How to use USB pins?
forfrends
Post by forfrends »
Hello. I encountered a restriction on the use of pins. I need to use USB pins (PA11 and PA12) for my own purposes. But if I write a simple sketch, then the pin switching does not happen:
#define Pin1 PA11
#define Pin2 PA12
    pinMode(Pin1, OUTPUT);
    pinMode(Pin2, OUTPUT);
    digitalWrite(Pin1, LOW);
    digitalWrite(Pin2, LOW);
    digitalWrite(Pin1, HIGH);
    digitalWrite(Pin2, HIGH);
It seems that somewhere these pins are used, possibly USB Serial. Can I use these pins somehow?
by stevestrong » Sun Apr 19, 2020 3:38 pm
Serial.end();
Answers: 4
Re: How to use USB pins?
From: http://docs.leaflabs.com/docs.leaflabs.com/index.html GPIO Information
Pin D23 (PA12) is the USB D+ line, and D24 (PA11) is the USB D- line. To use them as GPIOs, your program will need to disable SerialUSB first. Be aware, however, that disabling SerialUSB means that the bootloader won’t work properly, and you’ll need to use Perpetual Bootloader Mode to make your next upload.
forfrends
Post by forfrends »
Thanks!
Can you tell me how to disable SerialUSB?
Answers: 8
Serial.end();
forfrends
Post by forfrends »
Thank you, you helped me a lot!
