Searching code on Github (web)
Anything not related to STM32
a stupid question: is anyone aware how to search for source code on Github (web)?
It seems that Github can only find exact words (case insensitive), or terms including the searched query extended with "_" (underscore).
Partial matches are not detected. Is that right?
For example, I want to find all words containing the term "debug" in a specific repository.
If I only enter "debug", then "debugPorts" is not found, but "debug_port" is found.
What should I enter in the search field in order to also find "debugPorts"?
BennehBoy
Re: Searching code on Github (web)
Post by BennehBoy »
Have you tried standard match all operators such as %? Not something I've tried btw.
I got several times the same issue than you.
And it seems not possible to find using a pattern.
You can try using this:
https://github.com/search/advanced
Here the consideration for search with all the restrictions:
https://help.github.com/en/github/searc ... ode-search
Thanks Frederic, I have already read all those links and many more, but none of them provided answers to my issue.
That is why posted here in the hope that some has a solution.
But it seems that the usage of match operators is not supported, so I think we have to live with this restriction.
stevestrong wrote: Thu Mar 26, 2020 2:01 pm But it seems that the usage of match operators is not supported, so I think we have to live with this restriction.
Right. :roll:
ahull
Post by ahull »
Can you use Google or some other search engine to do what you need?
For example put this in google..
TFT.print(" STM-O-Scope by Andy Hull") ; site:github.com
... and you will see all of the instances of that string on the whole of github.
Modify it to
TFT.print(" STM-O-Scope by Andy Hull") ; site:github.com/pingumacpenguin/STM32-O-Scope +commit
And you will only see the commit in my repo.
Andy, the problem is with the incomplete word search.
You cannot search only for
it will be not found.
ahull
Post by ahull »
You could try duckduckgo instead, it does produce results for that search term.
https://duckduckgo.com
Enter the search you mentioned.
TFT.print(" STM-O-Sco site:github.com/pingumacpenguin/STM32-O-Scope
This expands to the following in the search URL
https://duckduckgo.com/?q=TFT.print(%22+STM-O-Sco+site%3Agithub.com%2Fpingumacpenguin%2FSTM32-O-Scope&t=canonical&atb=v192-1&ia=web
.. which produce stuff. Whether these are the droids you are looking for I don't know.
ahull
Post by ahull »
.. better still, duckduckgo supports Unix style string escaping, so try this string
"TFT.print(\" STM-O-Sco" site:github.com/pingumacpenguin/STM32-O-Scope
Note the "Escaped" double quote in the string.
Thanks, it looks much better with duckuck, but it is still not perfect.
I do not see directly the line where the text occurs. Of course the additional CTRL+F on the page helps further.
But: why do I get results from Bodmer's repo when I search the whole github?
Return to “Off topic”
