how to PWM Frequency stm32duino and resolution
navanod
Post by navanod »
First time post here for me so hi:)
I am looking on any tips to set up PWM frequency with a blue pill in the current arduino stm32duino release. I was throw a little by trying to get pwmWrite to work.
I can see that this basic example works
 analogWrite(A1, 127); // Start PWM on A1, at 1000 Hz with 50% duty cycle
  analogWriteFrequency(200000); // Set PMW period to 2000 Hz instead of 1000
and to set resolution I am using
analogWriteResolution (16);
Any other tips for making nice PWM with the stm32?
Answers: 33
Re: how to PWM Frequency stm32duino and resolution
navanod
Post by navanod »
Thank you fpiSTM that pretty much answers everything:) - Not sure how I missed those examples
Answers: 33
welcome ;)
navanod wrote:
Fri Jun 12, 2020 8:31 am
When you install board/library support in the ArduinoIDE, you often get examples too.
Good luck,
navanod
Post by navanod »
Thanks Ray, I had not installed them..still getting used to using the stm32 but now loving that hardware PWM:)
seandepagnier
Post by seandepagnier »
This is working great, but how do I use the library to set complementary outputs with adjustable deadtime?
rather than waiting for someone to write the code for you, take a look at the reference manual and see how it can be done (easily as well).
seandepagnier
it seems deadtime is not supported and complementary output is not working either.
So I have now:
  pwm_handle.Instance = TIM1;
  pwm_handle.Channel = HAL_TIM_ACTIVE_CHANNEL_CLEARED;
  pwm_handle.hdma[0] = NULL;
  pwm_handle.hdma[1] = NULL;
  pwm_handle.hdma[2] = NULL;
  pwm_handle.hdma[3] = NULL;
  pwm_handle.hdma[4] = NULL;
  pwm_handle.hdma[5] = NULL;
  pwm_handle.hdma[6] = NULL;
  pwm_handle.Lock = HAL_UNLOCKED;
  pwm_handle.State = HAL_TIM_STATE_RESET;
  /* Configure timer with some default values */
  pwm_handle.Init.Prescaler = 0;
  pwm_handle.Init.Period = 400;
  pwm_handle.Init.CounterMode = TIM_COUNTERMODE_UP;
  pwm_handle.Init.ClockDivision = TIM_CLOCKDIVISION_DIV1;
  pwm_handle.Init.AutoReloadPreload = TIM_AUTORELOAD_PRELOAD_ENABLE;
  TIM_HandleTypeDef *h = &pwm_handle;
  enableTimerClock(h);
  HAL_TIM_Base_Init(h);
  /* Configure some default values. Maybe overwritten later */
  TIM_OC_InitTypeDef channelOC;
  channelOC.OCMode = TIMER_NOT_USED;
  channelOC.Pulse = __HAL_TIM_GET_COMPARE(h, TIM_CHANNEL_1);
  channelOC.OCPolarity = TIM_OCPOLARITY_HIGH;
  channelOC.OCFastMode = TIM_OCFAST_DISABLE;
  channelOC.OCIdleState = TIM_OCIDLESTATE_RESET;
  channelOC.OCNPolarity = TIM_OCNPOLARITY_HIGH;
  channelOC.OCNIdleState = TIM_OCNIDLESTATE_RESET;
  channelOC.OCMode = TIM_OCMODE_PWM1;
  HAL_TIM_PWM_ConfigChannel(h, &channelOC, TIM_CHANNEL_1);
  /* Set the Break feature & Dead time */
  TIM_BreakDeadTimeConfigTypeDef sBreakConfig;
  sBreakConfig.BreakState       = TIM_BREAK_DISABLE;
  sBreakConfig.DeadTime         = 14;
  sBreakConfig.OffStateRunMode  = TIM_OSSR_ENABLE;
  sBreakConfig.OffStateIDLEMode = TIM_OSSI_ENABLE;
  sBreakConfig.LockLevel        = 0;//TIM_LOCKLEVEL_1;
  sBreakConfig.BreakPolarity    = TIM_BREAKPOLARITY_LOW;  // does matter?
  sBreakConfig.AutomaticOutput  = TIM_AUTOMATICOUTPUT_ENABLE;
  HAL_TIMEx_ConfigBreakDeadTime(h, &sBreakConfig);
  LL_TIM_SetPrescaler(TIM1, 0);
  __HAL_TIM_SET_AUTORELOAD(&pwm_handle, 400); // switch to 20khz
    __HAL_TIM_SET_COMPARE(&pwm_handle, TIM_CHANNEL_1, 400-65);
    pinmap_pinout(digitalPinToPinName(PA8), PinMap_PWM);
   HAL_TIM_PWM_Start(&pwm_handle, TIM_CHANNEL_1);
  pinmap_pinout(digitalPinToPinName(PB13), PinMap_PWM);
  HAL_TIMEx_PWMN_Start(&pwm_handle, TIM_CHANNEL_1);
alfrond
Post by alfrond »
Hi!
I am too trying to get pwm/compl outuputs/dead time to run on the STM32.
I'm not very experienced, but I see in the timer.h (if I remember correctly) that some timer/pwm functions doesn't seem implemented.
I have thouroughly read the STM32 reference manual, and it is quite clearly stated what registers to set and how to get it running. My problem now is that I'm not sure how to correctly write directly to registers using arduino IDE with the STM32dino..
Did you make progress?
Anyone who can help out? I know all the registers to use, I get bit arithmetics, but what is the syntax?
seandepagnier wrote:
Wed Jul 22, 2020 4:12 pm
So I have now:
