ag123 wrote: Tue Mar 17, 2020 4:46 pmrun the examples
yes, I ran an example. I was able to easily replace the displayed text, its color and position in the example. However, when I try to modify the code called in the example like this
Serial.println(testLines(ILI9341_CYAN));
unsigned long testLines(uint16_t color) {
unsigned long start, t;
int x1, y1, x2, y2,
w = tft.width(),
h = tft.height();
tft.fillScreen(ILI9341_BLACK);
yield();
x1 = y1 = 0;
y2 = h - 1;
start = micros();
for(x2=0; x2<w; x2+=6) tft.drawLine(x1, y1, x2, y2, color);
x2 = w - 1;
for(y2=0; y2<h; y2+=6) tft.drawLine(x1, y1, x2, y2, color);
t = micros() - start; // fillScreen doesn't count against timing
yield();
yield();
x1 = w - 1;
y1 = 0;
y2 = h - 1;
start = micros();
x2 = 0;
t += micros() - start;
yield();
yield();
x1 = 0;
y1 = h - 1;
y2 = 0;
start = micros();
x2 = w - 1;
yield();
yield();
x1 = w - 1;
y1 = h - 1;
y2 = 0;
start = micros();
x2 = 0;
yield();
return micros() - start;
To get started, I wanted to change the calculation of coordinates here. But when you try to change at least something related to tft.drawLine () in this code, the compiler gives a lot of errors.
(there was a power failure, so I lost this part of the code. I will continue today, so I will quickly give an example of my code modification and copy the compiler errors)
maybe there is some kind of documentation like this:
https://github.com/dgolda/UTFT/blob/master/UTFT.pdf
