USB enumeration not working with custom F103C8 board
axel
Post by axel »
Hello
I am trying to configure a custom board to use Roger's bootloader. I've confirmed the USB hardware works with a sketch uploaded directly to the board via STLink, however I've been unable to properly configure the bootloader to enumerate. The bootloader does appear to run fine (fast flashing LED followed by a slower flash) but nothing appears in device manager which leads me to believe there's something wrong with the USB enumeration code.
I have pin PB15 configured as an enumeration pin, connected to USB D+ via a 1.5kΩ resistor:
And I have configured an entry in the bootloader makefile for my hardware configuration:
#elif defined TARGET_DEKO32
    Status LED on PC13
    USB ENUM pin PB15
    No user button
    #define HAS_MAPLE_HARDWARE  1
    #define LED_BANK            GPIOC
    #define LED_PIN             13
    #define LED_ON_STATE        1
    #define USB_DISC_BANK       GPIOB
    #define USB_DISC_PIN        15
In theory this should be all that's needed to get the bootloader to work - but other than the LED flashing correctly the USB interface appears to be totally non-functional. Does anyone know what could be wrong?
Re: USB enumeration not working with custom F103C8 board
USB enumeration is triggered by a *usb reset*
which is a single-ended-zero (i.e. both d- d+ low ) > 2.5 uS
https://www.engineersgarage.com/signal- ... -part-5-6/
many times when things don't work, it could be a defective usb cable (more common)
to proof if it is after all enumerating, i.e. that usb reset works
in linux it is usbreset
in windows, it is to disable and enable the usb device in device manager.
doing this alone will start the host doing probe and enumeration.
and if this don't work, check / change the cables.
the old maple mini, has a transistor circuit at d+ / d- purposely to set them low to trigger a usb-reset
https://github.com/leaflabs/maplemini/b ... lemini.pdf
and USB D+ is PA12 and USB D- is PA11
that is different on your schematic
axel
Post by axel »
Apologies, I should've been more clear with that schematic - the A/B6/7 pins are on the USB-C connector, not the STM32
Regardless, I switched to the stm32-tkg-hid-bootloader using the same defines as I posted above, and it's working perfectly fine with my custom board.
ahsrabrifat
Post by ahsrabrifat »
axel wrote: Sat Jun 21, 2025 1:33 am Hello
    Status LED on PC13
    USB ENUM pin PB15
    No user button
    #define LED_PIN             13
In theory, this should be all that's needed to get the bootloader to work - but other than the LED flashing correctly, the USB interface appears to be non-functional. Does anyone know what could be wrong?
You may have simply connected a fixed 1.5kΩ pull-up to D+, or you're not toggling the pin correctly. Here's what to verify:
PB15 should be in open-drain mode, pulled low to disconnect USB, and high-Z (input or high) to connect it.
The bootloader toggles this pin at runtime, so check if PB15 is actually physically disconnecting and reconnecting D+.
Oscilloscope/logic analyzer on D+ during boot will confirm this.
Return to “USB bootloader”
