Problem creating new Variant STM32L151C
toogooda
Post by toogooda »
Hi I created two new Variants using the github wiki instructions here https://github.com/stm32duino/wiki/wiki ... nt-(board) one works perfectly the other compilies but does not work with blink example.
I can rule out hardware as blink using stm32cudeprogramer works fine.
Here is the boards.txt
# Generic L1
GenL1.name=Generic STM32L1 series
GenL1.build.core=arduino
GenL1.build.board=GenL1
GenL1.build.extra_flags=-D{build.product_line} {build.enable_usb} {build.xSerial}
# Generic L151C8xx
GenL1.menu.pnum.L151C8xx=Generic L151C8
GenL1.menu.pnum.L151C8xx.upload.maximum_size=65536
GenL1.menu.pnum.L151C8xx.upload.maximum_data_size=10240
GenL1.menu.pnum.L151C8xx.build.mcu=cortex-m3
GenL1.menu.pnum.L151C8xx.build.board=L151C8xx
GenL1.menu.pnum.L151C8xx.build.series=STM32L1xx
GenL1.menu.pnum.L151C8xx.build.product_line=STM32L151xB
GenL1.menu.pnum.L151C8xx.build.variant=Generic_L151Cx
GenL1.menu.pnum.L151C8xx.build.cmsis_lib_gcc=arm_cortexM3l_math
# Generic L151C8xxA
GenL1.menu.pnum.L151C8xxA=Generic L151C8-A
GenL1.menu.pnum.L151C8xxA.upload.maximum_size=65536
GenL1.menu.pnum.L151C8xxA.upload.maximum_data_size=32768
GenL1.menu.pnum.L151C8xxA.build.mcu=cortex-m3
GenL1.menu.pnum.L151C8xxA.build.board=L151C8xxA
GenL1.menu.pnum.L151C8xxA.build.series=STM32L1xx
GenL1.menu.pnum.L151C8xxA.build.product_line=STM32L151xBA
GenL1.menu.pnum.L151C8xxA.build.variant=Generic_L151CxA
GenL1.menu.pnum.L151C8xxA.build.cmsis_lib_gcc=arm_cortexM3l_math
# Upload menu
GenL1.menu.upload_method.swdMethod=STM32CubeProgrammer (SWD)
GenL1.menu.upload_method.swdMethod.upload.protocol=0
GenL1.menu.upload_method.swdMethod.upload.options=-g
GenL1.menu.upload_method.swdMethod.upload.tool=stm32CubeProg
GenL1.menu.upload_method.serialMethod=STM32CubeProgrammer (Serial)
GenL1.menu.upload_method.serialMethod.upload.protocol=1
GenL1.menu.upload_method.serialMethod.upload.options={serial.port.file} -s
GenL1.menu.upload_method.serialMethod.upload.tool=stm32CubeProg
GenL1.menu.upload_method.dfuMethod=STM32CubeProgrammer (DFU)
GenL1.menu.upload_method.dfuMethod.upload.protocol=2
GenL1.menu.upload_method.dfuMethod.upload.options=-g
GenL1.menu.upload_method.dfuMethod.upload.tool=stm32CubeProg
GenL1.menu.upload_method.bmpMethod=BMP (Black Magic Probe)
GenL1.menu.upload_method.bmpMethod.upload.protocol=gdb_bmp
GenL1.menu.upload_method.bmpMethod.upload.tool=bmp_upload
L151C8xxA is the working one L151C8xx is the one that is a problem
I used the timer config and LD file from the working stm32cubeprogrammer so not sure what to try next.
It compiles, downloads but does not blink.
Attached full variant folder
Any ideas?
Generic_L151Cx.zip
(7.83 KiB) Downloaded 212 times
Re: Problem creating new Variant STM32L151C
Probably the clock config.
toogooda
Post by toogooda »
fpiSTM wrote: Thu Oct 01, 2020 4:38 am Probably the clock config.
"void SystemClock_Config(void)" function was copied from STM32CubeIDE auto generated form a working blink example that was tested.
other than that function in variant.cpp are you referring to any other config?
here it is here
  RCC_OscInitStruct.PLL.PLLMUL = RCC_PLL_MUL8;
  RCC_OscInitStruct.PLL.PLLDIV = RCC_PLL_DIV2;
    Error_Handler();
  if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_1) != HAL_OK)
    Error_Handler();
toogooda
Post by toogooda »
@fpiSTM are you able to give me more detail? I can't seem to solve this, I used the SystemClock_Config(void) that worked in STM32CubeIDE can you give me anything else I can check?
.rpv
Post by .rpv »
toogooda wrote: Wed Oct 07, 2020 9:15 pm
Hi, you could check if there is a pin naming error, instead of a blinking sketch you just use HIGH on the LED-pin and with a multimeter or with an external led+resistor check every pin to see if a wrong pin is getting the HIGH value.
