STM32F10x light HID driverless bootloader supporting HD devices
What are you developing?
Re: STM32F10x light HID driverless bootloader supporting HD devices
TheKikGen wrote: Sun May 03, 2020 11:07 am My first approach was quite similar with HID, but you must first shutdown USB,...
That happens fast.
TheKikGen wrote: Sun May 03, 2020 11:07 am ... wait more or less 4 seconds
Nop. Why to wait?
In my approach I simply toggle the USB_DP line from 1->0->1. That is enough to signalize the host USB that a change occurred on the line.
The re-enumeration is performed within less than one second from both directions (user app-> bootloader -> user app).
For that the user app (core) should also have the same toggling method.
TheKikGen
Post by TheKikGen »
Thanks Steve. I will give a try to that...
Other subject :
I have added a new "page offset" option in TKG-Flash CLI. This allows to flash a bin firmware file from any bootloader at the right address.
The stm32duino bootloader flash at FLASH BASE+ 0x2000, last version of HID bootloader flash at +0x800, older version of HID booloader flash at 0x1000, etc... When you need to upload a bin file compiled and linked to a specific address with a different bootloader, most of the time, you will recompile the firmware. Not this time maybe ?
With that "-o" option, you add some pages to the usual start page (@FLASH BASE + 0x1000 also for a 4k bootloader size) to match the bin file original address. The booloader will flash at the offset required, but will also write the MSP / Reset handler in its first "user" page, so the vector table will be valid.
Ex : myfirmware.bin was compiled to be uploaded with the stm32duino bootloader, at @FLASH BASE + 0x2000 but my bootloader flash at 0x1000.
With a medium density Bluepill, the page size is 0x400 bytes. So I need to offset (0x2000- 0x1000) / 0x400 pages=> 4 pages.
$tkg-flash myfirmare.bin -o=4
Will do the adjustment, and will launch the firmware at the right address.
Btw, how do you do the progress bar for upload?
It seems that Arduino IDE message window only shows all printf-s from the flasher std output in one piece after the whole upload is done.
Don't you have the same problem?
Do you know a way to force the message window to be updated after each printf ?
TheKikGen
Post by TheKikGen »
Hi Steve. The IDE pseudo compilation console doesn't display correctly (as the IDE Terminal) most of C escape characters (e.g. \r).
So not possible to show a nice progression bar. The "-ide" option of tkg-flash shows consecutive characters on the same line instead.
Command line :
|            TKG-Flash v2.3 STM32F103 HID Bootloader Flash Tool         |
|                     High density device support.                      |
|       (c) 2020 - The KikGen Labs     https://github.com/TheKikGen     |
> Firmware file size is 49796 bytes.
> Searching for [1209:BEBA] HID device...|
> [1209:BEBA] HID device found !
> Flashing firmware (SIMULATION) (INFO) :
  INFO - Informations reported by the MCU :
      Flash memory size  : 128 K (medium density device)
      Page size          : 1024 bytes
      Flash base address : 0x8001000
  [--------------------------------------------->       ]   50176 bytes sent.
> Firmware flashing done !
  49 sectors written (SIMULATION).
> End of firmware update.
in the IDE with the -ide option :
$ ./tkg-flash umk-103c8-small-1000.bin -p=COM8 -sim -info  -ide
  50176 bytes sent.
Well, actually it is possible to display a progression bar, and \n is also shown correctly by Arduino IDE message window.
All I had to do is insert the line
setbuf(stdout, NULL);
before the first printf() and it did the job (see viewtopic.php?p=2622#p2622).
TheKikGen
Post by TheKikGen »
I already have this in my code. The \r is not usable at all.
True, but why would you use \r at all?
TheKikGen
Post by TheKikGen »
I use \r to animate the progression bar.
I just published the first release with binaries for Windows and Linux ready to use here :
https://github.com/TheKikGen/stm32-tkg- ... s/tag/V2.3
If anyone want to test it !
Return to “Projects”
