Need to change Vector table Address
- Contact:
Re: Need to change Vector table Address
I have no idea if this is resetting or jumping to 8010000, the debugger should show you the stack pointer.
In keil
Registers window
in debugger window the pointer showing
I'm in very big confusion now, why it this bootloader is working with keil generated code not Arduino?
Registers window
R0:0x08010145
R13(SP):0x20000458
0x8010E62 421 CMP r1,r4
- Contact:
You should track step by step with the debugger what is happening with Arduino generated code.
If the bootloader jumps to 0x8010xxxx address then it is the application which is faulty.
You could also compare the MAP files for the code generated with Keil and Arduino to figure out the difference.
It could be a module in arduino being enabled (eg usb) that might be conflicting with the bootloader , that is just a assumption thought.
thank you [mention]stevestrong[/mention] and [mention]darkspr1te[/mention].
bootloader is jumping to 0x8010000 perfectly but application not going forward. I assume that the problem with arduino generated file.
Now I want to generate same simple blinky example in STM32CUBE IDE. I'm new to use this IDE.
I found linker file STM32F103RET6_FLASH.ld and I changed flash address there, Is that enough or need to change any other files?
VECT_TAB_OFFSET inside the system_stm32f1xx.csankarAMP2 wrote: ↑Mon Jun 08, 2020 6:50 amI found linker file STM32F103RET6_FLASH.ld and I changed flash address there, Is that enough or need to change any other files?
First check if your jump from bl is working properly, just flash generated bin to exact offset using cubeprog
Thank you every one for your great support.
Now its working fine.
bug in bootloader code only.
by commenting __set_MSP(*mcuFirstPageAddr); this line is going to work.
