Arduino IDe upload verbose parameters
Answers: 8
does someone know which parameters can be used as upload.verbose in platform.txt and what is their effect?
In the platform specification I could only find few lines but they do not answer my question.
My problem is that even if i checked the verbose by upload option in Adruino preferences, the std outputs generated during upload are only printed in one piece, after the upload process finished.
Is it possible to get all upload std output lines one by one at the time they are generated displayed in Arduino message window? If yes, how?
by stas2z » Fri May 08, 2020 10:40 am
if your uploader is written on c/c++, try to use setbuf(stdout, NULL) before first printf
it will prevent stdout buffering
Re: Arduino IDe upload verbose parameters
stevestrong wrote: Thu May 07, 2020 9:11 pm
I don't know how it is managed anyway for some upload methid it seems output line by line.
For example when upload has a text progress bar.
Which upload method you want output?
I guess for your bootloader?
How do you print your message? On which stdio?
Answers: 8
Yes, that is for my CDC bootloader.
I use normal printf. Isn't that right?
What do you mean under "which stdio"?
What should I use instead?
Stderr, stdout.
Do you end with "\n"?
I don't remember but maybe you can force a flush
stas2z
Answers: 8
Post by stas2z »
Answers: 8
I use Eclipse and MinGW for the development. There is no stdout.h
Of course I use \n when needed.
It works correctly when executed in a CMD window.
Only Arduino IDE message window is not updating the outputs in real time.
stas2z
Answers: 8
Post by stas2z »
stevestrong wrote: Fri May 08, 2020 10:41 am I use Eclipse and MinGW for the development. There is no stdout.h
no) stdout and stderr are posix output streams, probably for mingw it will not make any sense, by default printf should output to stdout
Answers: 8
I also tried fprintf(stderr, ...) but no chance, the same effect.
For example, output in CMD in real time:
Trying to reset port COM22 or find bootloader on [1eaf:0002]
 ERROR: Could not establish communication with the device. Giving up.
vs output in Arduino (at the end of process):
This has inverted output and doubled last line...
stas2z
Answers: 8
Post by stas2z »
Try setbuf, if it will not work, the only way is to modify ide to prevent console buffering there
Answers: 8
I just tried setbuf, no improvement.
Return to “IDE's”
