[Solved] I need to return a single value from incoming serial data...
Answers: 8
Re: I need to return several values from incoming serial data...
Try this (beside your setup)
#define NR_BYTES 10
uint8 inBytes[10], inCnt;
uint32 rxTime;
  if (Serial2.received()>=0) // serial data available?
    uint32 m = millis();
    if ((m-rxTime)>20)
	inCnt = 0
    rxTime = m;
    if (inCnt>=NR_BYTES)
	inCnt = 0;
    inBytes[inCnt++] = Serial2.read();
  if (is_button_press==LOW && !digitalRead(buttonPin)) // button pressed?
    is_button_press = HIGH;
    digitalWrite(ledPin, LOW); // turn LED on
    for (int i=0; i<NR_BYTES; i++)
      Serial.write(inBytes[i]);
    Serial.write('\n');
    delay(debounce_delay);
  if (is_button_press==HIGH && digitalRead(buttonPin)) // button released?
    is_button_press = LOW;
    digitalWrite(ledPin, HIGH); // turn LED off
You can adjust NR_BYTES dependent on how many bytes do you see in monitor.
Answers: 8
Re: I need to return a single value from incoming serial data...
And here a version which outputs data each time the scale send some data, independent on any button.
#define NR_BYTES 10
uint8 inBytes[10], inCnt, dataIn;
uint32 rxTime;
  if ((m-rxTime)>20)
    inCnt = 0
    if (dataIn==1)
        dataIn = 0;
        Serial.write('\n');
    dataIn = 1;
    rxTime = m;
      inCnt = 0;
LORDHADES
Post by LORDHADES »
stevestrong wrote: Sat Nov 28, 2020 11:24 am Try this (beside your setup)
#define NR_BYTES 10
uint32 rxTime;
    if ((m-rxTime)>20)
	inCnt = 0
    rxTime = m;
	inCnt = 0;
    Serial.write('\n');
Thank you so much for your continuous support and being kind to me, Sir.... :)
I tweaked your code as below:
#define buttonPin PA0
#define ledPin PC13
#define NR_BYTES 7
uint8 inByte[10], inCnt;
uint32 rxTime;
int is_button_press = 0;
int debounce_delay = 300;
  pinMode(ledPin, OUTPUT);
  pinMode(buttonPin, INPUT_PULLUP);
  Serial2.begin(9600);
  if (Serial2.available()>=0)
    if ((m-rxTime)>20)
         inCnt = 0;
    rxTime = m;
        inCnt = 0;
    inByte[inCnt++] = Serial2.read();
    Serial.write(inByte[i]);
    Serial.write('\n');
But sir, unfortunately, the output on serial monitor is:
17:29:02.245 -> ⸮⸮⸮⸮⸮⸮⸮
17:29:03.232 -> ⸮⸮⸮⸮⸮⸮⸮
17:29:03.842 -> ⸮⸮⸮⸮⸮⸮⸮
17:29:04.123 -> ⸮⸮⸮⸮⸮⸮⸮
17:29:04.498 -> ⸮⸮⸮⸮⸮⸮⸮
17:29:06.311 -> ⸮⸮⸮⸮⸮⸮⸮
17:29:07.249 -> ⸮⸮⸮⸮⸮⸮⸮
17:29:08.280 -> ⸮⸮⸮⸮⸮⸮⸮
17:29:09.030 -> ⸮⸮⸮⸮⸮⸮⸮
17:29:10.108 -> ⸮⸮⸮⸮⸮⸮⸮
17:29:11.701 -> ⸮⸮⸮⸮⸮⸮⸮
17:29:12.639 -> ⸮⸮⸮⸮⸮⸮⸮
17:29:13.389 -> ⸮⸮⸮⸮⸮⸮⸮
17:29:14.139 -> ⸮⸮⸮⸮⸮⸮⸮
17:29:14.982 -> ⸮⸮⸮⸮⸮⸮⸮
LORDHADES
Post by LORDHADES »
stevestrong wrote: Sat Nov 28, 2020 11:45 am And here a version which outputs data each time the scale send some data, independent on any button.
#define NR_BYTES 10
uint32 rxTime;
  if ((m-rxTime)>20)
    inCnt = 0
    if (dataIn==1)
        dataIn = 0;
        Serial.write('\n');
    dataIn = 1;
    rxTime = m;
      inCnt = 0;
Again, I tweaked your code as below:
#define ledPin PC13
#define NR_BYTES 7
uint8 inByte[10], inCnt, dataIn;
uint32 rxTime;
    if ((m-rxTime)>20)
     inCnt = 0;
     if (dataIn == 1)
      dataIn = 0;
      Serial.write('\n');
    if (Serial2.available()>0)
      dataIn = 1;
      rxTime = m;
      inCnt = 0;
      inByte[inCnt++] = Serial.read();
But, unfortunately, this renders no output... :cry:
The Serial monitor is empty...
Answers: 8
If the serial monitor is empty that means that no data is received fron the scale.
This is why you see "?" in monitor for the first version, too.
LORDHADES
Post by LORDHADES »
stevestrong wrote: Sat Nov 28, 2020 12:35 pm If the serial monitor is empty that means that no data is received fron the scale.
Any solutions Sir?
int inByte;
  if(Serial2.available()>0)
  inByte = Serial2.read();
  Serial.write(inByte);
The above code generates below output:
18:18:02.504 -> 000.092
18:18:02.598 -> 000.092
18:18:02.705 -> 000.092
18:18:02.799 -> 000.092
18:18:02.939 -> 000.092
18:18:03.021 -> 000.092
18:18:03.115 -> 000.092
18:18:03.256 -> 000.092
18:18:03.349 -> 000.092
18:18:03.457 -> 000.092
18:18:03.551 -> 000.092
18:18:03.644 -> 000.092
18:18:03.784 -> 000.092
18:18:03.874 -> 000.092
Then why the previous code didn't receive weight? :shock:
I'm dying.. :?
Answers: 8
The misstake is that you tweaked my code incorrectly.
inBytes[inCnt++] = Serial.read();
should be
I added LED blink by data reception:
#define NR_BYTES 10
uint32 rxTime;
  if ((m-rxTime)>20)
    inCnt = 0
    if (dataIn==1)
        dataIn = 0;
        Serial.write('\n');
  if (Serial2.available()>0) // serial data available?
    dataIn = 1;
    rxTime = m;
      inCnt = 0;
LORDHADES
Post by LORDHADES »
stevestrong wrote: Sat Nov 28, 2020 12:58 pm The misstake is that you tweaked my code incorrectly.
should be
#define NR_BYTES 10
uint32 rxTime;
  if ((m-rxTime)>20)
    inCnt = 0
    if (dataIn==1)
        dataIn = 0;
        Serial.write('\n');
    dataIn = 1;
    rxTime = m;
      inCnt = 0;
Yout last two codes return output as:
800.11
800.11
800.11
800.11
800.11
800.11
800.11
But the weighing scale reading is 0.118.. :? :? :?
LORDHADES
Post by LORDHADES »
should be
:D
I'm sorry for that, Sir.. childish mistake.. :D
Answers: 8
change
if ((m-rxTime)>20)
to
if ((m-rxTime)>50)
And you don't need to quote every time my posts, it makes the reading hard. ;)
