Need to change Vector table Address
Re: Need to change Vector table Address
I have no idea if this is resetting or jumping to 8010000, the debugger should show you the stack pointer.
sankarAMP2
Post by sankarAMP2 »
In keil
Registers window
R0:0x08010145
R13(SP):0x20000458
in debugger window the pointer showing
0x8010E62 421   CMP    r1,r4
I'm in very big confusion now, why it this bootloader is working with keil generated code not Arduino?
You should track step by step with the debugger what is happening with Arduino generated code.
If the bootloader jumps to 0x8010xxxx address then it is the application which is faulty.
You could also compare the MAP files for the code generated with Keil and Arduino to figure out the difference.
darkspr1te
Post by darkspr1te »
It could be a module in arduino being enabled (eg usb) that might be conflicting with the bootloader , that is just a assumption thought.
sankarAMP2
thank you @stevestrong and @darkspr1te.
bootloader is jumping to 0x8010000 perfectly but application not going forward. I assume that the problem with arduino generated file.
Now I want to generate same simple blinky example in STM32CUBE IDE. I'm new to use this IDE.
I found linker file STM32F103RET6_FLASH.ld and I changed flash address there, Is that enough or need to change any other files?
stas2z
Answers: 8
Post by stas2z »
sankarAMP2 wrote:
Mon Jun 08, 2020 6:50 am
VECT_TAB_OFFSET inside the system_stm32f1xx.c
sankarAMP2
stas2z wrote:
Mon Jun 08, 2020 7:54 am
Thank you @stas2z
After changing flash address in both files, this blinky application generated in cude ide also not working with that bootloader. Bootloader might be buggy.. :roll:
stas2z
Answers: 8
Post by stas2z »
First check if your jump from bl is working properly, just flash generated bin to exact offset using cubeprog
sankarAMP2
Thank you every one for your great support.
Now its working fine.
bug in bootloader code only.
by commenting __set_MSP(*mcuFirstPageAddr); this line is going to work.
