connect your usb cable to the port? note that if you use a st-link to program it, st-link do not work as a usb-serial cable.
you need to connect a normal usb cable at the usb port
you should also make sure you can blink the led, for blue pills there are those with fake stm32f103 mcus
Answers: 91
For roger's USB is enabled by default.
Answers: 25
there are some setup instructions for com and dfu port for roger's core, please review the wiki in github
