SPI partly working when using hardware, library or code CS management
mrguen
Post by mrguen »
Maybe some of you know well the SPI?
I am trying to communicate between STM32F401RCT6 and an ADC module MCP3561.
The expected com on SPI is attached at the end of the message.
The SPI used is SPI2 with alternate pins
const byte SPI_MOSI = PC3;
const byte SPI_MISO = PC2;
const byte SPI_SCK = PB13;
const byte SPI_CS = PB12;
const uint32_t spiClk = 5000000; // or 10 MHz
byte passedValue = (MCP3561DeviceAddress << 6) & REGISTER_CONFIG1 << 2 & COMMAND_STATIC_READ_REGISTER;
1) It is partly working when using the hardware CS pin. The device answers correctly. But since the CS pin probably goes up after each transfer I can't read the data after sending a command.
SPIClass mySPI2(SPI_MOSI, SPI_MISO, SPI_SCK, SPI_CS);
SPISettings mySPIsettings = SPISettings(spiClk, MSBFIRST, SPI_MODE0);
mySPI2.begin();
mySPI2.beginTransaction(mySPIsettings);
returnedValue =  mySPI2.transfer(passedValue);
// The returned value is as expected (returning the MCP3561DeviceAddress): 00011111
returnedData =  mySPI2.transfer(0);
// Not correct all "1" . The device is supposed to send the data immediatly after receiving and answering to the command, never mind what is on MOSI.  But indeed if CS goes high MISO is supposed to return to HIGH. Or maybe I didn't catch the data ? (I did not find a shiftIn method).
mySPI2.endTransaction();
2) Using the CS management in the library: not working
SPIClass mySPI2(SPI_MOSI, SPI_MISO, SPI_SCK);
mySPI2.begin(SPI_CS);
returnedValue =  mySPI2.transfer(passedValue, SPI_CONTINUE);
// The returned value is NOT as expected - all "1"
returnedData =  mySPI2.transfer(0, SPI_LAST);
3) Managing CS pin in the code: working as with hardware management
pinMode(SPI_CS, OUTPUT);
digitalWrite(SPI_CS, HIGH);
mySPI2.begin();
digitalWrite(SPI_CS, LOW);
What might be wrong? Also I could not find a shiftIn() method.
by mrguen » Wed Sep 02, 2020 12:28 pm
The command was not correct. I can have it work when managing the CS pin in the code. I did not tested more the other two methods.
Re: SPI partly working when using hardware, library or code CS management
Hi @mrguen
did you read the wiki:
https://github.com/stm32duino/wiki/wiki/API#spi
Maybe you need the SPI_CONTINUE ?
mrguen
Post by mrguen »
@fpiSTM Yes I did read the WIKI and use SPI_CONTINUE in example 2, but maybe not correctly?
Well, like this I see nothing wrong. Anyway, I don't know this component (MCP3561),
is your value correct
mrguen
Post by mrguen »
@fpiSTM Yes this is a recent component (2019). So there is hardly any info available. I guess I have to analyze the signals. I will do some more test and let you know.
mrguen
Post by mrguen »
