Problem with timer
saeed144
Problem with timer
Post by saeed144 »
Hello
I tried to test my STM32F103C8T6 timer but it didn't work.
Can you help me?
#if !defined(STM32_CORE_VERSION) || (STM32_CORE_VERSION  < 0x01090000)
#error "Due to API change, this sketch is compatible with STM32_CORE_VERSION  >= 0x01090000"
void Update_IT_callback(void)
  digitalWrite(PA11, !digitalRead(PA13));
#if defined(TIM1)
  TIM_TypeDef *Instance = TIM1;
#else
  TIM_TypeDef *Instance = TIM2;
  pinMode(PA11, OUTPUT);
  digitalWrite(PA11, HIGH);
  //MyTim->setPrescaleFactor(72000000);
  MyTim->setOverflow(1, HERTZ_FORMAT);
  MyTim->attachInterrupt(Update_IT_callback);
  MyTim->resume();
LED on pin A11 should blink every second.
by fpiSTM » Tue Nov 24, 2020 10:28 am
This is a register read.
  * @brief  Retrieve prescaler from hardware register
  * @param  None
  * @retval prescaler factor
uint32_t HardwareTimer::getPrescaleFactor()
  // Hardware register correspond to prescaler-1. Example PSC register value 0 means divided by 1
  return (LL_TIM_GetPrescaler(_timerObj.handle.Instance) + 1);
Re: Problem with timer
As it seems PA13 never change it seems logical....
  digitalWrite(PA11, !digitalRead(PA11));
saeed144
Post by saeed144 »
Oh! you're right it blinks now , So sorry :roll:
I get presclaler factor and it returns 110.
ans = MyTim->getPrescaleFactor();
110 is default?
  * @param  None
saeed144
Post by saeed144 »
Thank you so much, you're great :)
