USB Composite read MIDI messages
leogomide07
Post by leogomide07 »
Greetings Everyone.
Im trying to get messages from Traktor in my bluepill, but when i send a message in the software, my function is never called
Im using the exemple that comes with the library, but with the onboard led:
#include <USBComposite.h>
class myMidi : public USBMIDI {
 virtual void handleNoteOff(unsigned int channel, unsigned int note, unsigned int velocity) {
  digitalWrite(PC13, LOW);
 virtual void handleNoteOn(unsigned int channel, unsigned int note, unsigned int velocity) {
myMidi midi;
USBCompositeSerial CompositeSerial;
    USBComposite.setProductId(0x0030);
    midi.registerComponent();
    CompositeSerial.registerComponent();
    USBComposite.begin();
    pinMode(PC13, OUTPUT);
    digitalWrite(PC13, HIGH);
  midi.poll();
I have tested if the software is really sending the message with LoopBe1 and another midi software, and i can get the output from it
Im doing something wrong in the code? There is another type of function that can work?
* i have tested the functions 'handleSysExData' and 'handleSysExEnd' too but same result
Bakisha
Answers: 3
Re: USB Composite read MIDI messages
Post by Bakisha »
What OS are you using?
If windows, does it have "Maple" audio device in device manager?
In your Traktor program, did you selected "Maple" as midi-out device?
I had problem with drivers, and fix for me is to set different device ID (i used USBComposite.setProductId(0x0020); )
leogomide07
Greetings, sorry for the delay
I have tested to change the ID number, does not work too
And yes, traktor can identify it as a midi in-out device
Hope some day we can have this lib to the official stm32 core :/
Bakisha
Answers: 3
Post by Bakisha »
You could try
Also, update library from library manager, if you havent.
Maybe even check is core have any updates.
