Regarding Impementation of CAN on STM32 discovery
surajkumar.tanurkar
Post by surajkumar.tanurkar »
i want to implement CAN protocol on stm32
please help me!!!
thank you!!!
Re: Regarding Impementation of CAN on STM32 discovery
a forumer here is doing a much bigger can based project here. i'd guess you could join the effort to learn the ropes
viewtopic.php?f=10&t=99
disclaimer i'm noob about can
surajkumar.tanurkar
he is using special module for it.
i dont want to use any type of module.
thank you for your suggestion
Bingo600
Post by Bingo600 »
surajkumar.tanurkar wrote: Thu Jan 23, 2020 8:51 am he is using special module for it.
What special module ?
I see 2 x STM32 Boards with external CanBus drivers (as normal)
/Bingo
Alan3114
Post by Alan3114 »
I have just added CAN communication to my project :-)
What do you need help with ?
surajkumar.tanurkar
i am using two stm32f407 and two mcp2515 and ide using is arduino and iwant to send one stm32f407 data another stm32 using can bus so help me out
thank you!!!
Bingo600
Post by Bingo600 »
surajkumar.tanurkar wrote: Tue Jan 28, 2020 7:07 am i am using two stm32f407 and two mcp2515 and ide using is arduino and iwant to send one stm32f407 data another stm32 using can bus so help me out
thank you!!!
Afaik MCP2515 is a SPI driven Canbus controller.
Doesn't the F407 have a built in canbus interface available ??
I'm quite sure there are Arduin0 libs for the mcp2515 , if that is the way you wish to go.
/Bingo
surajkumar.tanurkar
can you share link for MCP2515 library
fawadansari89
Post by fawadansari89 »
Hi I need
help with using MCP2515 library, this is my sketch my BLUEPILL is not responding to it
kindly guide me also what pins to use for SPI communication
#include <SPI.h> //Library for using SPI Communication
#include <mcp2515.h> //Library for using CAN Communication
struct can_frame canMsg;
MCP2515 mcp2515(PA4);
while (!Serial);
SPI.begin(); //Begins SPI communication
mcp2515.reset();
mcp2515.setBitrate(CAN_500KBPS,MCP_8MHZ); //Sets CAN at speed 500KBPS and Clock 8MHz
mcp2515.setNormalMode();
canMsg.can_id = 0x036; //CAN id as 0x036
canMsg.can_dlc = 1; //CAN data length as 8
int pot = analogRead(A3);
pot = map(pot,0, 1023, 0, 255);
canMsg.data[0] = pot; //Update humidity value in [0]
mcp2515.sendMessage(&canMsg); //Sends the CAN message
