How to use Interrupts on STM8 with sduino
leif
Post by leif »
With some googling, sleuthing, and trial-and-error, I figured it out!
With STM8 sduino, attachInterrupt works but not like on a normal arduino.
Interrupts are separate per PORT, not per pin. Each port has multiple pins. PA1, PA2 are on port A, PC3-PC7 are on port C etc.
Use pinMode to designate the pin as input, so that digitalRead can keep working in case you need it.
After that, you must call GPIO_Init (an STM8-specific API function) to actually enable interrupts for a particular pin.
Then, you disable interrupts and call EXTI_SetExtIntSensitivity to set the interrupt trigger type on that entire port.
Finally attachInterrupt(). See my example below, this code works for me on my STM8S003F3.
Hope this saves someone some time. :)
void ISR()
  //your code here
  pinMode(2,INPUT);
  GPIO_Init(GPIOA, GPIO_PIN_3, GPIO_MODE_IN_FL_IT);
  disableInterrupts();
  EXTI_SetExtIntSensitivity( EXTI_PORT_GPIOA, EXTI_SENSITIVITY_RISE_ONLY);
  enableInterrupts();
  attachInterrupt(INT_PORTA & 0xFF,ISR,0);
///Leif
zoomx
Re: How to use Interrupts on STM8 with sduino
Post by zoomx »
+1!!!
or you can set the CR2 bits. CR1 bits enable pull-up.
hmeijdam
Post by hmeijdam »
Pin change interrupts support has been added to sduino.
A little workaround was still needed for me, as the latest sduino version 0.5.0 does not yet includes it.
I had to manually copy the files Winterrupts.h and Arduino.h from the sduino Github page and move that into my Arduino IDE overwriting the current ones in the sduino folder:
E:\Arduino\arduino-1.8.13\portable\packages\sduino\hardware\stm8\0.5.0\cores\sduino
(I have a portable Arduino IDE installation, as I use many different versions of the IDE in parralel, so this may be somewhere else for you)
I also had to change the examplesketch from the sduino project page a little.
the digitalPinToInterrupt (dummy) macro was not yet defined, so that is the line I added in my sketch as workaround-fix.
// the pin where the input button is attached. Change, if needed
#define BUTTON  PA2
#define digitalPinToInterrupt(p)  ((p)==(p)) // workaround-fix, empty macro is missing in header files
// volatile is important, because this variable is modified in IRQ routine
volatile uint8_t flag = 0;
void on_button_pressed(void) {
  flag = 1;
  pinMode(LED_BUILTIN, OUTPUT);
  digitalWrite(LED_BUILTIN, 1);   // turn off the LED
  pinMode(BUTTON, INPUT_PULLUP);
  attachInterrupt(digitalPinToInterrupt(BUTTON), on_button_pressed, FALLING);
  if (flag) {
    digitalWrite(LED_BUILTIN, 0);
    delay(300);
    flag = 0;
Now it compiled for me and when connecting a button between PA2 and GND the led on my stm8s103F3 board blinks for 300ms when the buton is pressed.
Return to “STM8 Core”
