freeRTOS900 hangs
sankarAMP2
freeRTOS900 hangs
Post by sankarAMP2 »
Hello guys,
I wrote a code with freeRTOS multi threading and gsm mqtt.
My environment:
using Harware:
using libraries:
https://github.com/rogerclarkmelbourne/ ... reeRTOS900
https://github.com/knolleary/pubsubclient
https://github.com/vshymanskyy/TinyGSM
And my issue is: Code with freeRTOS900 or pubsubclient individually working fine but when I’m using both together the controller hangs unexpectedly…
Please help me to find reasons for RTOS hanging?
Thanq,
Sankar
Re: freeRTOS900 hangs
Post by Pito »
That description of your problem is not enough to help you.
Porting existing libraries into an Rtos is not easy - you have to create tasks which interacts, etc.
Best you will publish your entire code and it could be somebody helps you then..
a blue pill has only 20k of memory, of which part of it is used by usb and partly the core itself, then freeRTOS further sub-divide memory into smaller fixed sized compartments for each vtask. so most likely you've run out of memory either for the vtasks or the overall shared memory
