using spi1 and spi2 simultaneously
arun
Post by arun »
I want to simultaneously use the st7920 LCD at spi1 and mcp2515 at spi2 on stm32f103c8t6. I am using Arduino ide. some explanation and example code is needed. :?:
Re: using spi1 and spi2 simultaneously
It all depends on libraries you use.
Some libraries allow to choose SPI interface, some are written only for one SPI and you'll need to edit library code.
How to use different SPIs, how to change default pins, etc, you'll fine on wiki: https://github.com/stm32duino/wiki/wiki/API#spi
the answer depends on your definition of "simultaneously".
The closest you can come to it is via DMA. Even there the bus is shared so there can be cases where you aren't exactly using the two modules "simultaneously".
Most people use the word "simultaneously" in the sense of "so fast that it is as if it is simultaneously" (aka *not* simultaneously :)).
you can achieve that via really fast transmissions, using interrupts (+ buffers), or some kind of switching mechanism...
It can be done, you can declare SPI1, SPI2 etc
They goto different pins.
I've once done SD Card (SPI) and ILI9341 (SPI)
if you want to roll your own, the interrupt driven version is quite simple.
SPI ISR:
  if (transmission has reached its end) disable the SPI interrupt;
  else load up the next data to be transmitted and advance the pointer
This approach, with a FIFO buffer, is very efficient and unless you have really fast bit rate, the transmission is seamless.
the 103 is an interesting beast in that it doesn't have a (true) FIFO. so it can be quite inefficient given the isr overhead. So this approach works if the transmission bit rate is low.
arun
Post by arun »
thank you all for your replies and sorry for using the word simultaneously what I wanted to ask is how to use both spi1 and spi2.
I want to use mcp2515 at spi2. I need to modify that library.
what I want to know is what file needs to be modified and how it needs to be modified. I never modified a library file before.
thanks in advance :)
well, in a 'simple' sense, one way is to copy the 'include' (.h) and '.cpp or .c' codes of the library into your sketch folder and review the codes.
references to SPI would likely need to be changed to e.g. SPI2 for one of them.
Some libraries, allow you to pass the SPIClass object as a pointer to the library, so it'd depends on how the library is written.
arun
Post by arun »
this is the library file with spi settings
  mcp_can.cpp
  2012 Copyright (c) Seeed Technology Inc.  All right reserved.
  2017 Copyright (c) Cory J. Fowler  All Rights Reserved.
  Author: Loovee
  Contributor: Cory J. Fowler
  2017-09-25
  This library is free software; you can redistribute it and/or
  modify it under the terms of the GNU Lesser General Public
  License as published by the Free Software Foundation; either
  version 2.1 of the License, or (at your option) any later version.
  This library is distributed in the hope that it will be useful,
  but WITHOUT ANY WARRANTY; without even the implied warranty of
  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
  Lesser General Public License for more details.
  You should have received a copy of the GNU Lesser General Public
  License along with this library; if not, write to the Free Software
  Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA  02110-
  1301  USA
#include "mcp_can.h"
#define spi_readwrite SPI.transfer
#define spi_read() spi_readwrite(0x00)
** Function name:           mcp2515_reset
** Descriptions:            Performs a software reset
void MCP_CAN::mcp2515_reset(void)
    SPI.beginTransaction(SPISettings(10000000, MSBFIRST, SPI_MODE0));
    MCP2515_SELECT();
    spi_readwrite(MCP_RESET);
    MCP2515_UNSELECT();
    SPI.endTransaction();
    delay(5); // If the MCP2515 was in sleep mode when the reset command was issued then we need to wait a while for it to reset properly
** Function name:           mcp2515_readRegister
** Descriptions:            Read data register
INT8U MCP_CAN::mcp2515_readRegister(const INT8U address)
    INT8U ret;
    MCP2515_SELECT();
    spi_readwrite(MCP_READ);
    spi_readwrite(address);
    ret = spi_read();
    MCP2515_UNSELECT();
    return ret;
** Function name:           mcp2515_readRegisterS
** Descriptions:            Reads successive data registers
void MCP_CAN::mcp2515_readRegisterS(const INT8U address, INT8U values[], const INT8U n)
    INT8U i;
    MCP2515_SELECT();
    // mcp2515 has auto-increment of address-pointer
    for (i=0; i<n; i++)
        values[i] = spi_read();
    MCP2515_UNSELECT();
** Function name:           mcp2515_setRegister
** Descriptions:            Sets data register
void MCP_CAN::mcp2515_setRegister(const INT8U address, const INT8U value)
    MCP2515_SELECT();
    spi_readwrite(MCP_WRITE);
    spi_readwrite(value);
    MCP2515_UNSELECT();
** Function name:           mcp2515_setRegisterS
** Descriptions:            Sets successive data registers
void MCP_CAN::mcp2515_setRegisterS(const INT8U address, const INT8U values[], const INT8U n)
    INT8U i;
    MCP2515_SELECT();
    for (i=0; i<n; i++)
        spi_readwrite(values[i]);
    MCP2515_UNSELECT();
** Function name:           mcp2515_modifyRegister
** Descriptions:            Sets specific bits of a register
void MCP_CAN::mcp2515_modifyRegister(const INT8U address, const INT8U mask, const INT8U data)
    MCP2515_SELECT();
    spi_readwrite(MCP_BITMOD);
    spi_readwrite(mask);
    spi_readwrite(data);
    MCP2515_UNSELECT();
** Function name:           mcp2515_readStatus
** Descriptions:            Reads status register
INT8U MCP_CAN::mcp2515_readStatus(void)
    INT8U i;
    MCP2515_SELECT();
    spi_readwrite(MCP_READ_STATUS);
    i = spi_read();
    MCP2515_UNSELECT();
    return i;
** Function name:           setSleepWakeup
** Descriptions:            Enable or disable the wake up interrupt (If disabled the MCP2515 will not be woken up by CAN bus activity)
void MCP_CAN::setSleepWakeup(const INT8U enable)
    mcp2515_modifyRegister(MCP_CANINTE, MCP_WAKIF, enable ? MCP_WAKIF : 0);
** Function name:           setMode
** Descriptions:            Sets control mode
INT8U MCP_CAN::setMode(const INT8U opMode)
    mcpMode = opMode;
    return mcp2515_setCANCTRL_Mode(mcpMode);
** Function name:           mcp2515_setCANCTRL_Mode
** Descriptions:            Set control mode
INT8U MCP_CAN::mcp2515_setCANCTRL_Mode(const INT8U newmode)
	// If the chip is asleep and we want to change mode then a manual wake needs to be done
	// This is done by setting the wake up interrupt flag
	// This undocumented trick was found at https://github.com/mkleemann/can/blob/master/can_sleep_mcp2515.c
	if((mcp2515_readRegister(MCP_CANSTAT) & MODE_MASK) == MCP_SLEEP && newmode != MCP_SLEEP)
		// Make sure wake interrupt is enabled
		byte wakeIntEnabled = (mcp2515_readRegister(MCP_CANINTE) & MCP_WAKIF);
		if(!wakeIntEnabled)
			mcp2515_modifyRegister(MCP_CANINTE, MCP_WAKIF, MCP_WAKIF);
		// Set wake flag (this does the actual waking up)
		mcp2515_modifyRegister(MCP_CANINTF, MCP_WAKIF, MCP_WAKIF);
		// Wait for the chip to exit SLEEP and enter LISTENONLY mode.
		// If the chip is not connected to a CAN bus (or the bus has no other powered nodes) it will sometimes trigger the wake interrupt as soon
		// as it's put to sleep, but it will stay in SLEEP mode instead of automatically switching to LISTENONLY mode.
		// In this situation the mode needs to be manually set to LISTENONLY.
		if(mcp2515_requestNewMode(MCP_LISTENONLY) != MCP2515_OK)
			return MCP2515_FAIL;
		// Turn wake interrupt back off if it was originally off
		if(!wakeIntEnabled)
			mcp2515_modifyRegister(MCP_CANINTE, MCP_WAKIF, 0);
	// Clear wake flag
	mcp2515_modifyRegister(MCP_CANINTF, MCP_WAKIF, 0);
	return mcp2515_requestNewMode(newmode);
** Function name:           mcp2515_requestNewMode
INT8U MCP_CAN::mcp2515_requestNewMode(const INT8U newmode)
	byte startTime = millis();
	// Spam new mode request and wait for the operation  to complete
	while(1)
		// Request new mode
		// This is inside the loop as sometimes requesting the new mode once doesn't work (usually when attempting to sleep)
		mcp2515_modifyRegister(MCP_CANCTRL, MODE_MASK, newmode);
		byte statReg = mcp2515_readRegister(MCP_CANSTAT);
		if((statReg & MODE_MASK) == newmode) // We're now in the new mode
			return MCP2515_OK;
		else if((byte)(millis() - startTime) > 200) // Wait no more than 200ms for the operation to complete
** Function name:           mcp2515_configRate
** Descriptions:            Set baudrate
INT8U MCP_CAN::mcp2515_configRate(const INT8U canSpeed, const INT8U canClock)
    INT8U set, cfg1, cfg2, cfg3;
    set = 1;
    switch (canClock & MCP_CLOCK_SELECT)
        case (MCP_8MHZ):
        switch (canSpeed)
            case (CAN_5KBPS):                                               //   5KBPS
            cfg1 = MCP_8MHz_5kBPS_CFG1;
            cfg2 = MCP_8MHz_5kBPS_CFG2;
            cfg3 = MCP_8MHz_5kBPS_CFG3;
            break;
            case (CAN_10KBPS):                                              //  10KBPS
            cfg1 = MCP_8MHz_10kBPS_CFG1;
            cfg2 = MCP_8MHz_10kBPS_CFG2;
            cfg3 = MCP_8MHz_10kBPS_CFG3;
            break;
            case (CAN_20KBPS):                                              //  20KBPS
            cfg1 = MCP_8MHz_20kBPS_CFG1;
            cfg2 = MCP_8MHz_20kBPS_CFG2;
            cfg3 = MCP_8MHz_20kBPS_CFG3;
            break;
            case (CAN_31K25BPS):                                            //  31.25KBPS
            cfg1 = MCP_8MHz_31k25BPS_CFG1;
            cfg2 = MCP_8MHz_31k25BPS_CFG2;
            cfg3 = MCP_8MHz_31k25BPS_CFG3;
            break;
            case (CAN_33K3BPS):                                             //  33.33KBPS
            cfg1 = MCP_8MHz_33k3BPS_CFG1;
            cfg2 = MCP_8MHz_33k3BPS_CFG2;
            cfg3 = MCP_8MHz_33k3BPS_CFG3;
            break;
            case (CAN_40KBPS):                                              //  40Kbps
            cfg1 = MCP_8MHz_40kBPS_CFG1;
            cfg2 = MCP_8MHz_40kBPS_CFG2;
            cfg3 = MCP_8MHz_40kBPS_CFG3;
            break;
            case (CAN_50KBPS):                                              //  50Kbps
            cfg1 = MCP_8MHz_50kBPS_CFG1;
            cfg2 = MCP_8MHz_50kBPS_CFG2;
            cfg3 = MCP_8MHz_50kBPS_CFG3;
            break;
            case (CAN_80KBPS):                                              //  80Kbps
            cfg1 = MCP_8MHz_80kBPS_CFG1;
            cfg2 = MCP_8MHz_80kBPS_CFG2;
            cfg3 = MCP_8MHz_80kBPS_CFG3;
            break;
            case (CAN_100KBPS):                                             // 100Kbps
            cfg1 = MCP_8MHz_100kBPS_CFG1;
            cfg2 = MCP_8MHz_100kBPS_CFG2;
            cfg3 = MCP_8MHz_100kBPS_CFG3;
            break;
            case (CAN_125KBPS):                                             // 125Kbps
            cfg1 = MCP_8MHz_125kBPS_CFG1;
            cfg2 = MCP_8MHz_125kBPS_CFG2;
            cfg3 = MCP_8MHz_125kBPS_CFG3;
            break;
            case (CAN_200KBPS):                                             // 200Kbps
            cfg1 = MCP_8MHz_200kBPS_CFG1;
            cfg2 = MCP_8MHz_200kBPS_CFG2;
            cfg3 = MCP_8MHz_200kBPS_CFG3;
            break;
            case (CAN_250KBPS):                                             // 250Kbps
            cfg1 = MCP_8MHz_250kBPS_CFG1;
            cfg2 = MCP_8MHz_250kBPS_CFG2;
            cfg3 = MCP_8MHz_250kBPS_CFG3;
            break;
            case (CAN_500KBPS):                                             // 500Kbps
            cfg1 = MCP_8MHz_500kBPS_CFG1;
            cfg2 = MCP_8MHz_500kBPS_CFG2;
            cfg3 = MCP_8MHz_500kBPS_CFG3;
            break;
            case (CAN_1000KBPS):                                            //   1Mbps
            cfg1 = MCP_8MHz_1000kBPS_CFG1;
            cfg2 = MCP_8MHz_1000kBPS_CFG2;
            cfg3 = MCP_8MHz_1000kBPS_CFG3;
            break;
            default:
            set = 0;
            break;
        break;
        case (MCP_16MHZ):
        switch (canSpeed)
            case (CAN_5KBPS):                                               //   5Kbps
            cfg1 = MCP_16MHz_5kBPS_CFG1;
            cfg2 = MCP_16MHz_5kBPS_CFG2;
            cfg3 = MCP_16MHz_5kBPS_CFG3;
            break;
            case (CAN_10KBPS):                                              //  10Kbps
            cfg1 = MCP_16MHz_10kBPS_CFG1;
            cfg2 = MCP_16MHz_10kBPS_CFG2;
            cfg3 = MCP_16MHz_10kBPS_CFG3;
            break;
            case (CAN_20KBPS):                                              //  20Kbps
            cfg1 = MCP_16MHz_20kBPS_CFG1;
            cfg2 = MCP_16MHz_20kBPS_CFG2;
            cfg3 = MCP_16MHz_20kBPS_CFG3;
            break;
            case (CAN_33K3BPS):                                              //  20Kbps
            cfg1 = MCP_16MHz_33k3BPS_CFG1;
            cfg2 = MCP_16MHz_33k3BPS_CFG2;
            cfg3 = MCP_16MHz_33k3BPS_CFG3;
            break;
            cfg1 = MCP_16MHz_40kBPS_CFG1;
            cfg2 = MCP_16MHz_40kBPS_CFG2;
            cfg3 = MCP_16MHz_40kBPS_CFG3;
            break;
            cfg2 = MCP_16MHz_50kBPS_CFG2;
            cfg3 = MCP_16MHz_50kBPS_CFG3;
            break;
            cfg1 = MCP_16MHz_80kBPS_CFG1;
            cfg2 = MCP_16MHz_80kBPS_CFG2;
            cfg3 = MCP_16MHz_80kBPS_CFG3;
            break;
            cfg1 = MCP_16MHz_100kBPS_CFG1;
            cfg2 = MCP_16MHz_100kBPS_CFG2;
            cfg3 = MCP_16MHz_100kBPS_CFG3;
            break;
            cfg1 = MCP_16MHz_125kBPS_CFG1;
            cfg2 = MCP_16MHz_125kBPS_CFG2;
            cfg3 = MCP_16MHz_125kBPS_CFG3;
            break;
            cfg1 = MCP_16MHz_200kBPS_CFG1;
            cfg2 = MCP_16MHz_200kBPS_CFG2;
            cfg3 = MCP_16MHz_200kBPS_CFG3;
            break;
            cfg1 = MCP_16MHz_250kBPS_CFG1;
            cfg2 = MCP_16MHz_250kBPS_CFG2;
            cfg3 = MCP_16MHz_250kBPS_CFG3;
            break;
            cfg1 = MCP_16MHz_500kBPS_CFG1;
            cfg2 = MCP_16MHz_500kBPS_CFG2;
            cfg3 = MCP_16MHz_500kBPS_CFG3;
            break;
            cfg1 = MCP_16MHz_1000kBPS_CFG1;
            cfg2 = MCP_16MHz_1000kBPS_CFG2;
            cfg3 = MCP_16MHz_1000kBPS_CFG3;
            break;
            default:
            set = 0;
            break;
        break;
        case (MCP_20MHZ):
        switch (canSpeed)
            cfg1 = MCP_20MHz_40kBPS_CFG1;
            cfg2 = MCP_20MHz_40kBPS_CFG2;
            cfg3 = MCP_20MHz_40kBPS_CFG3;
            break;
            cfg1 = MCP_20MHz_50kBPS_CFG1;
            cfg2 = MCP_20MHz_50kBPS_CFG2;
            cfg3 = MCP_20MHz_50kBPS_CFG3;
            break;
            cfg1 = MCP_20MHz_80kBPS_CFG1;
            cfg2 = MCP_20MHz_80kBPS_CFG2;
            cfg3 = MCP_20MHz_80kBPS_CFG3;
            break;
            cfg1 = MCP_20MHz_100kBPS_CFG1;
            cfg2 = MCP_20MHz_100kBPS_CFG2;
            cfg3 = MCP_20MHz_100kBPS_CFG3;
            break;
            cfg1 = MCP_20MHz_125kBPS_CFG1;
            cfg2 = MCP_20MHz_125kBPS_CFG2;
            cfg3 = MCP_20MHz_125kBPS_CFG3;
            break;
            cfg1 = MCP_20MHz_200kBPS_CFG1;
            cfg2 = MCP_20MHz_200kBPS_CFG2;
            cfg3 = MCP_20MHz_200kBPS_CFG3;
            break;
            cfg1 = MCP_20MHz_250kBPS_CFG1;
            cfg2 = MCP_20MHz_250kBPS_CFG2;
            cfg3 = MCP_20MHz_250kBPS_CFG3;
            break;
            cfg1 = MCP_20MHz_500kBPS_CFG1;
            cfg2 = MCP_20MHz_500kBPS_CFG2;
            cfg3 = MCP_20MHz_500kBPS_CFG3;
            break;
            cfg1 = MCP_20MHz_1000kBPS_CFG1;
            cfg2 = MCP_20MHz_1000kBPS_CFG2;
            cfg3 = MCP_20MHz_1000kBPS_CFG3;
            break;
            default:
            set = 0;
            break;
        break;
        default:
        set = 0;
        break;
    if (canClock & MCP_CLKOUT_ENABLE) {
        cfg3 &= (~SOF_ENABLE);
    if (set) {
        mcp2515_setRegister(MCP_CNF1, cfg1);
        mcp2515_setRegister(MCP_CNF2, cfg2);
        mcp2515_setRegister(MCP_CNF3, cfg3);
        return MCP2515_OK;
** Function name:           mcp2515_initCANBuffers
** Descriptions:            Initialize Buffers, Masks, and Filters
void MCP_CAN::mcp2515_initCANBuffers(void)
    INT8U i, a1, a2, a3;
    INT8U std = 0;
    INT8U ext = 1;
    INT32U ulMask = 0x00, ulFilt = 0x00;
    mcp2515_write_mf(MCP_RXM0SIDH, ext, ulMask);			/*Set both masks to 0           */
    mcp2515_write_mf(MCP_RXM1SIDH, ext, ulMask);			/*Mask register ignores ext bit */
        /* Set all filters to 0         */
    mcp2515_write_mf(MCP_RXF0SIDH, ext, ulFilt);			/* RXB0: extended               */
    mcp2515_write_mf(MCP_RXF1SIDH, std, ulFilt);			/* RXB1: standard               */
    mcp2515_write_mf(MCP_RXF2SIDH, ext, ulFilt);			/* RXB2: extended               */
    mcp2515_write_mf(MCP_RXF3SIDH, std, ulFilt);			/* RXB3: standard               */
    mcp2515_write_mf(MCP_RXF4SIDH, ext, ulFilt);
    mcp2515_write_mf(MCP_RXF5SIDH, std, ulFilt);
        /* Clear, deactivate the three  */
        /* transmit buffers             */
        /* TXBnCTRL -> TXBnD7           */
    a1 = MCP_TXB0CTRL;
    a2 = MCP_TXB1CTRL;
    a3 = MCP_TXB2CTRL;
    for (i = 0; i < 14; i++) {                                          /* in-buffer loop               */
        mcp2515_setRegister(a1, 0);
        mcp2515_setRegister(a2, 0);
        mcp2515_setRegister(a3, 0);
        a1++;
        a2++;
        a3++;
    mcp2515_setRegister(MCP_RXB0CTRL, 0);
    mcp2515_setRegister(MCP_RXB1CTRL, 0);
** Descriptions:            Initialize the controller
INT8U MCP_CAN::mcp2515_init(const INT8U canIDMode, const INT8U canSpeed, const INT8U canClock)
  INT8U res;
    mcp2515_reset();
    mcpMode = MCP_LOOPBACK;
    res = mcp2515_setCANCTRL_Mode(MODE_CONFIG);
    if(res > 0)
#if DEBUG_MODE
      Serial.println(F("Entering Configuration Mode Failure..."));
      return res;
#if DEBUG_MODE
    Serial.println(F("Entering Configuration Mode Successful!"));
    // Set Baudrate
    if(mcp2515_configRate(canSpeed, canClock))
#if DEBUG_MODE
      Serial.println(F("Setting Baudrate Failure..."));
      return res;
#if DEBUG_MODE
    Serial.println(F("Setting Baudrate Successful!"));
    if ( res == MCP2515_OK ) {
        /* init canbuffers              */
        mcp2515_initCANBuffers();
        /* interrupt mode               */
        mcp2515_setRegister(MCP_CANINTE, MCP_RX0IF | MCP_RX1IF);
	//Sets BF pins as GPO
	mcp2515_setRegister(MCP_BFPCTRL,MCP_BxBFS_MASK | MCP_BxBFE_MASK);
	//Sets RTS pins as GPI
	mcp2515_setRegister(MCP_TXRTSCTRL,0x00);
        switch(canIDMode)
            case (MCP_ANY):
            mcp2515_modifyRegister(MCP_RXB0CTRL,
            MCP_RXB_RX_MASK | MCP_RXB_BUKT_MASK,
            MCP_RXB_RX_ANY | MCP_RXB_BUKT_MASK);
            mcp2515_modifyRegister(MCP_RXB1CTRL, MCP_RXB_RX_MASK,
            MCP_RXB_RX_ANY);
            break;
/*          The followingn two functions of the MCP2515 do not work, there is a bug in the silicon.
            case (MCP_STD):
            MCP_RXB_RX_STD | MCP_RXB_BUKT_MASK );
            MCP_RXB_RX_STD);
            break;
            case (MCP_EXT):
            MCP_RXB_RX_EXT | MCP_RXB_BUKT_MASK );
            MCP_RXB_RX_EXT);
            break;
            case (MCP_STDEXT):
            MCP_RXB_RX_STDEXT | MCP_RXB_BUKT_MASK );
            MCP_RXB_RX_STDEXT);
            break;
            default:
#if DEBUG_MODE
            Serial.println(F("`Setting ID Mode Failure..."));
            break;
        res = mcp2515_setCANCTRL_Mode(mcpMode);
        if(res)
#if DEBUG_MODE
          Serial.println(F("Returning to Previous Mode Failure..."));
          return res;
    return res;
** Function name:           mcp2515_write_id
** Descriptions:            Write CAN ID
void MCP_CAN::mcp2515_write_id( const INT8U mcp_addr, const INT8U ext, const INT32U id )
    uint16_t canid;
    INT8U tbufdata[4];
    canid = (uint16_t)(id & 0x0FFFF);
    if ( ext == 1)
        tbufdata[MCP_EID0] = (INT8U) (canid & 0xFF);
        tbufdata[MCP_EID8] = (INT8U) (canid >> 8);
        canid = (uint16_t)(id >> 16);
        tbufdata[MCP_SIDL] = (INT8U) (canid & 0x03);
        tbufdata[MCP_SIDL] += (INT8U) ((canid & 0x1C) << 3);
        tbufdata[MCP_SIDL] |= MCP_TXB_EXIDE_M;
        tbufdata[MCP_SIDH] = (INT8U) (canid >> 5 );
    else
        tbufdata[MCP_SIDH] = (INT8U) (canid >> 3 );
        tbufdata[MCP_SIDL] = (INT8U) ((canid & 0x07 ) << 5);
        tbufdata[MCP_EID0] = 0;
        tbufdata[MCP_EID8] = 0;
    mcp2515_setRegisterS( mcp_addr, tbufdata, 4 );
** Function name:           mcp2515_write_mf
** Descriptions:            Write Masks and Filters
void MCP_CAN::mcp2515_write_mf( const INT8U mcp_addr, const INT8U ext, const INT32U id )
    uint16_t canid;
    INT8U tbufdata[4];
    if ( ext == 1)
    else
        tbufdata[MCP_SIDL] = (INT8U) ((canid & 0x07) << 5);
** Function name:           mcp2515_read_id
** Descriptions:            Read CAN ID
void MCP_CAN::mcp2515_read_id( const INT8U mcp_addr, INT8U* ext, INT32U* id )
    INT8U tbufdata[4];
    *ext = 0;
    *id = 0;
    mcp2515_readRegisterS( mcp_addr, tbufdata, 4 );
    *id = (tbufdata[MCP_SIDH]<<3) + (tbufdata[MCP_SIDL]>>5);
    if ( (tbufdata[MCP_SIDL] & MCP_TXB_EXIDE_M) ==  MCP_TXB_EXIDE_M )
        /* extended id                  */
        *id = (*id<<2) + (tbufdata[MCP_SIDL] & 0x03);
        *id = (*id<<8) + tbufdata[MCP_EID8];
        *id = (*id<<8) + tbufdata[MCP_EID0];
        *ext = 1;
** Function name:           mcp2515_write_canMsg
** Descriptions:            Write message
void MCP_CAN::mcp2515_write_canMsg( const INT8U buffer_sidh_addr)
    INT8U mcp_addr;
    mcp_addr = buffer_sidh_addr;
    mcp2515_setRegisterS(mcp_addr+5, m_nDta, m_nDlc );                  /* write data bytes             */
    if ( m_nRtr == 1)                                                   /* if RTR set bit in byte       */
        m_nDlc |= MCP_RTR_MASK;
    mcp2515_setRegister((mcp_addr+4), m_nDlc );                         /* write the RTR and DLC        */
    mcp2515_write_id(mcp_addr, m_nExtFlg, m_nID );                      /* write CAN id                 */
** Function name:           mcp2515_read_canMsg
** Descriptions:            Read message
void MCP_CAN::mcp2515_read_canMsg( const INT8U buffer_sidh_addr)        /* read can msg                 */
    INT8U mcp_addr, ctrl;
    mcp2515_read_id( mcp_addr, &m_nExtFlg,&m_nID );
    ctrl = mcp2515_readRegister( mcp_addr-1 );
    m_nDlc = mcp2515_readRegister( mcp_addr+4 );
    if (ctrl & 0x08)
        m_nRtr = 1;
    else
        m_nRtr = 0;
    m_nDlc &= MCP_DLC_MASK;
    mcp2515_readRegisterS( mcp_addr+5, &(m_nDta[0]), m_nDlc );
** Function name:           mcp2515_getNextFreeTXBuf
** Descriptions:            Send message
INT8U MCP_CAN::mcp2515_getNextFreeTXBuf(INT8U *txbuf_n)                 /* get Next free txbuf          */
    INT8U res, i, ctrlval;
    INT8U ctrlregs[MCP_N_TXBUFFERS] = { MCP_TXB0CTRL, MCP_TXB1CTRL, MCP_TXB2CTRL };
    res = MCP_ALLTXBUSY;
    *txbuf_n = 0x00;
        /* check all 3 TX-Buffers       */
    for (i=0; i<MCP_N_TXBUFFERS; i++) {
        ctrlval = mcp2515_readRegister( ctrlregs[i] );
        if ( (ctrlval & MCP_TXB_TXREQ_M) == 0 ) {
            *txbuf_n = ctrlregs[i]+1;                                   /* return SIDH-address of Buffer*/
            res = MCP2515_OK;
            return res;                                                 /* ! function exit              */
    return res;
** Function name:           MCP_CAN
** Descriptions:            Public function to declare CAN class and the /CS pin.
MCP_CAN::MCP_CAN(INT8U _CS)
    MCPCS = _CS;
    MCP2515_UNSELECT();
    pinMode(MCPCS, OUTPUT);
** Function name:           begin
** Descriptions:            Public function to declare controller initialization parameters.
INT8U MCP_CAN::begin(INT8U idmodeset, INT8U speedset, INT8U clockset)
    INT8U res;
    SPI.begin();
    res = mcp2515_init(idmodeset, speedset, clockset);
    if (res == MCP2515_OK)
        return CAN_OK;
    return CAN_FAILINIT;
** Function name:           init_Mask
** Descriptions:            Public function to set mask(s).
INT8U MCP_CAN::init_Mask(INT8U num, INT8U ext, INT32U ulData)
    INT8U res = MCP2515_OK;
#if DEBUG_MODE
    Serial.println(F("Starting to Set Mask!"));
    if(res > 0){
#if DEBUG_MODE
	return res;
    if (num == 0){
        mcp2515_write_mf(MCP_RXM0SIDH, ext, ulData);
    else if(num == 1){
        mcp2515_write_mf(MCP_RXM1SIDH, ext, ulData);
    else res =  MCP2515_FAIL;
    if(res > 0){
#if DEBUG_MODE
    Serial.println(F("Entering Previous Mode Failure..."));
	Serial.println(F("Setting Mask Failure..."));
	return res;
#if DEBUG_MODE
    Serial.println(F("Setting Mask Successful!"));
    return res;
INT8U MCP_CAN::init_Mask(INT8U num, INT32U ulData)
    INT8U ext = 0;
#if DEBUG_MODE
    if(res > 0){
#if DEBUG_MODE
  return res;
    if((ulData & 0x80000000) == 0x80000000)
        ext = 1;
    if (num == 0){
    else if(num == 1){
    if(res > 0){
#if DEBUG_MODE
    return res;
#if DEBUG_MODE
    return res;
** Function name:           init_Filt
** Descriptions:            Public function to set filter(s).
INT8U MCP_CAN::init_Filt(INT8U num, INT8U ext, INT32U ulData)
#if DEBUG_MODE
    Serial.println(F("Starting to Set Filter!"));
    if(res > 0)
#if DEBUG_MODE
      Serial.println(F("Enter Configuration Mode Failure..."));
      return res;
    switch( num )
        case 0:
        mcp2515_write_mf(MCP_RXF0SIDH, ext, ulData);
        break;
        case 1:
        mcp2515_write_mf(MCP_RXF1SIDH, ext, ulData);
        break;
        case 2:
        mcp2515_write_mf(MCP_RXF2SIDH, ext, ulData);
        break;
        case 3:
        mcp2515_write_mf(MCP_RXF3SIDH, ext, ulData);
        break;
        case 4:
        mcp2515_write_mf(MCP_RXF4SIDH, ext, ulData);
        break;
        case 5:
        mcp2515_write_mf(MCP_RXF5SIDH, ext, ulData);
        break;
        default:
        res = MCP2515_FAIL;
    if(res > 0)
#if DEBUG_MODE
	Serial.println(F("Setting Filter Failure..."));
      return res;
#if DEBUG_MODE
    Serial.println(F("Setting Filter Successful!"));
    return res;
INT8U MCP_CAN::init_Filt(INT8U num, INT32U ulData)
    INT8U ext = 0;
#if DEBUG_MODE
    if(res > 0)
#if DEBUG_MODE
      return res;
        ext = 1;
    switch( num )
        case 0:
        break;
        case 1:
        break;
        case 2:
        break;
        case 3:
        break;
        case 4:
        break;
        case 5:
        break;
        default:
        res = MCP2515_FAIL;
    if(res > 0)
#if DEBUG_MODE
      return res;
#if DEBUG_MODE
    return res;
** Function name:           setMsg
** Descriptions:            Set can message, such as dlc, id, dta[] and so on
INT8U MCP_CAN::setMsg(INT32U id, INT8U rtr, INT8U ext, INT8U len, INT8U *pData)
    int i = 0;
    m_nID     = id;
    m_nRtr    = rtr;
    m_nExtFlg = ext;
    m_nDlc    = len;
    for(i = 0; i<MAX_CHAR_IN_MESSAGE; i++)
        m_nDta[i] = *(pData+i);
    return MCP2515_OK;
** Function name:           clearMsg
** Descriptions:            Set all messages to zero
INT8U MCP_CAN::clearMsg()
    m_nID       = 0;
    m_nDlc      = 0;
    m_nExtFlg   = 0;
    m_nRtr      = 0;
    m_nfilhit   = 0;
    for(int i = 0; i<m_nDlc; i++ )
      m_nDta[i] = 0x00;
    return MCP2515_OK;
** Function name:           sendMsg
INT8U MCP_CAN::sendMsg()
    INT8U res, res1, txbuf_n;
    uint32_t uiTimeOut, temp;
    temp = micros();
    // 24 * 4 microseconds typical
    do {
        res = mcp2515_getNextFreeTXBuf(&txbuf_n);                       /* info = addr.                 */
        uiTimeOut = micros() - temp;
    } while (res == MCP_ALLTXBUSY && (uiTimeOut < TIMEOUTVALUE));
    if(uiTimeOut >= TIMEOUTVALUE)
        return CAN_GETTXBFTIMEOUT;                                      /* get tx buff time out         */
    uiTimeOut = 0;
    mcp2515_write_canMsg( txbuf_n);
    mcp2515_modifyRegister( txbuf_n-1 , MCP_TXB_TXREQ_M, MCP_TXB_TXREQ_M );
    temp = micros();
    do
        res1 = mcp2515_readRegister(txbuf_n-1);                         /* read send buff ctrl reg 	*/
        res1 = res1 & 0x08;
    } while (res1 && (uiTimeOut < TIMEOUTVALUE));
    if(uiTimeOut >= TIMEOUTVALUE)                                       /* send msg timeout             */
        return CAN_SENDMSGTIMEOUT;
    return CAN_OK;
** Function name:           sendMsgBuf
** Descriptions:            Send message to transmitt buffer
INT8U MCP_CAN::sendMsgBuf(INT32U id, INT8U ext, INT8U len, INT8U *buf)
    INT8U res;
    setMsg(id, 0, ext, len, buf);
    res = sendMsg();
    return res;
INT8U MCP_CAN::sendMsgBuf(INT32U id, INT8U len, INT8U *buf)
    INT8U ext = 0, rtr = 0;
    INT8U res;
    if((id & 0x80000000) == 0x80000000)
        ext = 1;
    if((id & 0x40000000) == 0x40000000)
        rtr = 1;
    setMsg(id, rtr, ext, len, buf);
    res = sendMsg();
    return res;
** Function name:           readMsg
INT8U MCP_CAN::readMsg()
    INT8U stat, res;
    stat = mcp2515_readStatus();
    if ( stat & MCP_STAT_RX0IF )                                        /* Msg in Buffer 0              */
        mcp2515_read_canMsg( MCP_RXBUF_0);
        mcp2515_modifyRegister(MCP_CANINTF, MCP_RX0IF, 0);
        res = CAN_OK;
    else if ( stat & MCP_STAT_RX1IF )                                   /* Msg in Buffer 1              */
        mcp2515_read_canMsg( MCP_RXBUF_1);
        mcp2515_modifyRegister(MCP_CANINTF, MCP_RX1IF, 0);
        res = CAN_OK;
    else
        res = CAN_NOMSG;
    return res;
** Function name:           readMsgBuf
** Descriptions:            Public function, Reads message from receive buffer.
INT8U MCP_CAN::readMsgBuf(INT32U *id, INT8U *ext, INT8U *len, INT8U buf[])
    if(readMsg() == CAN_NOMSG)
	return CAN_NOMSG;
    *id  = m_nID;
    *len = m_nDlc;
    *ext = m_nExtFlg;
    for(int i = 0; i<m_nDlc; i++)
        buf[i] = m_nDta[i];
    return CAN_OK;
INT8U MCP_CAN::readMsgBuf(INT32U *id, INT8U *len, INT8U buf[])
	return CAN_NOMSG;
    if (m_nExtFlg)
        m_nID |= 0x80000000;
    if (m_nRtr)
        m_nID |= 0x40000000;
    *id  = m_nID;
    *len = m_nDlc;
        buf[i] = m_nDta[i];
    return CAN_OK;
** Function name:           checkReceive
** Descriptions:            Public function, Checks for received data.  (Used if not using the interrupt output)
INT8U MCP_CAN::checkReceive(void)
    INT8U res;
    res = mcp2515_readStatus();                                         /* RXnIF in Bit 1 and 0         */
    if ( res & MCP_STAT_RXIF_MASK )
        return CAN_MSGAVAIL;
    else
        return CAN_NOMSG;
** Function name:           checkError
** Descriptions:            Public function, Returns error register data.
INT8U MCP_CAN::checkError(void)
    INT8U eflg = mcp2515_readRegister(MCP_EFLG);
    if ( eflg & MCP_EFLG_ERRORMASK )
        return CAN_CTRLERROR;
    else
        return CAN_OK;
** Function name:           getError
** Descriptions:            Returns error register value.
INT8U MCP_CAN::getError(void)
    return mcp2515_readRegister(MCP_EFLG);
** Function name:           mcp2515_errorCountRX
** Descriptions:            Returns REC register value
INT8U MCP_CAN::errorCountRX(void)
    return mcp2515_readRegister(MCP_REC);
** Function name:           mcp2515_errorCountTX
** Descriptions:            Returns TEC register value
INT8U MCP_CAN::errorCountTX(void)
    return mcp2515_readRegister(MCP_TEC);
** Function name:           mcp2515_enOneShotTX
** Descriptions:            Enables one shot transmission mode
INT8U MCP_CAN::enOneShotTX(void)
    mcp2515_modifyRegister(MCP_CANCTRL, MODE_ONESHOT, MODE_ONESHOT);
    if((mcp2515_readRegister(MCP_CANCTRL) & MODE_ONESHOT) != MODE_ONESHOT)
	    return CAN_FAIL;
    else
	    return CAN_OK;
** Function name:           mcp2515_disOneShotTX
** Descriptions:            Disables one shot transmission mode
INT8U MCP_CAN::disOneShotTX(void)
    mcp2515_modifyRegister(MCP_CANCTRL, MODE_ONESHOT, 0);
    if((mcp2515_readRegister(MCP_CANCTRL) & MODE_ONESHOT) != 0)
        return CAN_FAIL;
    else
        return CAN_OK;
** Function name:           mcp2515_abortTX
** Descriptions:            Aborts any queued transmissions
INT8U MCP_CAN::abortTX(void)
    mcp2515_modifyRegister(MCP_CANCTRL, ABORT_TX, ABORT_TX);
    // Maybe check to see if the TX buffer transmission request bits are cleared instead?
    if((mcp2515_readRegister(MCP_CANCTRL) & ABORT_TX) != ABORT_TX)
	    return CAN_FAIL;
    else
	    return CAN_OK;
** Function name:           setGPO
INT8U MCP_CAN::setGPO(INT8U data)
    mcp2515_modifyRegister(MCP_BFPCTRL, MCP_BxBFS_MASK, (data<<4));
    return 0;
** Function name:           getGPI
INT8U MCP_CAN::getGPI(void)
    INT8U res;
    res = mcp2515_readRegister(MCP_TXRTSCTRL) & MCP_BxRTS_MASK;
    return (res >> 3);
  END FILE
here is a suggestion
copy the library files *.h, *.cpp, *.c into your sketch folder.
make an include say
mysketch.h
#include <SPI.h>
#ifndef _MYSKETCH_H
#define _MYSKETCH_H
extern SPIClass SPI_2;
then in your .ino skech you need to #include "mysketch.h"
and declare in the global variables
//            MOSI  MISO  SCLK
SPIClass SPI_2(PB15, PB14, PB13);
similarly #include "mysketch.h" the same in
mcp_can.h and mcp_can.cpp
and not least, in mcp_can.h and mcp_can.cpp
change the references for SPI to SPI_2, simply replace them all.
arun
Post by arun »
i got this error code
Arduino: 1.8.19 (Windows Store 1.8.57.0) (Windows 10), Board: "Generic STM32F103C series, STM32F103C8 (20k RAM. 64k Flash), STLink, 72Mhz (Normal), Smallest (default)"
cans:16:32: error: no matching function for call to 'SPIClass::SPIClass(<anonymous enum>, <anonymous enum>, <anonymous enum>)'
C:\Users\Arunsaravana\Documents\Arduino\cans\cans.ino:16:32: note: candidates are:
In file included from C:\Users\Arunsaravana\Documents\Arduino\cans\arun.h:1:0,
                 from C:\Users\Arunsaravana\Documents\Arduino\cans\cans.ino:10:
C:\Users\Arunsaravana\Documents\ArduinoData\packages\stm32duino\hardware\STM32F1\2021.5.31\libraries\SPI\src/SPI.h:176:5: note: SPIClass::SPIClass(uint32)
     SPIClass(uint32 spiPortNumber);
C:\Users\Arunsaravana\Documents\ArduinoData\packages\stm32duino\hardware\STM32F1\2021.5.31\libraries\SPI\src/SPI.h:176:5: note:   candidate expects 1 argument, 3 provided
C:\Users\Arunsaravana\Documents\ArduinoData\packages\stm32duino\hardware\STM32F1\2021.5.31\libraries\SPI\src/SPI.h:170:7: note: constexpr SPIClass::SPIClass(const SPIClass&)
 class SPIClass {
C:\Users\Arunsaravana\Documents\ArduinoData\packages\stm32duino\hardware\STM32F1\2021.5.31\libraries\SPI\src/SPI.h:170:7: note:   candidate expects 1 argument, 3 provided
C:\Users\Arunsaravana\Documents\ArduinoData\packages\stm32duino\hardware\STM32F1\2021.5.31\libraries\SPI\src/SPI.h:170:7: note: constexpr SPIClass::SPIClass(SPIClass&&)
exit status 1
