Then you have to check what exactly is your application doing. Did you try with a simple blinky sketch?sankarAMP2 wrote: ↑Sat Jun 06, 2020 3:36 amI've made changes there but its not working from my custom location.
Need to change Vector table Address
- Contact:
Re: Need to change Vector table Address
Yes I am trying with blink example only.
sorry If it is a silly question but I don't know core level work,
In keil I just changed only IROM1 address, it directly took as flash base address and compiled and runs fine. but in arduino we have to change in different files like boards.txt, flash.ld, stm32f103re.ld ...
I am trying to understand build process I am not getting what is going on? please help me.
- Contact:
You only need to change one linker file, the one which is actually used.
And the boards.txt for VECT_TAB address.
This should not cause any headache...
Your problem is that you have two sw parts which both can be erroneous, and you don't know which one is causing the trouble.
First you have to make sure that the bootloader works as expected and flashes the sw from SD card to the right place.
Then you go one step further and check whether Arduino has built the application with the right offset.
Post here the Arduino build message (with verbose turned on).
Yes my bootloader is doing well it is taking .bin file from sd and storing to right location. I have verified by seeing in st link utility. Works well when I generated 2nd application in keil.stevestrong wrote: ↑Sat Jun 06, 2020 10:04 amFirst you have to make sure that the bootloader works as expected and flashes the sw from SD card to the right place.
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\AMP_SAI\AppData\Local\Arduino15\packages -hardware C:\Users\AMP_SAI\Documents\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\AMP_SAI\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\AMP_SAI\Documents\Arduino\libraries -fqbn=Arduino_STM32-master:STM32F1:genericSTM32F103R:device_variant=STM32F103RE,upload_method=STLinkMethod,cpu_speed=speed_72mhz,opt=osstd -vid-pid=10C4_EA60 -ide-version=10811 -build-path C:\Users\AMP_SAI\Desktop\hexfile -warnings=none -build-cache C:\Users\AMP_SAI\AppData\Local\Temp\arduino_cache_727569 -prefs=build.warn_data_percentage=75 -verbose C:\Users\AMP_SAI\Desktop\usermks\usermks.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\AMP_SAI\AppData\Local\Arduino15\packages -hardware C:\Users\AMP_SAI\Documents\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\AMP_SAI\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\AMP_SAI\Documents\Arduino\libraries -fqbn=Arduino_STM32-master:STM32F1:genericSTM32F103R:device_variant=STM32F103RE,upload_method=STLinkMethod,cpu_speed=speed_72mhz,opt=osstd -vid-pid=10C4_EA60 -ide-version=10811 -build-path C:\Users\AMP_SAI\Desktop\hexfile -warnings=none -build-cache C:\Users\AMP_SAI\AppData\Local\Temp\arduino_cache_727569 -prefs=build.warn_data_percentage=75 -verbose C:\Users\AMP_SAI\Desktop\usermks\usermks.ino
Using board 'genericSTM32F103R' from platform in folder: C:\Users\AMP_SAI\Documents\Arduino\hardware\Arduino_STM32-master\STM32F1
Using core 'maple' from platform in folder: C:\Users\AMP_SAI\Documents\Arduino\hardware\Arduino_STM32-master\STM32F1
Warning: platform.txt from core 'STM32 Boards (STM32duino.com)' contains deprecated recipe.ar.pattern="{compiler.path}{compiler.ar.cmd}" {compiler.ar.flags} {compiler.ar.extra_flags} "{build.path}/{archive_file}" "{object_file}", automatically converted to recipe.ar.pattern="{compiler.path}{compiler.ar.cmd}" {compiler.ar.flags} {compiler.ar.extra_flags} "{archive_file_path}" "{object_file}". Consider upgrading this core.
Detecting libraries used...
"C:\\Users\\AMP_SAI\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-g++" -c -g -Os -w -DDEBUG_LEVEL=DEBUG_NONE -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -DBOARD_generic_stm32f103r -DVECT_TAB_ADDR=0x8010000 -DERROR_LED_PORT=GPIOB -DERROR_LED_PIN=1 -w -x c++ -E -CC -mcpu=cortex-m3 -DF_CPU=72000000L -DARDUINO=10811 -DARDUINO_GENERIC_STM32F103R -DARDUINO_ARCH_STM32F1 -DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1 -DSERIAL_USB -DGENERIC_BOOTLOADER -DMCU_STM32F103RE -mthumb -march=armv7-m -D__STM32F1__ -DMCU_STM32F103RE -mthumb -march=armv7-m -D__STM32F1__ "-IC:\\Users\\AMP_SAI\\Documents\\Arduino\\hardware\\Arduino_STM32-master\\STM32F1\\system/libmaple" "-IC:\\Users\\AMP_SAI\\Documents\\Arduino\\hardware\\Arduino_STM32-master\\STM32F1\\system/libmaple/include" "-IC:\\Users\\AMP_SAI\\Documents\\Arduino\\hardware\\Arduino_STM32-master\\STM32F1\\system/libmaple/stm32f1/include" "-IC:\\Users\\AMP_SAI\\Documents\\Arduino\\hardware\\Arduino_STM32-master\\STM32F1\\system/libmaple/usb/stm32f1" "-IC:\\Users\\AMP_SAI\\Documents\\Arduino\\hardware\\Arduino_STM32-master\\STM32F1\\system/libmaple/usb/usb_lib" "-IC:\\Users\\AMP_SAI\\Documents\\Arduino\\hardware\\Arduino_STM32-master\\STM32F1\\cores\\maple" "-IC:\\Users\\AMP_SAI\\Documents\\Arduino\\hardware\\Arduino_STM32-master\\STM32F1\\variants\\generic_stm32f103r" "C:\\Users\\AMP_SAI\\Desktop\\hexfile\\sketch\\usermks.ino.cpp" -o nul
"C:\\Users\\AMP_SAI\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-g++" -c -g -Os -w -DDEBUG_LEVEL=DEBUG_NONE -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -DBOARD_generic_stm32f103r -DVECT_TAB_ADDR=0x8010000 -DERROR_LED_PORT=GPIOB -DERROR_LED_PIN=1 -w -x c++ -E -CC -mcpu=cortex-m3 -DF_CPU=72000000L -DARDUINO=10811 -DARDUINO_GENERIC_STM32F103R -DARDUINO_ARCH_STM32F1 -DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1 -DSERIAL_USB -DGENERIC_BOOTLOADER -DMCU_STM32F103RE -mthumb -march=armv7-m -D__STM32F1__ -DMCU_STM32F103RE -mthumb -march=armv7-m -D__STM32F1__ "-IC:\\Users\\AMP_SAI\\Documents\\Arduino\\hardware\\Arduino_STM32-master\\STM32F1\\system/libmaple" "-IC:\\Users\\AMP_SAI\\Documents\\Arduino\\hardware\\Arduino_STM32-master\\STM32F1\\system/libmaple/include" "-IC:\\Users\\AMP_SAI\\Documents\\Arduino\\hardware\\Arduino_STM32-master\\STM32F1\\system/libmaple/stm32f1/include" "-IC:\\Users\\AMP_SAI\\Documents\\Arduino\\hardware\\Arduino_STM32-master\\STM32F1\\system/libmaple/usb/stm32f1" "-IC:\\Users\\AMP_SAI\\Documents\\Arduino\\hardware\\Arduino_STM32-master\\STM32F1\\system/libmaple/usb/usb_lib" "-IC:\\Users\\AMP_SAI\\Documents\\Arduino\\hardware\\Arduino_STM32-master\\STM32F1\\cores\\maple" "-IC:\\Users\\AMP_SAI\\Documents\\Arduino\\hardware\\Arduino_STM32-master\\STM32F1\\variants\\generic_stm32f103r" "C:\\Users\\AMP_SAI\\Desktop\\hexfile\\sketch\\usermks.ino.cpp" -o "C:\\Users\\AMP_SAI\\Desktop\\hexfile\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\Program Files (x86)\\Arduino\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\AMP_SAI\\Desktop\\hexfile\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Users\\AMP_SAI\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-g++" -c -g -Os -w -DDEBUG_LEVEL=DEBUG_NONE -MMD -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -DBOARD_generic_stm32f103r -DVECT_TAB_ADDR=0x8010000 -DERROR_LED_PORT=GPIOB -DERROR_LED_PIN=1 -mcpu=cortex-m3 -DF_CPU=72000000L -DARDUINO=10811 -DARDUINO_GENERIC_STM32F103R -DARDUINO_ARCH_STM32F1 -DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1 -DSERIAL_USB -DGENERIC_BOOTLOADER -DMCU_STM32F103RE -mthumb -march=armv7-m -D__STM32F1__ -DMCU_STM32F103RE -mthumb -march=armv7-m -D__STM32F1__ "-IC:\\Users\\AMP_SAI\\Documents\\Arduino\\hardware\\Arduino_STM32-master\\STM32F1\\system/libmaple" "-IC:\\Users\\AMP_SAI\\Documents\\Arduino\\hardware\\Arduino_STM32-master\\STM32F1\\system/libmaple/include" "-IC:\\Users\\AMP_SAI\\Documents\\Arduino\\hardware\\Arduino_STM32-master\\STM32F1\\system/libmaple/stm32f1/include" "-IC:\\Users\\AMP_SAI\\Documents\\Arduino\\hardware\\Arduino_STM32-master\\STM32F1\\system/libmaple/usb/stm32f1" "-IC:\\Users\\AMP_SAI\\Documents\\Arduino\\hardware\\Arduino_STM32-master\\STM32F1\\system/libmaple/usb/usb_lib" "-IC:\\Users\\AMP_SAI\\Documents\\Arduino\\hardware\\Arduino_STM32-master\\STM32F1\\cores\\maple" "-IC:\\Users\\AMP_SAI\\Documents\\Arduino\\hardware\\Arduino_STM32-master\\STM32F1\\variants\\generic_stm32f103r" "C:\\Users\\AMP_SAI\\Desktop\\hexfile\\sketch\\usermks.ino.cpp" -o "C:\\Users\\AMP_SAI\\Desktop\\hexfile\\sketch\\usermks.ino.cpp.o"
Compiling libraries...
Compiling core...
Using previously compiled file: C:\Users\AMP_SAI\Desktop\hexfile\core\wirish\start.S.o
Using previously compiled file: C:\Users\AMP_SAI\Desktop\hexfile\core\wirish\start_c.c.o
Using previously compiled file: C:\Users\AMP_SAI\Desktop\hexfile\core\wirish\syscalls.c.o
Using previously compiled file: C:\Users\AMP_SAI\Desktop\hexfile\core\board.cpp.o
Using previously compiled file: C:\Users\AMP_SAI\Desktop\hexfile\core\wirish\boards.cpp.o
Using previously compiled file: C:\Users\AMP_SAI\Desktop\hexfile\core\wirish\boards_setup.cpp.o
Using precompiled core: C:\Users\AMP_SAI\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a
"C:\\Users\\AMP_SAI\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-g++" -Os -Wl,--gc-sections -mcpu=cortex-m3 "-TC:\\Users\\AMP_SAI\\Documents\\Arduino\\hardware\\Arduino_STM32-master\\STM32F1\\variants\\generic_stm32f103r/ld/stm32f103re.ld" "-Wl,-Map,C:\\Users\\AMP_SAI\\Desktop\\hexfile/usermks.ino.map" "-LC:\\Users\\AMP_SAI\\Documents\\Arduino\\hardware\\Arduino_STM32-master\\STM32F1\\variants\\generic_stm32f103r/ld" -o "C:\\Users\\AMP_SAI\\Desktop\\hexfile/usermks.ino.elf" "-LC:\\Users\\AMP_SAI\\Desktop\\hexfile" -lm -lgcc -mthumb -Wl,--cref -Wl,--check-sections -Wl,--gc-sections -Wl,--unresolved-symbols=report-all -Wl,--warn-common -Wl,--warn-section-align -Wl,--warn-unresolved-symbols -Wl,--start-group "C:\\Users\\AMP_SAI\\Desktop\\hexfile\\sketch\\usermks.ino.cpp.o" "C:\\Users\\AMP_SAI\\Desktop\\hexfile\\core\\wirish\\start.S.o" "C:\\Users\\AMP_SAI\\Desktop\\hexfile\\core\\wirish\\start_c.c.o" "C:\\Users\\AMP_SAI\\Desktop\\hexfile\\core\\wirish\\syscalls.c.o" "C:\\Users\\AMP_SAI\\Desktop\\hexfile\\core\\board.cpp.o" "C:\\Users\\AMP_SAI\\Desktop\\hexfile\\core\\wirish\\boards.cpp.o" "C:\\Users\\AMP_SAI\\Desktop\\hexfile\\core\\wirish\\boards_setup.cpp.o" "C:\\Users\\AMP_SAI\\Desktop\\hexfile/..\\..\\AppData\\Local\\Temp\\arduino_cache_727569\\core\\core_5b0bd59db35eb2205b9735ec041d5f36.a" -Wl,--end-group
"C:\\Users\\AMP_SAI\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-objcopy" -O binary "C:\\Users\\AMP_SAI\\Desktop\\hexfile/usermks.ino.elf" "C:\\Users\\AMP_SAI\\Desktop\\hexfile/usermks.ino.bin"
"C:\\Users\\AMP_SAI\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-size" -A "C:\\Users\\AMP_SAI\\Desktop\\hexfile/usermks.ino.elf"
Sketch uses 15796 bytes (3%) of program storage space. Maximum is 524288 bytes.
Global variables use 5176 bytes (7%) of dynamic memory, leaving 60360 bytes for local variables. Maximum is 65536 bytes.
- Contact:
Please post those changed files, and the MAP file, too.
stm32f103re.ld
boards.txt file
* Linker script for Generic STM32F103RE boards.
MEMORY
ram (rwx) : ORIGIN = 0x20000000, LENGTH = 64K
rom (rx) : ORIGIN = 0x08010000, LENGTH = 448K
/* Provide memory region aliases for common.inc */
REGION_ALIAS("REGION_TEXT", rom);
REGION_ALIAS("REGION_DATA", ram);
REGION_ALIAS("REGION_BSS", ram);
REGION_ALIAS("REGION_RODATA", rom);
/* Let common.inc handle the real work. */
INCLUDE common.inc
# STM32 Boards
menu.device_variant=Variant
menu.bootloader_version=Bootloader version
menu.upload_method=Upload method
menu.cpu_speed=CPU Speed(MHz)
menu.opt=Optimize
mapleMini.name=Maple Mini
mapleMini.build.board=MAPLE_MINI
mapleMini.vid.0=0x1EAF
mapleMini.pid.0=0x0004
mapleMini.build.core=maple
mapleMini.build.cpu_flags=-DMCU_STM32F103CB -DSERIAL_USB
mapleMini.build.variant=maple_mini
mapleMini.upload.usbID=1EAF:0003
mapleMini.upload.tool=maple_upload
mapleMini.upload.protocol=maple_dfu
mapleMini.upload.use_1200bps_touch=false
mapleMini.upload.file_type=bin
mapleMini.upload.auto_reset=true
mapleMini.menu.bootloader_version.original = Original (17k RAM,108k Flash)
mapleMini.menu.bootloader_version.original.build.vect=VECT_TAB_ADDR=0x8005000
mapleMini.menu.bootloader_version.original.build.ldscript=ld/flash.ld
mapleMini.menu.bootloader_version.original.upload.maximum_size=110592
mapleMini.menu.bootloader_version.original.upload.maximum_data_size=17408
mapleMini.menu.bootloader_version.original.upload.altID=1
mapleMini.menu.bootloader_version.bootloader20 = Bootloader 2.0 (20k RAM,120k Flash)
mapleMini.menu.bootloader_version.bootloader20.build.vect=VECT_TAB_ADDR=0x8002000
mapleMini.menu.bootloader_version.bootloader20.build.ldscript=ld/bootloader_20.ld
mapleMini.menu.bootloader_version.bootloader20.upload.maximum_size=122880
mapleMini.menu.bootloader_version.bootloader20.upload.maximum_data_size=20480
mapleMini.menu.bootloader_version.bootloader20.upload.altID=2
#-- CPU Clock frequency
mapleMini.menu.cpu_speed.speed_72mhz=72MHz (Normal)
mapleMini.menu.cpu_speed.speed_72mhz.build.f_cpu=72000000L
mapleMini.menu.cpu_speed.speed_48mhz=48MHz (Slow - with USB)
mapleMini.menu.cpu_speed.speed_48mhz.build.f_cpu=48000000L
mapleMini.menu.cpu_speed.speed_128mhz=Overclocked 128MHz NO USB SERIAL. MANUAL RESET NEEDED TO UPLOAD
mapleMini.menu.cpu_speed.speed_128mhz.build.f_cpu=128000000L
#-- Optimizations
mapleMini.menu.opt.osstd=Smallest (default)
#mapleMini.menu.opt.oslto=Smallest Code with LTO
#mapleMini.menu.opt.oslto.build.flags.optimize=-Os -flto
#mapleMini.menu.opt.oslto.build.flags.ldspecs=-flto
mapleMini.menu.opt.o1std=Fast (-O1)
mapleMini.menu.opt.o1std.build.flags.optimize=-O1
mapleMini.menu.opt.o1std.build.flags.ldspecs=
#mapleMini.menu.opt.o1lto=Fast (-O1) with LTO
#mapleMini.menu.opt.o1lto.build.flags.optimize=-O1 -flto
#mapleMini.menu.opt.o1lto.build.flags.ldspecs=-flto
mapleMini.menu.opt.o2std=Faster (-O2)
mapleMini.menu.opt.o2std.build.flags.optimize=-O2
mapleMini.menu.opt.o2std.build.flags.ldspecs=
#mapleMini.menu.opt.o2lto=Faster (-O2) with LTO
#mapleMini.menu.opt.o2lto.build.flags.optimize=-O2 -flto
#mapleMini.menu.opt.o2lto.build.flags.ldspecs=-flto
mapleMini.menu.opt.o3std=Fastest (-O3)
mapleMini.menu.opt.o3std.build.flags.optimize=-O3
mapleMini.menu.opt.o3std.build.flags.ldspecs=
#mapleMini.menu.opt.o3lto=Fastest (-O3) with LTO
#mapleMini.menu.opt.o3lto.build.flags.optimize=-O3 -flto
#mapleMini.menu.opt.o3lto.build.flags.ldspecs=-flto
mapleMini.menu.opt.ogstd=Debug (-g)
mapleMini.menu.opt.ogstd.build.flags.optimize=-Og
mapleMini.menu.opt.ogstd.build.flags.ldspecs=
maple.name=Maple (Rev 3)
maple.vid.0=0x1EAF
maple.pid.0=0x0004
maple.upload.tool=maple_upload
maple.upload.protocol=maple_dfu
maple.upload.maximum_size=108000
maple.upload.maximum_data_size=17000
maple.upload.use_1200bps_touch=false
maple.upload.file_type=bin
maple.upload.usbID=1EAF:0003
maple.upload.altID=1
maple.upload.auto_reset=true
maple.build.board=MAPLE_REV3
maple.build.core=maple
maple.build.cpu_flags=-DMCU_STM32F103RB -DSERIAL_USB
maple.build.ldscript=ld/flash.ld
maple.build.variant=maple
maple.build.vect=VECT_TAB_ADDR=0x8005000
maple.menu.cpu_speed.speed_72mhz=72Mhz (Normal)
maple.menu.cpu_speed.speed_72mhz.build.f_cpu=72000000L
maple.menu.cpu_speed.speed_48mhz=48Mhz (Slow - with USB)
maple.menu.cpu_speed.speed_48mhz.build.f_cpu=48000000L
maple.menu.cpu_speed.speed_128mhz=Overclocked 128Mhz NO USB SERIAL. MANUAL RESET NEEDED TO UPLOAD
maple.menu.cpu_speed.speed_128mhz.build.f_cpu=128000000L
#-- Optimizations
maple.menu.opt.osstd=Smallest (default)
#maple.menu.opt.oslto=Smallest Code with LTO
#maple.menu.opt.oslto.build.flags.optimize=-Os -flto
#maple.menu.opt.oslto.build.flags.ldspecs=-flto
maple.menu.opt.o1std=Fast (-O1)
maple.menu.opt.o1std.build.flags.optimize=-O1
maple.menu.opt.o1std.build.flags.ldspecs=
#maple.menu.opt.o1lto=Fast (-O1) with LTO
#maple.menu.opt.o1lto.build.flags.optimize=-O1 -flto
#maple.menu.opt.o1lto.build.flags.ldspecs=-flto
maple.menu.opt.o2std=Faster (-O2)
maple.menu.opt.o2std.build.flags.optimize=-O2
maple.menu.opt.o2std.build.flags.ldspecs=
#maple.menu.opt.o2lto=Faster (-O2) with LTO
#maple.menu.opt.o2lto.build.flags.optimize=-O2 -flto
#maple.menu.opt.o2lto.build.flags.ldspecs=-flto
maple.menu.opt.o3std=Fastest (-O3)
maple.menu.opt.o3std.build.flags.optimize=-O3
maple.menu.opt.o3std.build.flags.ldspecs=
#maple.menu.opt.o3lto=Fastest (-O3) with LTO
#maple.menu.opt.o3lto.build.flags.optimize=-O3 -flto
#maple.menu.opt.o3lto.build.flags.ldspecs=-flto
maple.menu.opt.ogstd=Debug (-g)
maple.menu.opt.ogstd.build.flags.optimize=-Og
maple.menu.opt.ogstd.build.flags.ldspecs=
mapleRET6.name=Maple (RET6)
mapleRET6.vid.0=0x1EAF
mapleRET6.pid.0=0x0004
mapleRET6.build.board=MAPLE_RET6
mapleRET6.build.core=maple
mapleRET6.build.cpu_flags=-DMCU_STM32F103RE -DSERIAL_USB
mapleRET6.build.ldscript=ld/stm32f103re-bootloader.ld
mapleRET6.build.variant=maple_ret6
mapleRET6.build.vect=VECT_TAB_ADDR=0x8005000
mapleRET6.upload.tool=maple_upload
mapleRET6.upload.protocol=maple_dfu
mapleRET6.upload.maximum_size=262144
mapleRET6.upload.maximum_data_size=49152
mapleRET6.upload.use_1200bps_touch=false
mapleRET6.upload.file_type=bin
mapleRET6.upload.usbID=1EAF:0003
mapleRET6.upload.altID=1
mapleRET6.upload.auto_reset=true
mapleRET6.menu.cpu_speed.speed_72mhz=72Mhz (Normal)
mapleRET6.menu.cpu_speed.speed_72mhz.build.f_cpu=72000000L
mapleRET6.menu.cpu_speed.speed_48mhz=48Mhz (Slow - with USB)
mapleRET6.menu.cpu_speed.speed_48mhz.build.f_cpu=48000000L
mapleRET6.menu.cpu_speed.speed_128mhz=Overclocked 128Mhz NO USB SERIAL. MANUAL RESET NEEDED TO UPLOAD
mapleRET6.menu.cpu_speed.speed_128mhz.build.f_cpu=128000000L
#-- Optimizations
mapleRET6.menu.opt.osstd=Smallest (default)
#mapleRET6.menu.opt.oslto=Smallest Code with LTO
#mapleRET6.menu.opt.oslto.build.flags.optimize=-Os -flto
#mapleRET6.menu.opt.oslto.build.flags.ldspecs=-flto
mapleRET6.menu.opt.o1std=Fast (-O1)
mapleRET6.menu.opt.o1std.build.flags.optimize=-O1
mapleRET6.menu.opt.o1std.build.flags.ldspecs=
#mapleRET6.menu.opt.o1lto=Fast (-O1) with LTO
#mapleRET6.menu.opt.o1lto.build.flags.optimize=-O1 -flto
#mapleRET6.menu.opt.o1lto.build.flags.ldspecs=-flto
mapleRET6.menu.opt.o2std=Faster (-O2)
mapleRET6.menu.opt.o2std.build.flags.optimize=-O2
mapleRET6.menu.opt.o2std.build.flags.ldspecs=
#mapleRET6.menu.opt.o2lto=Faster (-O2) with LTO
#mapleRET6.menu.opt.o2lto.build.flags.optimize=-O2 -flto
#mapleRET6.menu.opt.o2lto.build.flags.ldspecs=-flto
mapleRET6.menu.opt.o3std=Fastest (-O3)
mapleRET6.menu.opt.o3std.build.flags.optimize=-O3
mapleRET6.menu.opt.o3std.build.flags.ldspecs=
#mapleRET6.menu.opt.o3lto=Fastest (-O3) with LTO
#mapleRET6.menu.opt.o3lto.build.flags.optimize=-O3 -flto
#mapleRET6.menu.opt.o3lto.build.flags.ldspecs=-flto
mapleRET6.menu.opt.ogstd=Debug (-g)
mapleRET6.menu.opt.ogstd.build.flags.optimize=-Og
mapleRET6.menu.opt.ogstd.build.flags.ldspecs=
microduino32_flash.name=Microduino Core STM32 to Flash
microduino32_flash.vid.0=0x1EAF
microduino32_flash.pid.0=0x0004
microduino32_flash.upload.tool=maple_upload
microduino32_flash.upload.protocol=maple_dfu
microduino32_flash.upload.maximum_size=108000
microduino32_flash.upload.maximum_data_size=17000
microduino32_flash.upload.use_1200bps_touch=false
microduino32_flash.upload.file_type=bin
microduino32_flash.upload.usbID=1EAF:0003
microduino32_flash.upload.altID=1
microduino32_flash.upload.auto_reset=true
microduino32_flash.build.mcu=cortex-m3
microduino32_flash.build.f_cpu=72000000L
microduino32_flash.build.board=MICRODUINO_CORE_STM32
microduino32_flash.build.core=maple
microduino32_flash.build.extra_flags=-DMCU_STM32F103CB -mthumb -DSERIAL_USB -march=armv7-m -D__STM32F1__
microduino32_flash.build.ldscript=ld/flash.ld
microduino32_flash.build.variant=microduino
microduino32_flash.build.variant_system_lib=libmaple.a
microduino32_flash.build.vect=VECT_TAB_ADDR=0x8005000
microduino32_flash.build.density=STM32_MEDIUM_DENSITY
# FIXME!
microduino32_flash.build.error_led_port=GPIOB
microduino32_flash.build.error_led_pin=1
microduino32_flash.build.gcc_ver=gcc-arm-none-eabi-4.8.3-2014q1
microduino32_flash.menu.cpu_speed.speed_72mhz=72Mhz (Normal)
microduino32_flash.menu.cpu_speed.speed_72mhz.build.f_cpu=72000000L
microduino32_flash.menu.cpu_speed.speed_48mhz=48Mhz (Slow - with USB)
microduino32_flash.menu.cpu_speed.speed_48mhz.build.f_cpu=48000000L
microduino32_flash.menu.cpu_speed.speed_128mhz=Overclocked 128Mhz NO USB SERIAL. MANUAL RESET NEEDED TO UPLOAD
microduino32_flash.menu.cpu_speed.speed_128mhz.build.f_cpu=128000000L
#-- Optimizations
microduino32_flash.menu.opt.osstd=Smallest (default)
#microduino32_flash.menu.opt.oslto=Smallest Code with LTO
#microduino32_flash.menu.opt.oslto.build.flags.optimize=-Os -flto
#microduino32_flash.menu.opt.oslto.build.flags.ldspecs=-flto
microduino32_flash.menu.opt.o1std=Fast (-O1)
microduino32_flash.menu.opt.o1std.build.flags.optimize=-O1
microduino32_flash.menu.opt.o1std.build.flags.ldspecs=
#microduino32_flash.menu.opt.o1lto=Fast (-O1) with LTO
#microduino32_flash.menu.opt.o1lto.build.flags.optimize=-O1 -flto
#microduino32_flash.menu.opt.o1lto.build.flags.ldspecs=-flto
microduino32_flash.menu.opt.o2std=Faster (-O2)
microduino32_flash.menu.opt.o2std.build.flags.optimize=-O2
microduino32_flash.menu.opt.o2std.build.flags.ldspecs=
#microduino32_flash.menu.opt.o2lto=Faster (-O2) with LTO
#microduino32_flash.menu.opt.o2lto.build.flags.optimize=-O2 -flto
#microduino32_flash.menu.opt.o2lto.build.flags.ldspecs=-flto
microduino32_flash.menu.opt.o3std=Fastest (-O3)
microduino32_flash.menu.opt.o3std.build.flags.optimize=-O3
microduino32_flash.menu.opt.o3std.build.flags.ldspecs=
#microduino32_flash.menu.opt.o3lto=Fastest (-O3) with LTO
#microduino32_flash.menu.opt.o3lto.build.flags.optimize=-O3 -flto
#microduino32_flash.menu.opt.o3lto.build.flags.ldspecs=-flto
microduino32_flash.menu.opt.ogstd=Debug (-g)
microduino32_flash.menu.opt.ogstd.build.flags.optimize=-Og
microduino32_flash.menu.opt.ogstd.build.flags.ldspecs=
nucleo_f103rb.name=STM Nucleo F103RB (STLink)
nucleo_f103rb.upload.tool=stlink_upload
nucleo_f103rb.upload.protocol=maple_dfu
nucleo_f103rb.upload.maximum_size=108000
nucleo_f103rb.upload.maximum_data_size=17000
nucleo_f103rb.upload.use_1200bps_touch=false
nucleo_f103rb.upload.file_type=bin
nucleo_f103rb.upload.params.quiet=no
nucleo_f103rb.upload.usbID=1EAF:0003
nucleo_f103rb.upload.altID=1
nucleo_f103rb.upload.auto_reset=true
nucleo_f103rb.build.mcu=cortex-m3
nucleo_f103rb.build.board=STM_NUCLEO_F103RB
nucleo_f103rb.build.core=maple
nucleo_f103rb.build.ldscript=ld/jtag.ld
nucleo_f103rb.build.variant=nucleo_f103rb
nucleo_f103rb.build.variant_system_lib=libmaple.a
nucleo_f103rb.build.density=STM32_MEDIUM_DENSITY
nucleo_f103rb.build.error_led_port=GPIOB
nucleo_f103rb.build.error_led_pin=1
nucleo_f103rb.build.gcc_ver=gcc-arm-none-eabi-4.8.3-2014q1
nucleo_f103rb.build.vect=VECT_TAB_ADDR=0x8000000
## internal oscillator (HSI), running at 64 MHz
nucleo_f103rb.menu.device_variant.NucleoF103_HSI=Nucleo F103 @ 64 MHz
nucleo_f103rb.menu.device_variant.NucleoF103_HSI.build.f_cpu=64000000L
nucleo_f103rb.menu.device_variant.NucleoF103_HSI.build.extra_flags=-DMCU_STM32F103RB -mthumb -march=armv7-m -D__STM32F1__
## external crystal (HSE), running at 72 MHz
nucleo_f103rb.menu.device_variant.NucleoF103_HSE=Nucleo F103 @ 72 MHz w/ crystal
nucleo_f103rb.menu.device_variant.NucleoF103_HSE.build.f_cpu=72000000L
nucleo_f103rb.menu.device_variant.NucleoF103_HSE.build.extra_flags=-DNUCLEO_HSE_CRYSTAL -DMCU_STM32F103RB -mthumb -march=armv7-m -D__STM32F1__
#-- Optimizations
nucleo_f103rb.menu.opt.osstd=Smallest (default)
#nucleo_f103rb.menu.opt.oslto=Smallest Code with LTO
#nucleo_f103rb.menu.opt.oslto.build.flags.optimize=-Os -flto
#nucleo_f103rb.menu.opt.oslto.build.flags.ldspecs=-flto
nucleo_f103rb.menu.opt.o1std=Fast (-O1)
nucleo_f103rb.menu.opt.o1std.build.flags.optimize=-O1
nucleo_f103rb.menu.opt.o1std.build.flags.ldspecs=
#nucleo_f103rb.menu.opt.o1lto=Fast (-O1) with LTO
#nucleo_f103rb.menu.opt.o1lto.build.flags.optimize=-O1 -flto
#nucleo_f103rb.menu.opt.o1lto.build.flags.ldspecs=-flto
nucleo_f103rb.menu.opt.o2std=Faster (-O2)
nucleo_f103rb.menu.opt.o2std.build.flags.optimize=-O2
nucleo_f103rb.menu.opt.o2std.build.flags.ldspecs=
#nucleo_f103rb.menu.opt.o2lto=Faster (-O2) with LTO
#nucleo_f103rb.menu.opt.o2lto.build.flags.optimize=-O2 -flto
#nucleo_f103rb.menu.opt.o2lto.build.flags.ldspecs=-flto
nucleo_f103rb.menu.opt.o3std=Fastest (-O3)
nucleo_f103rb.menu.opt.o3std.build.flags.optimize=-O3
nucleo_f103rb.menu.opt.o3std.build.flags.ldspecs=
#nucleo_f103rb.menu.opt.o3lto=Fastest (-O3) with LTO
#nucleo_f103rb.menu.opt.o3lto.build.flags.optimize=-O3 -flto
#nucleo_f103rb.menu.opt.o3lto.build.flags.ldspecs=-flto
nucleo_f103rb.menu.opt.ogstd=Debug (-g)
nucleo_f103rb.menu.opt.ogstd.build.flags.optimize=-Og
nucleo_f103rb.menu.opt.ogstd.build.flags.ldspecs=
###################### Generic STM32F103C ########################################
genericSTM32F103C.name=Generic STM32F103C series
genericSTM32F103C.vid.0=0x1EAF
genericSTM32F103C.pid.0=0x0004
genericSTM32F103C.build.variant=generic_stm32f103c
genericSTM32F103C.build.vect=VECT_TAB_ADDR=0x8000000
genericSTM32F103C.build.core=maple
genericSTM32F103C.build.board=GENERIC_STM32F103C
genericSTM32F103C.build.error_led_port=GPIOC
genericSTM32F103C.build.error_led_pin=13
genericSTM32F103C.upload.use_1200bps_touch=false
genericSTM32F103C.upload.file_type=bin
genericSTM32F103C.upload.auto_reset=true
genericSTM32F103C.upload.tool=maple_upload
genericSTM32F103C.upload.protocol=maple_dfu
## STM32F103C8 -------------------------
genericSTM32F103C.menu.device_variant.STM32F103C8=STM32F103C8 (20k RAM. 64k Flash)
genericSTM32F103C.menu.device_variant.STM32F103C8.build.cpu_flags=-DMCU_STM32F103C8
genericSTM32F103C.menu.device_variant.STM32F103C8.build.ldscript=ld/jtag_c8.ld
genericSTM32F103C.menu.device_variant.STM32F103C8.upload.maximum_size=65536
genericSTM32F103C.menu.device_variant.STM32F103C8.upload.maximum_data_size=20480
## STM32F103CB -------------------------
genericSTM32F103C.menu.device_variant.STM32F103CB=STM32F103CB (20k RAM. 128k Flash)
genericSTM32F103C.menu.device_variant.STM32F103CB.build.cpu_flags=-DMCU_STM32F103CB
genericSTM32F103C.menu.device_variant.STM32F103CB.build.ldscript=ld/jtag.ld
genericSTM32F103C.menu.device_variant.STM32F103CB.upload.maximum_size=131072
genericSTM32F103C.menu.device_variant.STM32F103CB.upload.maximum_data_size=20480
#---------------------------- UPLOAD METHODS ---------------------------
genericSTM32F103C.menu.upload_method.DFUUploadMethod=STM32duino bootloader
genericSTM32F103C.menu.upload_method.DFUUploadMethod.upload.protocol=maple_dfu
genericSTM32F103C.menu.upload_method.DFUUploadMethod.upload.tool=maple_upload
genericSTM32F103C.menu.upload_method.DFUUploadMethod.build.upload_flags=-DSERIAL_USB -DGENERIC_BOOTLOADER
genericSTM32F103C.menu.upload_method.DFUUploadMethod.build.vect=VECT_TAB_ADDR=0x8002000
genericSTM32F103C.menu.upload_method.DFUUploadMethod.build.ldscript=ld/bootloader_20.ld
genericSTM32F103C.menu.upload_method.DFUUploadMethod.upload.usbID=1EAF:0003
genericSTM32F103C.menu.upload_method.DFUUploadMethod.upload.altID=2
genericSTM32F103C.menu.upload_method.serialMethod=Serial
genericSTM32F103C.menu.upload_method.serialMethod.upload.protocol=maple_serial
genericSTM32F103C.menu.upload_method.serialMethod.upload.tool=serial_upload
genericSTM32F103C.menu.upload_method.serialMethod.build.upload_flags=-DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG
genericSTM32F103C.menu.upload_method.STLinkMethod=STLink
genericSTM32F103C.menu.upload_method.STLinkMethod.upload.protocol=STLink
genericSTM32F103C.menu.upload_method.STLinkMethod.upload.tool=stlink_upload
genericSTM32F103C.menu.upload_method.STLinkMethod.build.upload_flags=-DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1 -DSERIAL_USB -DGENERIC_BOOTLOADER
genericSTM32F103C.menu.upload_method.BMPMethod=BMP (Black Magic Probe)
genericSTM32F103C.menu.upload_method.BMPMethod.upload.protocol=gdb_bmp
genericSTM32F103C.menu.upload_method.BMPMethod.upload.tool=bmp_upload
genericSTM32F103C.menu.upload_method.BMPMethod.build.upload_flags=-DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG
genericSTM32F103C.menu.upload_method.jlinkMethod=JLink
genericSTM32F103C.menu.upload_method.jlinkMethod.upload.protocol=jlink
genericSTM32F103C.menu.upload_method.jlinkMethod.upload.tool=jlink_upload
genericSTM32F103C.menu.upload_method.jlinkMethod.build.upload_flags=-DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1 -DSERIAL_USB -DGENERIC_BOOTLOADER
genericSTM32F103C.menu.upload_method.HIDUploadMethod=HID bootloader 2.0
genericSTM32F103C.menu.upload_method.HIDUploadMethod.upload.tool=hid_upload
genericSTM32F103C.menu.upload_method.HIDUploadMethod.build.upload_flags=-DSERIAL_USB -DGENERIC_BOOTLOADER
genericSTM32F103C.menu.upload_method.HIDUploadMethod.build.vect=VECT_TAB_ADDR=0x8001000
genericSTM32F103C.menu.upload_method.HIDUploadMethod.build.ldscript=ld/hid_bootloader.ld
genericSTM32F103C.menu.cpu_speed.speed_72mhz=72Mhz (Normal)
genericSTM32F103C.menu.cpu_speed.speed_72mhz.build.f_cpu=72000000L
genericSTM32F103C.menu.cpu_speed.speed_48mhz=48Mhz (Slow - with USB)
genericSTM32F103C.menu.cpu_speed.speed_48mhz.build.f_cpu=48000000L
genericSTM32F103C.menu.cpu_speed.speed_128mhz=Overclocked 128Mhz NO USB SERIAL. MANUAL RESET NEEDED TO UPLOAD
genericSTM32F103C.menu.cpu_speed.speed_128mhz.build.f_cpu=128000000L
#-- Optimizations
genericSTM32F103C.menu.opt.osstd=Smallest (default)
#genericSTM32F103C.menu.opt.oslto=Smallest Code with LTO
#genericSTM32F103C.menu.opt.oslto.build.flags.optimize=-Os -flto
#genericSTM32F103C.menu.opt.oslto.build.flags.ldspecs=-flto
genericSTM32F103C.menu.opt.o1std=Fast (-O1)
genericSTM32F103C.menu.opt.o1std.build.flags.optimize=-O1
genericSTM32F103C.menu.opt.o1std.build.flags.ldspecs=
#genericSTM32F103C.menu.opt.o1lto=Fast (-O1) with LTO
#genericSTM32F103C.menu.opt.o1lto.build.flags.optimize=-O1 -flto
#genericSTM32F103C.menu.opt.o1lto.build.flags.ldspecs=-flto
genericSTM32F103C.menu.opt.o2std=Faster (-O2)
genericSTM32F103C.menu.opt.o2std.build.flags.optimize=-O2
genericSTM32F103C.menu.opt.o2std.build.flags.ldspecs=
#genericSTM32F103C.menu.opt.o2lto=Faster (-O2) with LTO
#genericSTM32F103C.menu.opt.o2lto.build.flags.optimize=-O2 -flto
#genericSTM32F103C.menu.opt.o2lto.build.flags.ldspecs=-flto
genericSTM32F103C.menu.opt.o3std=Fastest (-O3)
genericSTM32F103C.menu.opt.o3std.build.flags.optimize=-O3
genericSTM32F103C.menu.opt.o3std.build.flags.ldspecs=
#genericSTM32F103C.menu.opt.o3lto=Fastest (-O3) with LTO
#genericSTM32F103C.menu.opt.o3lto.build.flags.optimize=-O3 -flto
#genericSTM32F103C.menu.opt.o3lto.build.flags.ldspecs=-flto
genericSTM32F103C.menu.opt.ogstd=Debug (-g)
genericSTM32F103C.menu.opt.ogstd.build.flags.optimize=-Og
genericSTM32F103C.menu.opt.ogstd.build.flags.ldspecs=
###################### Generic STM32F103C6 ########################################
genericSTM32F103C6.name=Generic STM32F103C6/fake STM32F103C8
genericSTM32F103C6.vid.0=0x1EAF
genericSTM32F103C6.pid.0=0x0004
genericSTM32F103C6.build.variant=generic_stm32f103c
genericSTM32F103C6.build.vect=VECT_TAB_ADDR=0x8000000
genericSTM32F103C6.build.core=maple
genericSTM32F103C6.build.board=GENERIC_STM32F103C
genericSTM32F103C6.build.error_led_port=GPIOC
genericSTM32F103C6.build.error_led_pin=13
genericSTM32F103C6.upload.use_1200bps_touch=false
genericSTM32F103C6.upload.file_type=bin
genericSTM32F103C6.upload.auto_reset=true
genericSTM32F103C6.upload.tool=maple_upload
genericSTM32F103C6.upload.protocol=maple_dfu
genericSTM32F103C6.build.cpu_flags=-DMCU_STM32F103C6
genericSTM32F103C6.build.ldscript=ld/jtag_c6.ld
genericSTM32F103C6.upload.maximum_size=32768
genericSTM32F103C6.upload.maximum_data_size=10240
genericSTM32F103C6.menu.upload_method.DFUUploadMethod=STM32duino bootloader
genericSTM32F103C6.menu.upload_method.DFUUploadMethod.upload.protocol=maple_dfu
genericSTM32F103C6.menu.upload_method.DFUUploadMethod.upload.tool=maple_upload
genericSTM32F103C6.menu.upload_method.DFUUploadMethod.build.upload_flags=-DSERIAL_USB -DGENERIC_BOOTLOADER
genericSTM32F103C6.menu.upload_method.DFUUploadMethod.build.vect=VECT_TAB_ADDR=0x8002000
genericSTM32F103C6.menu.upload_method.DFUUploadMethod.build.ldscript=ld/bootloader_20_c6.ld
genericSTM32F103C6.menu.upload_method.DFUUploadMethod.upload.usbID=1EAF:0003
genericSTM32F103C6.menu.upload_method.DFUUploadMethod.upload.altID=2
genericSTM32F103C6.menu.upload_method.DFUUploadMethod.upload.maximum_size=24576
genericSTM32F103C6.menu.upload_method.serialMethod=Serial
genericSTM32F103C6.menu.upload_method.serialMethod.upload.protocol=maple_serial
genericSTM32F103C6.menu.upload_method.serialMethod.upload.tool=serial_upload
genericSTM32F103C6.menu.upload_method.serialMethod.build.upload_flags=-DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG
genericSTM32F103C6.menu.upload_method.STLinkMethod=STLink
genericSTM32F103C6.menu.upload_method.STLinkMethod.upload.protocol=STLink
genericSTM32F103C6.menu.upload_method.STLinkMethod.upload.tool=stlink_upload
genericSTM32F103C6.menu.upload_method.STLinkMethod.build.upload_flags=-DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1 -DSERIAL_USB -DGENERIC_BOOTLOADER
genericSTM32F103C6.menu.upload_method.BMPMethod=BMP (Black Magic Probe)
genericSTM32F103C6.menu.upload_method.BMPMethod.upload.protocol=gdb_bmp
genericSTM32F103C6.menu.upload_method.BMPMethod.upload.tool=bmp_upload
genericSTM32F103C6.menu.upload_method.BMPMethod.build.upload_flags=-DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG
genericSTM32F103C6.menu.upload_method.jlinkMethod=JLink
genericSTM32F103C6.menu.upload_method.jlinkMethod.upload.protocol=jlink
genericSTM32F103C6.menu.upload_method.jlinkMethod.upload.tool=jlink_upload
genericSTM32F103C6.menu.upload_method.jlinkMethod.build.upload_flags=-DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1 -DSERIAL_USB -DGENERIC_BOOTLOADER
#genericSTM32F103C6.menu.upload_method.HIDUploadMethod=HID bootloader 2.0
#genericSTM32F103C6.menu.upload_method.HIDUploadMethod.upload.tool=hid_upload
#genericSTM32F103C6.menu.upload_method.HIDUploadMethod.build.upload_flags=-DSERIAL_USB -DGENERIC_BOOTLOADER
#genericSTM32F103C6.menu.upload_method.HIDUploadMethod.build.vect=VECT_TAB_ADDR=0x8001000
#genericSTM32F103C6.menu.upload_method.HIDUploadMethod.build.ldscript=ld/hid_bootloader_c6.ld
genericSTM32F103C6.menu.cpu_speed.speed_72mhz=72Mhz (Normal)
genericSTM32F103C6.menu.cpu_speed.speed_72mhz.build.f_cpu=72000000L
genericSTM32F103C6.menu.cpu_speed.speed_48mhz=48Mhz (Slow - with USB)
genericSTM32F103C6.menu.cpu_speed.speed_48mhz.build.f_cpu=48000000L
genericSTM32F103C6.menu.cpu_speed.speed_128mhz=Overclocked 128Mhz NO USB SERIAL. MANUAL RESET NEEDED TO UPLOAD
genericSTM32F103C6.menu.cpu_speed.speed_128mhz.build.f_cpu=128000000L
#-- Optimizations
genericSTM32F103C6.menu.opt.osstd=Smallest (default)
#genericSTM32F103C6.menu.opt.oslto=Smallest Code with LTO
#genericSTM32F103C6.menu.opt.oslto.build.flags.optimize=-Os -flto
#genericSTM32F103C6.menu.opt.oslto.build.flags.ldspecs=-flto
genericSTM32F103C6.menu.opt.o1std=Fast (-O1)
genericSTM32F103C6.menu.opt.o1std.build.flags.optimize=-O1
genericSTM32F103C6.menu.opt.o1std.build.flags.ldspecs=
#genericSTM32F103C6.menu.opt.o1lto=Fast (-O1) with LTO
#genericSTM32F103C6.menu.opt.o1lto.build.flags.optimize=-O1 -flto
#genericSTM32F103C6.menu.opt.o1lto.build.flags.ldspecs=-flto
genericSTM32F103C6.menu.opt.o2std=Faster (-O2)
genericSTM32F103C6.menu.opt.o2std.build.flags.optimize=-O2
genericSTM32F103C6.menu.opt.o2std.build.flags.ldspecs=
#genericSTM32F103C6.menu.opt.o2lto=Faster (-O2) with LTO
#genericSTM32F103C6.menu.opt.o2lto.build.flags.optimize=-O2 -flto
#genericSTM32F103C6.menu.opt.o2lto.build.flags.ldspecs=-flto
genericSTM32F103C6.menu.opt.o3std=Fastest (-O3)
genericSTM32F103C6.menu.opt.o3std.build.flags.optimize=-O3
genericSTM32F103C6.menu.opt.o3std.build.flags.ldspecs=
#genericSTM32F103C6.menu.opt.o3lto=Fastest (-O3) with LTO
#genericSTM32F103C6.menu.opt.o3lto.build.flags.optimize=-O3 -flto
#genericSTM32F103C6.menu.opt.o3lto.build.flags.ldspecs=-flto
genericSTM32F103C6.menu.opt.ogstd=Debug (-g)
genericSTM32F103C6.menu.opt.ogstd.build.flags.optimize=-Og
genericSTM32F103C6.menu.opt.ogstd.build.flags.ldspecs=
########################### Generic STM32F103R ###########################
genericSTM32F103R.name=Generic STM32F103R series
genericSTM32F103R.vid.0=0x1EAF
genericSTM32F103R.pid.0=0x0004
#genericSTM32F103R.build.variant=generic_stm32f103r
genericSTM32F103R.build.vect=VECT_TAB_ADDR=0x8010000
genericSTM32F103R.build.core=maple
genericSTM32F103R.build.board=GENERIC_STM32F103R
genericSTM32F103R.upload.use_1200bps_touch=false
genericSTM32F103R.upload.file_type=bin
genericSTM32F103R.upload.auto_reset=true
genericSTM32F103R.upload.tool=maple_upload
genericSTM32F103R.upload.protocol=maple_dfu
genericSTM32F103R.menu.device_variant.STM32F103R8=STM32F103R8 (20k RAM. 64k Flash)
genericSTM32F103R.menu.device_variant.STM32F103R8.build.variant=generic_stm32f103r8
genericSTM32F103R.menu.device_variant.STM32F103R8.build.cpu_flags=-DMCU_STM32F103R8
genericSTM32F103R.menu.device_variant.STM32F103R8.upload.maximum_size=65536
genericSTM32F103R.menu.device_variant.STM32F103R8.upload.maximum_data_size=20480
genericSTM32F103R.menu.device_variant.STM32F103R8.build.ldscript=ld/stm32f103r8.ld
genericSTM32F103R.menu.device_variant.STM32F103RB=STM32F103RB (20k RAM. 128k Flash)
genericSTM32F103R.menu.device_variant.STM32F103RB.build.variant=generic_stm32f103r8
genericSTM32F103R.menu.device_variant.STM32F103RB.build.cpu_flags=-DMCU_STM32F103RB
genericSTM32F103R.menu.device_variant.STM32F103RB.upload.maximum_size=131072
genericSTM32F103R.menu.device_variant.STM32F103RB.upload.maximum_data_size=20480
genericSTM32F103R.menu.device_variant.STM32F103RB.build.ldscript=ld/stm32f103rb.ld
genericSTM32F103R.menu.device_variant.STM32F103RC=STM32F103RC (48k RAM. 256k Flash)
genericSTM32F103R.menu.device_variant.STM32F103RC.build.variant=generic_stm32f103r
genericSTM32F103R.menu.device_variant.STM32F103RC.build.cpu_flags=-DMCU_STM32F103RC
genericSTM32F103R.menu.device_variant.STM32F103RC.upload.maximum_size=262144
genericSTM32F103R.menu.device_variant.STM32F103RC.upload.maximum_data_size=49152
genericSTM32F103R.menu.device_variant.STM32F103RC.upload.ram.maximum_size=49152
genericSTM32F103R.menu.device_variant.STM32F103RC.upload.flash.maximum_size=262144
genericSTM32F103R.menu.device_variant.STM32F103RC.build.ldscript=ld/stm32f103rc.ld
genericSTM32F103R.menu.device_variant.STM32F103RE=STM32F103RE (64k RAM. 512k Flash)
genericSTM32F103R.menu.device_variant.STM32F103RE.build.variant=generic_stm32f103r
genericSTM32F103R.menu.device_variant.STM32F103RE.build.cpu_flags=-DMCU_STM32F103RE
genericSTM32F103R.menu.device_variant.STM32F103RE.upload.maximum_size=524288
genericSTM32F103R.menu.device_variant.STM32F103RE.upload.maximum_data_size=65536
genericSTM32F103R.menu.device_variant.STM32F103RE.build.ldscript=ld/stm32f103re.ld
genericSTM32F103R.menu.upload_method.DFUUploadMethod=STM32duino bootloader
genericSTM32F103R.menu.upload_method.DFUUploadMethod.upload.protocol=maple_dfu
genericSTM32F103R.menu.upload_method.DFUUploadMethod.upload.tool=maple_upload
genericSTM32F103R.menu.upload_method.DFUUploadMethod.build.upload_flags=-DSERIAL_USB -DGENERIC_BOOTLOADER
genericSTM32F103R.menu.upload_method.DFUUploadMethod.build.vect=VECT_TAB_ADDR=0x8002000
genericSTM32F103R.menu.upload_method.DFUUploadMethod.build.ldscript=ld/bootloader.ld
genericSTM32F103R.menu.upload_method.DFUUploadMethod.upload.usbID=1EAF:0003
genericSTM32F103R.menu.upload_method.DFUUploadMethod.upload.altID=2
genericSTM32F103R.menu.upload_method.serialMethod=Serial
genericSTM32F103R.menu.upload_method.serialMethod.upload.protocol=maple_serial
genericSTM32F103R.menu.upload_method.serialMethod.upload.tool=serial_upload
genericSTM32F103R.menu.upload_method.serialMethod.build.upload_flags=-DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1
genericSTM32F103R.menu.upload_method.STLinkMethod=STLink
genericSTM32F103R.menu.upload_method.STLinkMethod.upload.protocol=STLink
genericSTM32F103R.menu.upload_method.STLinkMethod.upload.tool=stlink_upload
genericSTM32F103R.menu.upload_method.STLinkMethod.build.upload_flags=-DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1 -DSERIAL_USB -DGENERIC_BOOTLOADER
genericSTM32F103R.menu.upload_method.BMPMethod=BMP (Black Magic Probe)
genericSTM32F103R.menu.upload_method.BMPMethod.upload.protocol=gdb_bmp
genericSTM32F103R.menu.upload_method.BMPMethod.upload.tool=bmp_upload
genericSTM32F103R.menu.upload_method.BMPMethod.build.upload_flags=-DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG
genericSTM32F103R.menu.cpu_speed.speed_72mhz=72Mhz (Normal)
genericSTM32F103R.menu.cpu_speed.speed_72mhz.build.f_cpu=72000000L
genericSTM32F103R.menu.cpu_speed.speed_48mhz=48Mhz (Slow - with USB)
genericSTM32F103R.menu.cpu_speed.speed_48mhz.build.f_cpu=48000000L
genericSTM32F103R.menu.cpu_speed.speed_128mhz=Overclocked 128Mhz NO USB SERIAL. MANUAL RESET NEEDED TO UPLOAD
genericSTM32F103R.menu.cpu_speed.speed_128mhz.build.f_cpu=128000000L
#-- Optimizations
genericSTM32F103R.menu.opt.osstd=Smallest (default)
#genericSTM32F103R.menu.opt.oslto=Smallest Code with LTO
#genericSTM32F103R.menu.opt.oslto.build.flags.optimize=-Os -flto
#genericSTM32F103R.menu.opt.oslto.build.flags.ldspecs=-flto
genericSTM32F103R.menu.opt.o1std=Fast (-O1)
genericSTM32F103R.menu.opt.o1std.build.flags.optimize=-O1
genericSTM32F103R.menu.opt.o1std.build.flags.ldspecs=
#genericSTM32F103R.menu.opt.o1lto=Fast (-O1) with LTO
#genericSTM32F103R.menu.opt.o1lto.build.flags.optimize=-O1 -flto
#genericSTM32F103R.menu.opt.o1lto.build.flags.ldspecs=-flto
genericSTM32F103R.menu.opt.o2std=Faster (-O2)
genericSTM32F103R.menu.opt.o2std.build.flags.optimize=-O2
genericSTM32F103R.menu.opt.o2std.build.flags.ldspecs=
#genericSTM32F103R.menu.opt.o2lto=Faster (-O2) with LTO
#genericSTM32F103R.menu.opt.o2lto.build.flags.optimize=-O2 -flto
#genericSTM32F103R.menu.opt.o2lto.build.flags.ldspecs=-flto
genericSTM32F103R.menu.opt.o3std=Fastest (-O3)
genericSTM32F103R.menu.opt.o3std.build.flags.optimize=-O3
genericSTM32F103R.menu.opt.o3std.build.flags.ldspecs=
#genericSTM32F103R.menu.opt.o3lto=Fastest (-O3) with LTO
#genericSTM32F103R.menu.opt.o3lto.build.flags.optimize=-O3 -flto
#genericSTM32F103R.menu.opt.o3lto.build.flags.ldspecs=-flto
genericSTM32F103R.menu.opt.ogstd=Debug (-g)
genericSTM32F103R.menu.opt.ogstd.build.flags.optimize=-Og
genericSTM32F103R.menu.opt.ogstd.build.flags.ldspecs=
###################### Generic STM32F103T ########################################
genericSTM32F103T.name=Generic STM32F103T series
genericSTM32F103T.vid.0=0x1EAF
genericSTM32F103T.pid.0=0x0004
genericSTM32F103T.build.variant=generic_stm32f103t
genericSTM32F103T.build.vect=VECT_TAB_ADDR=0x8000000
genericSTM32F103T.build.core=maple
genericSTM32F103T.build.board=GENERIC_STM32F103T
genericSTM32F103T.upload.use_1200bps_touch=false
genericSTM32F103T.upload.file_type=bin
genericSTM32F103T.upload.auto_reset=true
genericSTM32F103T.upload.tool=maple_upload
genericSTM32F103T.upload.protocol=maple_dfu
## STM32F103T8 -------------------------
genericSTM32F103T.menu.device_variant.STM32F103T8=STM32F103T8 (20k RAM. 64k Flash)
genericSTM32F103T.menu.device_variant.STM32F103T8.build.cpu_flags=-DMCU_STM32F103T8
genericSTM32F103T.menu.device_variant.STM32F103T8.build.ldscript=ld/jtag_t8.ld
genericSTM32F103T.menu.device_variant.STM32F103T8.upload.maximum_size=65536
genericSTM32F103T.menu.device_variant.STM32F103T8.upload.maximum_data_size=20480
## STM32F103TB -------------------------
genericSTM32F103T.menu.device_variant.STM32F103TB=STM32F103TB (20k RAM. 128k Flash)
genericSTM32F103T.menu.device_variant.STM32F103TB.build.cpu_flags=-DMCU_STM32F103TB
genericSTM32F103T.menu.device_variant.STM32F103TB.build.ldscript=ld/jtag.ld
genericSTM32F103T.menu.device_variant.STM32F103TB.upload.maximum_size=131072
genericSTM32F103T.menu.device_variant.STM32F103TB.upload.maximum_data_size=20480
genericSTM32F103T.menu.upload_method.DFUUploadMethod=STM32duino bootloader
genericSTM32F103T.menu.upload_method.DFUUploadMethod.upload.protocol=maple_dfu
genericSTM32F103T.menu.upload_method.DFUUploadMethod.upload.tool=maple_upload
genericSTM32F103T.menu.upload_method.DFUUploadMethod.build.upload_flags=-DSERIAL_USB -DGENERIC_BOOTLOADER
genericSTM32F103T.menu.upload_method.DFUUploadMethod.build.vect=VECT_TAB_ADDR=0x8002000
genericSTM32F103T.menu.upload_method.DFUUploadMethod.build.ldscript=ld/bootloader_20.ld
genericSTM32F103T.menu.upload_method.DFUUploadMethod.upload.usbID=1EAF:0003
genericSTM32F103T.menu.upload_method.DFUUploadMethod.upload.altID=2
genericSTM32F103T.menu.upload_method.serialMethod=Serial
genericSTM32F103T.menu.upload_method.serialMethod.upload.protocol=maple_serial
genericSTM32F103T.menu.upload_method.serialMethod.upload.tool=serial_upload
genericSTM32F103T.menu.upload_method.serialMethod.build.upload_flags=-DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1
genericSTM32F103T.menu.upload_method.STLinkMethod=STLink
genericSTM32F103T.menu.upload_method.STLinkMethod.upload.protocol=STLink
genericSTM32F103T.menu.upload_method.STLinkMethod.upload.tool=stlink_upload
genericSTM32F103T.menu.upload_method.STLinkMethod.build.upload_flags=-DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1 -DSERIAL_USB -DGENERIC_BOOTLOADER
genericSTM32F103T.menu.upload_method.BMPMethod=BMP (Black Magic Probe)
genericSTM32F103T.menu.upload_method.BMPMethod.upload.protocol=gdb_bmp
genericSTM32F103T.menu.upload_method.BMPMethod.upload.tool=bmp_upload
genericSTM32F103T.menu.upload_method.BMPMethod.build.upload_flags=-DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG
genericSTM32F103T.menu.cpu_speed.speed_72mhz=72Mhz (Normal)
genericSTM32F103T.menu.cpu_speed.speed_72mhz.build.f_cpu=72000000L
genericSTM32F103T.menu.cpu_speed.speed_48mhz=48Mhz (Slow - with USB)
genericSTM32F103T.menu.cpu_speed.speed_48mhz.build.f_cpu=48000000L
genericSTM32F103T.menu.cpu_speed.speed_128mhz=Overclocked 128Mhz NO USB SERIAL. MANUAL RESET NEEDED TO UPLOAD
genericSTM32F103T.menu.cpu_speed.speed_128mhz.build.f_cpu=128000000L
#-- Optimizations
genericSTM32F103T.menu.opt.osstd=Smallest (default)
#genericSTM32F103T.menu.opt.oslto=Smallest Code with LTO
#genericSTM32F103T.menu.opt.oslto.build.flags.optimize=-Os -flto
#genericSTM32F103T.menu.opt.oslto.build.flags.ldspecs=-flto
genericSTM32F103T.menu.opt.o1std=Fast (-O1)
genericSTM32F103T.menu.opt.o1std.build.flags.optimize=-O1
genericSTM32F103T.menu.opt.o1std.build.flags.ldspecs=
#genericSTM32F103T.menu.opt.o1lto=Fast (-O1) with LTO
#genericSTM32F103T.menu.opt.o1lto.build.flags.optimize=-O1 -flto
#genericSTM32F103T.menu.opt.o1lto.build.flags.ldspecs=-flto
genericSTM32F103T.menu.opt.o2std=Faster (-O2)
genericSTM32F103T.menu.opt.o2std.build.flags.optimize=-O2
genericSTM32F103T.menu.opt.o2std.build.flags.ldspecs=
#genericSTM32F103T.menu.opt.o2lto=Faster (-O2) with LTO
#genericSTM32F103T.menu.opt.o2lto.build.flags.optimize=-O2 -flto
#genericSTM32F103T.menu.opt.o2lto.build.flags.ldspecs=-flto
genericSTM32F103T.menu.opt.o3std=Fastest (-O3)
genericSTM32F103T.menu.opt.o3std.build.flags.optimize=-O3
genericSTM32F103T.menu.opt.o3std.build.flags.ldspecs=
#genericSTM32F103T.menu.opt.o3lto=Fastest (-O3) with LTO
#genericSTM32F103T.menu.opt.o3lto.build.flags.optimize=-O3 -flto
#genericSTM32F103T.menu.opt.o3lto.build.flags.ldspecs=-flto
genericSTM32F103T.menu.opt.ogstd=Debug (-g)
genericSTM32F103T.menu.opt.ogstd.build.flags.optimize=-Og
genericSTM32F103T.menu.opt.ogstd.build.flags.ldspecs=
########################### Generic STM32F103V ###########################
genericSTM32F103V.name=Generic STM32F103V series
genericSTM32F103V.vid.0=0x1EAF
genericSTM32F103V.pid.0=0x0004
#genericSTM32F103V.build.variant=generic_stm32f103v
genericSTM32F103V.build.vect=VECT_TAB_ADDR=0x8000000
genericSTM32F103V.build.core=maple
genericSTM32F103V.build.board=GENERIC_STM32F103V
genericSTM32F103V.upload.use_1200bps_touch=false
genericSTM32F103V.upload.file_type=bin
genericSTM32F103V.upload.auto_reset=true
genericSTM32F103V.upload.tool=maple_upload
genericSTM32F103V.upload.protocol=maple_dfu
genericSTM32F103V.build.error_led_port=GPIOE
genericSTM32F103V.build.error_led_pin=6
genericSTM32F103V.menu.device_variant.STM32F103VB=STM32F103VB
genericSTM32F103V.menu.device_variant.STM32F103VB.build.variant=generic_stm32f103vb
genericSTM32F103V.menu.device_variant.STM32F103VB.build.cpu_flags=-DMCU_STM32F103VB
genericSTM32F103V.menu.device_variant.STM32F103VB.upload.maximum_size=131072
genericSTM32F103V.menu.device_variant.STM32F103VB.upload.maximum_data_size=20480
genericSTM32F103V.menu.device_variant.STM32F103VB.build.ldscript=ld/stm32f103vb.ld
genericSTM32F103V.menu.device_variant.STM32F103VC=STM32F103VC
genericSTM32F103V.menu.device_variant.STM32F103VC.build.variant=generic_stm32f103v
genericSTM32F103V.menu.device_variant.STM32F103VC.build.cpu_flags=-DMCU_STM32F103VC
genericSTM32F103V.menu.device_variant.STM32F103VC.upload.maximum_size=262144
genericSTM32F103V.menu.device_variant.STM32F103VC.upload.maximum_data_size=49152
genericSTM32F103V.menu.device_variant.STM32F103VC.build.ldscript=ld/stm32f103vc.ld
genericSTM32F103V.menu.device_variant.STM32F103VD=STM32F103VD
genericSTM32F103V.menu.device_variant.STM32F103VD.build.variant=generic_stm32f103v
genericSTM32F103V.menu.device_variant.STM32F103VD.build.cpu_flags=-DMCU_STM32F103VD
genericSTM32F103V.menu.device_variant.STM32F103VD.upload.maximum_size=393216
genericSTM32F103V.menu.device_variant.STM32F103VD.upload.maximum_data_size=65536
genericSTM32F103V.menu.device_variant.STM32F103VD.build.ldscript=ld/stm32f103vd.ld
genericSTM32F103V.menu.device_variant.STM32F103VE=STM32F103VE
genericSTM32F103V.menu.device_variant.STM32F103VE.build.variant=generic_stm32f103v
genericSTM32F103V.menu.device_variant.STM32F103VE.build.cpu_flags=-DMCU_STM32F103VE
genericSTM32F103V.menu.device_variant.STM32F103VE.upload.maximum_size=524288
genericSTM32F103V.menu.device_variant.STM32F103VE.upload.maximum_data_size=65536
genericSTM32F103V.menu.device_variant.STM32F103VE.build.ldscript=ld/stm32f103ve.ld
genericSTM32F103V.menu.upload_method.DFUUploadMethod=STM32duino bootloader
genericSTM32F103V.menu.upload_method.DFUUploadMethod.upload.protocol=maple_dfu
genericSTM32F103V.menu.upload_method.DFUUploadMethod.upload.tool=maple_upload
genericSTM32F103V.menu.upload_method.DFUUploadMethod.build.upload_flags=-DSERIAL_USB -DGENERIC_BOOTLOADER
genericSTM32F103V.menu.upload_method.DFUUploadMethod.build.vect=VECT_TAB_ADDR=0x8002000
genericSTM32F103V.menu.upload_method.DFUUploadMethod.build.ldscript=ld/stm32f103veDFU.ld
genericSTM32F103V.menu.upload_method.DFUUploadMethod.upload.usbID=1EAF:0003
genericSTM32F103V.menu.upload_method.DFUUploadMethod.upload.altID=2
genericSTM32F103V.menu.upload_method.serialMethod=Serial
genericSTM32F103V.menu.upload_method.serialMethod.upload.protocol=maple_serial
genericSTM32F103V.menu.upload_method.serialMethod.upload.tool=serial_upload
genericSTM32F103V.menu.upload_method.serialMethod.build.upload_flags=-DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1
genericSTM32F103V.menu.upload_method.STLinkMethod=STLink
genericSTM32F103V.menu.upload_method.STLinkMethod.upload.protocol=STLink
genericSTM32F103V.menu.upload_method.STLinkMethod.upload.tool=stlink_upload
genericSTM32F103V.menu.upload_method.STLinkMethod.build.upload_flags=-DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1 -DSERIAL_USB -DGENERIC_BOOTLOADER
genericSTM32F103V.menu.upload_method.BMPMethod=BMP (Black Magic Probe)
genericSTM32F103V.menu.upload_method.BMPMethod.upload.protocol=gdb_bmp
genericSTM32F103V.menu.upload_method.BMPMethod.upload.tool=bmp_upload
genericSTM32F103V.menu.upload_method.BMPMethod.build.upload_flags=-DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG
genericSTM32F103V.menu.cpu_speed.speed_72mhz=72Mhz (Normal)
genericSTM32F103V.menu.cpu_speed.speed_72mhz.build.f_cpu=72000000L
genericSTM32F103V.menu.cpu_speed.speed_48mhz=48Mhz (Slow - with USB)
genericSTM32F103V.menu.cpu_speed.speed_48mhz.build.f_cpu=48000000L
genericSTM32F103V.menu.cpu_speed.speed_128mhz=Overclocked 128Mhz NO USB SERIAL. MANUAL RESET NEEDED TO UPLOAD
genericSTM32F103V.menu.cpu_speed.speed_128mhz.build.f_cpu=128000000L
#-- Optimizations
genericSTM32F103V.menu.opt.osstd=Smallest (default)
#genericSTM32F103V.menu.opt.oslto=Smallest Code with LTO
#genericSTM32F103V.menu.opt.oslto.build.flags.optimize=-Os -flto
#genericSTM32F103V.menu.opt.oslto.build.flags.ldspecs=-flto
genericSTM32F103V.menu.opt.o1std=Fast (-O1)
genericSTM32F103V.menu.opt.o1std.build.flags.optimize=-O1
genericSTM32F103V.menu.opt.o1std.build.flags.ldspecs=
#genericSTM32F103V.menu.opt.o1lto=Fast (-O1) with LTO
#genericSTM32F103V.menu.opt.o1lto.build.flags.optimize=-O1 -flto
#genericSTM32F103V.menu.opt.o1lto.build.flags.ldspecs=-flto
genericSTM32F103V.menu.opt.o2std=Faster (-O2)
genericSTM32F103V.menu.opt.o2std.build.flags.optimize=-O2
genericSTM32F103V.menu.opt.o2std.build.flags.ldspecs=
#genericSTM32F103V.menu.opt.o2lto=Faster (-O2) with LTO
#genericSTM32F103V.menu.opt.o2lto.build.flags.optimize=-O2 -flto
#genericSTM32F103V.menu.opt.o2lto.build.flags.ldspecs=-flto
genericSTM32F103V.menu.opt.o3std=Fastest (-O3)
genericSTM32F103V.menu.opt.o3std.build.flags.optimize=-O3
genericSTM32F103V.menu.opt.o3std.build.flags.ldspecs=
#genericSTM32F103V.menu.opt.o3lto=Fastest (-O3) with LTO
#genericSTM32F103V.menu.opt.o3lto.build.flags.optimize=-O3 -flto
#genericSTM32F103V.menu.opt.o3lto.build.flags.ldspecs=-flto
genericSTM32F103V.menu.opt.ogstd=Debug (-g)
genericSTM32F103V.menu.opt.ogstd.build.flags.optimize=-Og
genericSTM32F103V.menu.opt.ogstd.build.flags.ldspecs=
########################### Generic STM32F103Z ###########################
genericSTM32F103Z.name=Generic STM32F103Z series
genericSTM32F103Z.vid.0=0x1EAF
genericSTM32F103Z.pid.0=0x0004
genericSTM32F103Z.build.variant=generic_stm32f103z
genericSTM32F103Z.build.vect=VECT_TAB_ADDR=0x8000000
genericSTM32F103Z.build.core=maple
genericSTM32F103Z.build.board=GENERIC_STM32F103Z
genericSTM32F103Z.upload.use_1200bps_touch=false
genericSTM32F103Z.upload.file_type=bin
genericSTM32F103Z.upload.auto_reset=true
genericSTM32F103Z.upload.tool=maple_upload
genericSTM32F103Z.upload.protocol=maple_dfu
genericSTM32F103Z.menu.device_variant.STM32F103ZC=STM32F103ZC
genericSTM32F103Z.menu.device_variant.STM32F103ZC.build.cpu_flags=-DMCU_STM32F103ZC
genericSTM32F103Z.menu.device_variant.STM32F103ZC.upload.maximum_size=262144
genericSTM32F103Z.menu.device_variant.STM32F103ZC.upload.maximum_data_size=49152
genericSTM32F103Z.menu.device_variant.STM32F103ZC.build.ldscript=ld/stm32f103zc.ld
genericSTM32F103Z.menu.device_variant.STM32F103ZD=STM32F103ZD
genericSTM32F103Z.menu.device_variant.STM32F103ZD.build.cpu_flags=-DMCU_STM32F103ZD
genericSTM32F103Z.menu.device_variant.STM32F103ZD.upload.maximum_size=393216
genericSTM32F103Z.menu.device_variant.STM32F103ZD.upload.maximum_data_size=65536
genericSTM32F103Z.menu.device_variant.STM32F103ZD.build.ldscript=ld/stm32f103zd.ld
genericSTM32F103Z.menu.device_variant.STM32F103ZE=STM32F103ZE
genericSTM32F103Z.menu.device_variant.STM32F103ZE.build.cpu_flags=-DMCU_STM32F103ZE
genericSTM32F103Z.menu.device_variant.STM32F103ZE.upload.maximum_size=524288
genericSTM32F103Z.menu.device_variant.STM32F103ZE.upload.maximum_data_size=65536
genericSTM32F103Z.menu.device_variant.STM32F103ZE.build.ldscript=ld/stm32f103ze.ld
genericSTM32F103Z.menu.upload_method.DFUUploadMethod=STM32duino bootloader
genericSTM32F103Z.menu.upload_method.DFUUploadMethod.upload.protocol=maple_dfu
genericSTM32F103Z.menu.upload_method.DFUUploadMethod.upload.tool=maple_upload
genericSTM32F103Z.menu.upload_method.DFUUploadMethod.build.upload_flags=-DSERIAL_USB -DGENERIC_BOOTLOADER
genericSTM32F103Z.menu.upload_method.DFUUploadMethod.build.vect=VECT_TAB_ADDR=0x8002000
genericSTM32F103Z.menu.upload_method.DFUUploadMethod.build.ldscript=ld/stm32f103z_dfu.ld
genericSTM32F103Z.menu.upload_method.DFUUploadMethod.upload.usbID=1EAF:0003
genericSTM32F103Z.menu.upload_method.DFUUploadMethod.upload.altID=2
genericSTM32F103Z.menu.upload_method.serialMethod=Serial
genericSTM32F103Z.menu.upload_method.serialMethod.upload.protocol=maple_serial
genericSTM32F103Z.menu.upload_method.serialMethod.upload.tool=serial_upload
genericSTM32F103Z.menu.upload_method.serialMethod.build.upload_flags=-DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1
genericSTM32F103Z.menu.upload_method.STLinkMethod=STLink
genericSTM32F103Z.menu.upload_method.STLinkMethod.upload.protocol=STLink
genericSTM32F103Z.menu.upload_method.STLinkMethod.upload.tool=stlink_upload
genericSTM32F103Z.menu.upload_method.STLinkMethod.build.upload_flags=-DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1 -DSERIAL_USB -DGENERIC_BOOTLOADER
genericSTM32F103Z.menu.upload_method.BMPMethod=BMP (Black Magic Probe)
genericSTM32F103Z.menu.upload_method.BMPMethod.upload.protocol=gdb_bmp
genericSTM32F103Z.menu.upload_method.BMPMethod.upload.tool=bmp_upload
genericSTM32F103Z.menu.upload_method.BMPMethod.build.upload_flags=-DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG
genericSTM32F103Z.menu.cpu_speed.speed_72mhz=72Mhz (Normal)
genericSTM32F103Z.menu.cpu_speed.speed_72mhz.build.f_cpu=72000000L
genericSTM32F103Z.menu.cpu_speed.speed_48mhz=48Mhz (Slow - with USB)
genericSTM32F103Z.menu.cpu_speed.speed_48mhz.build.f_cpu=48000000L
genericSTM32F103Z.menu.cpu_speed.speed_128mhz=Overclocked 128Mhz NO USB SERIAL. MANUAL RESET NEEDED TO UPLOAD
genericSTM32F103Z.menu.cpu_speed.speed_128mhz.build.f_cpu=128000000L
#-- Optimizations
genericSTM32F103Z.menu.opt.osstd=Smallest (default)
#genericSTM32F103Z.menu.opt.oslto=Smallest Code with LTO
#genericSTM32F103Z.menu.opt.oslto.build.flags.optimize=-Os -flto
#genericSTM32F103Z.menu.opt.oslto.build.flags.ldspecs=-flto
genericSTM32F103Z.menu.opt.o1std=Fast (-O1)
genericSTM32F103Z.menu.opt.o1std.build.flags.optimize=-O1
genericSTM32F103Z.menu.opt.o1std.build.flags.ldspecs=
#genericSTM32F103Z.menu.opt.o1lto=Fast (-O1) with LTO
#genericSTM32F103Z.menu.opt.o1lto.build.flags.optimize=-O1 -flto
#genericSTM32F103Z.menu.opt.o1lto.build.flags.ldspecs=-flto
genericSTM32F103Z.menu.opt.o2std=Faster (-O2)
genericSTM32F103Z.menu.opt.o2std.build.flags.optimize=-O2
genericSTM32F103Z.menu.opt.o2std.build.flags.ldspecs=
#genericSTM32F103Z.menu.opt.o2lto=Faster (-O2) with LTO
#genericSTM32F103Z.menu.opt.o2lto.build.flags.optimize=-O2 -flto
#genericSTM32F103Z.menu.opt.o2lto.build.flags.ldspecs=-flto
genericSTM32F103Z.menu.opt.o3std=Fastest (-O3)
genericSTM32F103Z.menu.opt.o3std.build.flags.optimize=-O3
genericSTM32F103Z.menu.opt.o3std.build.flags.ldspecs=
#genericSTM32F103Z.menu.opt.o3lto=Fastest (-O3) with LTO
#genericSTM32F103Z.menu.opt.o3lto.build.flags.optimize=-O3 -flto
#genericSTM32F103Z.menu.opt.o3lto.build.flags.ldspecs=-flto
genericSTM32F103Z.menu.opt.ogstd=Debug (-g)
genericSTM32F103Z.menu.opt.ogstd.build.flags.optimize=-Og
genericSTM32F103Z.menu.opt.ogstd.build.flags.ldspecs=
###################### HYTiny STM32F103T ########################################
hytiny-stm32f103t.name=HYTiny STM32F103TB
hytiny-stm32f103t.vid.0=0x1EAF
hytiny-stm32f103t.pid.0=0x0004
hytiny-stm32f103t.build.variant=hytiny_stm32f103t
hytiny-stm32f103t.build.vect=VECT_TAB_ADDR=0x8000000
hytiny-stm32f103t.build.core=maple
hytiny-stm32f103t.build.board=HYTINY_STM32F103T
hytiny-stm32f103t.upload.use_1200bps_touch=false
hytiny-stm32f103t.upload.file_type=bin
hytiny-stm32f103t.upload.auto_reset=true
hytiny-stm32f103t.build.cpu_flags=-DMCU_STM32F103CB
hytiny-stm32f103t.build.ldscript=ld/jtag.ld
hytiny-stm32f103t.upload.maximum_size=131072
hytiny-stm32f103t.upload.maximum_data_size=20480
hytiny-stm32f103t.menu.upload_method.DFUUploadMethod=STM32duino bootloader
hytiny-stm32f103t.menu.upload_method.DFUUploadMethod.upload.protocol=maple_dfu
hytiny-stm32f103t.menu.upload_method.DFUUploadMethod.upload.tool=maple_upload
hytiny-stm32f103t.menu.upload_method.DFUUploadMethod.build.upload_flags=-DSERIAL_USB
hytiny-stm32f103t.menu.upload_method.DFUUploadMethod.build.vect=VECT_TAB_ADDR=0x8002000
hytiny-stm32f103t.menu.upload_method.DFUUploadMethod.build.ldscript=ld/bootloader_20.ld
hytiny-stm32f103t.menu.upload_method.DFUUploadMethod.upload.usbID=1EAF:0003
hytiny-stm32f103t.menu.upload_method.DFUUploadMethod.upload.altID=2
hytiny-stm32f103t.menu.upload_method.serialMethod=Serial
hytiny-stm32f103t.menu.upload_method.serialMethod.upload.protocol=maple_serial
hytiny-stm32f103t.menu.upload_method.serialMethod.upload.tool=serial_upload
hytiny-stm32f103t.menu.upload_method.serialMethod.build.upload_flags=-DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1
hytiny-stm32f103t.menu.upload_method.STLinkMethod=STLink
hytiny-stm32f103t.menu.upload_method.STLinkMethod.upload.protocol=STLink
hytiny-stm32f103t.menu.upload_method.STLinkMethod.upload.tool=stlink_upload
hytiny-stm32f103t.menu.upload_method.STLinkMethod.build.upload_flags=-DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1 -DSERIAL_USB -DGENERIC_BOOTLOADER
hytiny-stm32f103t.menu.upload_method.BMPMethod=BMP (Black Magic Probe)
hytiny-stm32f103t.menu.upload_method.BMPMethod.upload.protocol=gdb_bmp
hytiny-stm32f103t.menu.upload_method.BMPMethod.upload.tool=bmp_upload
hytiny-stm32f103t.menu.upload_method.BMPMethod.build.upload_flags=-DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG
hytiny-stm32f103t.menu.upload_method.jlinkMethod=JLink
hytiny-stm32f103t.menu.upload_method.jlinkMethod.upload.protocol=jlink
hytiny-stm32f103t.menu.upload_method.jlinkMethod.upload.tool=jlink_upload
hytiny-stm32f103t.menu.upload_method.jlinkMethod.build.upload_flags=-DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1 -DSERIAL_USB -DGENERIC_BOOTLOADER
hytiny-stm32f103t.menu.cpu_speed.speed_72mhz=72Mhz (Normal)
hytiny-stm32f103t.menu.cpu_speed.speed_72mhz.build.f_cpu=72000000L
hytiny-stm32f103t.menu.cpu_speed.speed_48mhz=48Mhz (Slow - with USB)
hytiny-stm32f103t.menu.cpu_speed.speed_48mhz.build.f_cpu=48000000L
hytiny-stm32f103t.menu.cpu_speed.speed_128mhz=Overclocked 128Mhz NO USB SERIAL. MANUAL RESET NEEDED TO UPLOAD
hytiny-stm32f103t.menu.cpu_speed.speed_128mhz.build.f_cpu=128000000L
#-- Optimizations
hytiny-stm32f103t.menu.opt.osstd=Smallest (default)
#hytiny-stm32f103t.menu.opt.oslto=Smallest Code with LTO
#hytiny-stm32f103t.menu.opt.oslto.build.flags.optimize=-Os -flto
#hytiny-stm32f103t.menu.opt.oslto.build.flags.ldspecs=-flto
hytiny-stm32f103t.menu.opt.o1std=Fast (-O1)
hytiny-stm32f103t.menu.opt.o1std.build.flags.optimize=-O1
hytiny-stm32f103t.menu.opt.o1std.build.flags.ldspecs=
#hytiny-stm32f103t.menu.opt.o1lto=Fast (-O1) with LTO
#hytiny-stm32f103t.menu.opt.o1lto.build.flags.optimize=-O1 -flto
#hytiny-stm32f103t.menu.opt.o1lto.build.flags.ldspecs=-flto
hytiny-stm32f103t.menu.opt.o2std=Faster (-O2)
hytiny-stm32f103t.menu.opt.o2std.build.flags.optimize=-O2
hytiny-stm32f103t.menu.opt.o2std.build.flags.ldspecs=
#hytiny-stm32f103t.menu.opt.o2lto=Faster (-O2) with LTO
#hytiny-stm32f103t.menu.opt.o2lto.build.flags.optimize=-O2 -flto
#hytiny-stm32f103t.menu.opt.o2lto.build.flags.ldspecs=-flto
hytiny-stm32f103t.menu.opt.o3std=Fastest (-O3)
hytiny-stm32f103t.menu.opt.o3std.build.flags.optimize=-O3
hytiny-stm32f103t.menu.opt.o3std.build.flags.ldspecs=
#hytiny-stm32f103t.menu.opt.o3lto=Fastest (-O3) with LTO
#hytiny-stm32f103t.menu.opt.o3lto.build.flags.optimize=-O3 -flto
#hytiny-stm32f103t.menu.opt.o3lto.build.flags.ldspecs=-flto
hytiny-stm32f103t.menu.opt.ogstd=Debug (-g)
hytiny-stm32f103t.menu.opt.ogstd.build.flags.optimize=-Og
hytiny-stm32f103t.menu.opt.ogstd.build.flags.ldspecs=
########################### STM32VLD to FLASH ###########################
STM32VLD.name=STM32VLD to FLASH
#STM32VLD.vid.0=0x1EAF
#STM32VLD.pid.0=0x0004
STM32VLD.build.vect=VECT_TAB_ADDR=0x8000000
STM32VLD.build.core=maple
STM32VLD.build.board=STM32VLD
STM32VLD.build.variant=STM32VLD
STM32VLD.build.ldscript=ld/jtag.ld
STM32VLD.build.family=cortex-m3
STM32VLD.build.f_cpu=24000000L
STM32VLD.upload.use_1200bps_touch=false
STM32VLD.upload.file_type=bin
STM32VLD.upload.auto_reset=true
STM32VLD.upload.params.quiet=no
STM32VLD.build.cpu_flags=-DMCU_STM32F100RB
STM32VLD.menu.upload_method.STLinkMethod=STLink
STM32VLD.menu.upload_method.STLinkMethod.upload.protocol=STLink
STM32VLD.menu.upload_method.STLinkMethod.upload.tool=stlink_upload
STM32VLD.menu.upload_method.STLinkMethod.build.upload_flags=-DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG
STM32VLD.menu.cpu_speed.speed_72mhz=72Mhz (Normal)
STM32VLD.menu.cpu_speed.speed_72mhz.build.f_cpu=72000000L
STM32VLD.menu.cpu_speed.speed_48mhz=48Mhz (Slow - with USB)
STM32VLD.menu.cpu_speed.speed_48mhz.build.f_cpu=48000000L
STM32VLD.menu.cpu_speed.speed_128mhz=Overclocked 128Mhz NO USB SERIAL. MANUAL RESET NEEDED TO UPLOAD
STM32VLD.menu.cpu_speed.speed_128mhz.build.f_cpu=128000000L
#-- Optimizations
STM32VLD.menu.opt.osstd=Smallest (default)
#STM32VLD.menu.opt.oslto=Smallest Code with LTO
#STM32VLD.menu.opt.oslto.build.flags.optimize=-Os -flto
#STM32VLD.menu.opt.oslto.build.flags.ldspecs=-flto
STM32VLD.menu.opt.o1std=Fast (-O1)
STM32VLD.menu.opt.o1std.build.flags.optimize=-O1
STM32VLD.menu.opt.o1std.build.flags.ldspecs=
#STM32VLD.menu.opt.o1lto=Fast (-O1) with LTO
#STM32VLD.menu.opt.o1lto.build.flags.optimize=-O1 -flto
#STM32VLD.menu.opt.o1lto.build.flags.ldspecs=-flto
STM32VLD.menu.opt.o2std=Faster (-O2)
STM32VLD.menu.opt.o2std.build.flags.optimize=-O2
STM32VLD.menu.opt.o2std.build.flags.ldspecs=
#STM32VLD.menu.opt.o2lto=Faster (-O2) with LTO
#STM32VLD.menu.opt.o2lto.build.flags.optimize=-O2 -flto
#STM32VLD.menu.opt.o2lto.build.flags.ldspecs=-flto
STM32VLD.menu.opt.o3std=Fastest (-O3)
STM32VLD.menu.opt.o3std.build.flags.optimize=-O3
STM32VLD.menu.opt.o3std.build.flags.ldspecs=
#STM32VLD.menu.opt.o3lto=Fastest (-O3) with LTO
#STM32VLD.menu.opt.o3lto.build.flags.optimize=-O3 -flto
#STM32VLD.menu.opt.o3lto.build.flags.ldspecs=-flto
STM32VLD.menu.opt.ogstd=Debug (-g)
STM32VLD.menu.opt.ogstd.build.flags.optimize=-Og
STM32VLD.menu.opt.ogstd.build.flags.ldspecs=
- Contact:
Re: Need to change Vector table Address
The map file is located in the same directory where the BIN file is.
Attach it as TXT file.
Archive member included because of file (symbol)
C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(exc.S.o)
(__exc_hardfault)
C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(isrs.S.o)
(__stm32reservedexception7)
C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(vector_table.S.o)
(__stm32_vector_table)
C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(adc.c.o)
C:\Users\AMP_SAI\Desktop\hexfile\core\wirish\boards.cpp.o (adc_set_sample_rate)
C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(adc_f1.c.o)
C:\Users\AMP_SAI\Desktop\hexfile\core\wirish\boards.cpp.o (adc_set_prescaler)
C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(flash.c.o)
C:\Users\AMP_SAI\Desktop\hexfile\core\wirish\boards.cpp.o (flash_set_latency)
C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(gpio_f1.c.o)
C:\Users\AMP_SAI\Desktop\hexfile\core\wirish\boards_setup.cpp.o (gpio_init_all)
C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(nvic.c.o)
C:\Users\AMP_SAI\Desktop\hexfile\core\wirish\boards.cpp.o (nvic_init)
C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(rcc.c.o)
C:\Users\AMP_SAI\Desktop\hexfile\core\wirish\boards.cpp.o (rcc_switch_sysclk)
C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(rcc_f1.c.o)
C:\Users\AMP_SAI\Desktop\hexfile\core\wirish\boards.cpp.o (rcc_configure_pll)
C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(systick.c.o)
C:\Users\AMP_SAI\Desktop\hexfile\core\wirish\boards.cpp.o (systick_init)
C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(timer.c.o)
C:\Users\AMP_SAI\Desktop\hexfile\core\wirish\boards.cpp.o (timer_foreach)
C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(usart_f1.c.o)
C:\Users\AMP_SAI\Desktop\hexfile\core\board.cpp.o (UART5)
C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(usart_private.c.o)
C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(usart_f1.c.o) (_usart_clock_freq)
C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(util.c.o)
C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(exc.S.o) (__error)
C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(HardwareSerial.cpp.o)
C:\Users\AMP_SAI\Desktop\hexfile\core\board.cpp.o (HardwareSerial::HardwareSerial(usart_dev*, unsigned char, unsigned char))
C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(Print.cpp.o)
C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(HardwareSerial.cpp.o) (Print::write(char const*))
C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(cxxabi-compat.cpp.o)
C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(HardwareSerial.cpp.o) (__cxa_pure_virtual)
C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(main.cpp.o)
(main)
C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(wirish_digital_f1.cpp.o)
C:\Users\AMP_SAI\Desktop\hexfile\sketch\usermks.ino.cpp.o (pinMode(unsigned char, WiringPinMode))
C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(usb_serial.cpp.o)
C:\Users\AMP_SAI\Desktop\hexfile\core\wirish\boards_setup.cpp.o (USBSerial::begin())
C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(wirish_digital.cpp.o)
C:\Users\AMP_SAI\Desktop\hexfile\sketch\usermks.ino.cpp.o (digitalWrite(unsigned char, unsigned char))
C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(wirish_time.cpp.o)
C:\Users\AMP_SAI\Desktop\hexfile\sketch\usermks.ino.cpp.o (delay(unsigned long))
C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(gpio.c.o)
C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(gpio_f1.c.o) (gpio_init)
C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(iwdg.c.o)
C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(usb_serial.cpp.o) (iwdg_init)
C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(usart.c.o)
C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(HardwareSerial.cpp.o) (usart_init)
C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(usb.c.o)
C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(usb_serial.cpp.o) (USBLIB)
C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(usb_cdcacm.c.o)
C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(usb_serial.cpp.o) (usb_cdcacm_set_hooks)
C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(usb_reg_map.c.o)
C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(usb_cdcacm.c.o) (usb_copy_to_pma)
C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(usb_core.c.o)
C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(usb_cdcacm.c.o) (Standard_GetDescriptorData)
C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(usb_init.c.o)
C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(usb.c.o) (pInformation)
C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(usb_mem.c.o)
C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(usb_core.c.o) (UserToPMABufferCopy)
C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(usb_regs.c.o)
C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(usb_core.c.o) (SetEPTxStatus)
c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/armv7-m\libgcc.a(_arm_addsubdf3.o)
C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(Print.cpp.o) (__aeabi_dsub)
c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/armv7-m\libgcc.a(_arm_muldivdf3.o)
C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(Print.cpp.o) (__aeabi_dmul)
c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/armv7-m\libgcc.a(_arm_cmpdf2.o)
C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(Print.cpp.o) (__aeabi_dcmplt)
c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/armv7-m\libgcc.a(_arm_fixdfsi.o)
C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(Print.cpp.o) (__aeabi_d2iz)
c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/armv7-m\libgcc.a(_aeabi_uldivmod.o)
C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(Print.cpp.o) (__aeabi_uldivmod)
c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/armv7-m\libgcc.a(_fixdfdi.o)
C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(Print.cpp.o) (__aeabi_d2lz)
c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/armv7-m\libgcc.a(_fixunsdfdi.o)
c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/armv7-m\libgcc.a(_fixdfdi.o) (__aeabi_d2ulz)
c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/armv7-m\libgcc.a(bpabi.o)
c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/armv7-m\libgcc.a(_aeabi_uldivmod.o) (__gnu_uldivmod_helper)
c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/armv7-m\libgcc.a(_dvmd_tls.o)
c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/armv7-m\libgcc.a(_aeabi_uldivmod.o) (__aeabi_ldiv0)
c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/armv7-m\libgcc.a(_arm_fixunsdfsi.o)
c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/armv7-m\libgcc.a(_fixunsdfdi.o) (__aeabi_d2uiz)
c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/armv7-m\libgcc.a(_divdi3.o)
c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/armv7-m\libgcc.a(bpabi.o) (__divdi3)
c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/armv7-m\libgcc.a(_udivdi3.o)
c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/armv7-m\libgcc.a(bpabi.o) (__udivdi3)
c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv7-m\libc.a(lib_a-errno.o)
C:\Users\AMP_SAI\Desktop\hexfile\core\wirish\syscalls.c.o (__errno)
c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv7-m\libc.a(lib_a-exit.o)
c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv7-m/crt0.o (exit)
c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv7-m\libc.a(lib_a-impure.o)
c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv7-m\libc.a(lib_a-exit.o) (_global_impure_ptr)
c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv7-m\libc.a(lib_a-init.o)
c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv7-m/crt0.o (__libc_init_array)
c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv7-m\libc.a(lib_a-memset.o)
c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv7-m/crt0.o (memset)
c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv7-m\libc.a(lib_a-strlen.o)
C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(usb_serial.cpp.o) (strlen)
c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv7-m\libc.a(lib_a-__call_atexit.o)
c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv7-m\libc.a(lib_a-exit.o) (__call_exitprocs)
c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv7-m\libc.a(lib_a-atexit.o)
c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv7-m\libc.a(lib_a-__call_atexit.o) (atexit)
c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv7-m\libc.a(lib_a-fini.o)
c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv7-m\libc.a(lib_a-__call_atexit.o) (__libc_fini_array)
c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv7-m\libc.a(lib_a-__atexit.o)
c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv7-m\libc.a(lib_a-atexit.o) (__register_exitproc)
Allocating common symbols
Common symbol size file
SaveRState 0x2 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(usb.c.o)
SaveState 0x2 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(usb_init.c.o)
pProperty 0x4 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(usb_init.c.o)
EPindex 0x1 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(usb_init.c.o)
SaveTState 0x2 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(usb.c.o)
systick_uptime_millis
0x4 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(systick.c.o)
Device_Info 0x1c C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(usb_init.c.o)
pUser_Standard_Requests
StatusInfo 0x2 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(usb_core.c.o)
pInformation 0x4 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(usb_init.c.o)
ResumeS 0x2 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(usb.c.o)
wInterrupt_Mask 0x2 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(usb_init.c.o)
Discarded input sections
.text 0x00000000 0x0 c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/armv7-m/crti.o
.data 0x00000000 0x0 c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/armv7-m/crti.o
.bss 0x00000000 0x0 c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/armv7-m/crti.o
.data 0x00000000 0x4 c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/armv7-m/crtbegin.o
.text 0x00000000 0x74 c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv7-m/crt0.o
.data 0x00000000 0x0 c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv7-m/crt0.o
.bss 0x00000000 0x0 c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv7-m/crt0.o
.ARM.extab 0x00000000 0x0 c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv7-m/crt0.o
.ARM.exidx 0x00000000 0x8 c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv7-m/crt0.o
.text 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile\sketch\usermks.ino.cpp.o
.data 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile\sketch\usermks.ino.cpp.o
.bss 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile\sketch\usermks.ino.cpp.o
.data 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile\core\wirish\start.S.o
.bss 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile\core\wirish\start.S.o
.ARM.extab 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile\core\wirish\start.S.o
.text 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile\core\wirish\start_c.c.o
.data 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile\core\wirish\start_c.c.o
.bss 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile\core\wirish\start_c.c.o
.text 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile\core\wirish\syscalls.c.o
.data 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile\core\wirish\syscalls.c.o
.bss 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile\core\wirish\syscalls.c.o
.text._sbrk 0x00000000 0x44 C:\Users\AMP_SAI\Desktop\hexfile\core\wirish\syscalls.c.o
.text._open 0x00000000 0x8 C:\Users\AMP_SAI\Desktop\hexfile\core\wirish\syscalls.c.o
.text._close 0x00000000 0x4 C:\Users\AMP_SAI\Desktop\hexfile\core\wirish\syscalls.c.o
.text._fstat 0x00000000 0xa C:\Users\AMP_SAI\Desktop\hexfile\core\wirish\syscalls.c.o
.text._isatty 0x00000000 0x4 C:\Users\AMP_SAI\Desktop\hexfile\core\wirish\syscalls.c.o
.text.isatty 0x00000000 0x4 C:\Users\AMP_SAI\Desktop\hexfile\core\wirish\syscalls.c.o
.text._lseek 0x00000000 0x6 C:\Users\AMP_SAI\Desktop\hexfile\core\wirish\syscalls.c.o
.text.getch 0x00000000 0x4 C:\Users\AMP_SAI\Desktop\hexfile\core\wirish\syscalls.c.o
.text._read 0x00000000 0xe C:\Users\AMP_SAI\Desktop\hexfile\core\wirish\syscalls.c.o
.text.putch 0x00000000 0x2 C:\Users\AMP_SAI\Desktop\hexfile\core\wirish\syscalls.c.o
.text.cgets 0x00000000 0x78 C:\Users\AMP_SAI\Desktop\hexfile\core\wirish\syscalls.c.o
.text._write 0x00000000 0x1a C:\Users\AMP_SAI\Desktop\hexfile\core\wirish\syscalls.c.o
.text.fgets 0x00000000 0xc C:\Users\AMP_SAI\Desktop\hexfile\core\wirish\syscalls.c.o
.bss.pbreak.4440
.text 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile\core\board.cpp.o
.data 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile\core\board.cpp.o
.bss 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile\core\board.cpp.o
.USER_FLASH 0x00000000 0x2a C:\Users\AMP_SAI\Desktop\hexfile\core\board.cpp.o
.text 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile\core\wirish\boards.cpp.o
.data 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile\core\wirish\boards.cpp.o
.bss 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile\core\wirish\boards.cpp.o
.text._Z12boardUsesPinh
0x00000000 0x1c C:\Users\AMP_SAI\Desktop\hexfile\core\wirish\boards.cpp.o
.text 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile\core\wirish\boards_setup.cpp.o
.data 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile\core\wirish\boards_setup.cpp.o
.bss 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile\core\wirish\boards_setup.cpp.o
.data 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(exc.S.o)
.bss 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(exc.S.o)
.data 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(isrs.S.o)
.bss 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(isrs.S.o)
.text 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(vector_table.S.o)
.data 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(vector_table.S.o)
.bss 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(vector_table.S.o)
.text 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(adc.c.o)
.data 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(adc.c.o)
.bss 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(adc.c.o)
.text.adc_read
0x00000000 0x20 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(adc.c.o)
.text 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(adc_f1.c.o)
.data 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(adc_f1.c.o)
.bss 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(adc_f1.c.o)
.text.adc_config_gpio
0x00000000 0xa C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(adc_f1.c.o)
.text 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(flash.c.o)
.data 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(flash.c.o)
.bss 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(flash.c.o)
.text 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(gpio_f1.c.o)
.data 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(gpio_f1.c.o)
.bss 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(gpio_f1.c.o)
.text.gpio_get_mode
0x00000000 0x2e C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(gpio_f1.c.o)
.text.afio_remap
0x00000000 0x20 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(gpio_f1.c.o)
.rodata.GPIOA 0x00000000 0x4 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(gpio_f1.c.o)
.rodata.GPIOD 0x00000000 0x4 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(gpio_f1.c.o)
.rodata.GPIOE 0x00000000 0x4 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(gpio_f1.c.o)
.rodata.GPIOF 0x00000000 0x4 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(gpio_f1.c.o)
.rodata.GPIOG 0x00000000 0x4 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(gpio_f1.c.o)
.text 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(nvic.c.o)
.data 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(nvic.c.o)
.bss 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(nvic.c.o)
.text.nvic_set_vector_table
0x00000000 0x14 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(nvic.c.o)
.text 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(rcc.c.o)
.data 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(rcc.c.o)
.bss 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(rcc.c.o)
.text.rcc_is_clk_on
0x00000000 0x1e C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(rcc.c.o)
.text 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(rcc_f1.c.o)
.data 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(rcc_f1.c.o)
.bss 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(rcc_f1.c.o)
.text.rcc_clk_init
0x00000000 0x3c C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(rcc_f1.c.o)
.text 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(systick.c.o)
.data 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(systick.c.o)
.bss 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(systick.c.o)
.text.systick_disable
0x00000000 0xc C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(systick.c.o)
.text.systick_enable
.text.systick_attach_callback
.text 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(timer.c.o)
.data 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(timer.c.o)
.bss 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(timer.c.o)
.text.timer_disable
0x00000000 0x12 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(timer.c.o)
.text.timer_attach_interrupt
0x00000000 0xc0 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(timer.c.o)
.rodata.TIMER1
0x00000000 0x4 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(timer.c.o)
.rodata.TIMER2
.rodata.TIMER3
.rodata.TIMER4
.rodata.TIMER5
.rodata.TIMER6
.rodata.TIMER7
.rodata.TIMER8
.text 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(usart_f1.c.o)
.data 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(usart_f1.c.o)
.bss 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(usart_f1.c.o)
.text.usart_config_gpios_async
0x00000000 0x4a C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(usart_f1.c.o)
.text.usart_set_baud_rate
0x00000000 0x3c C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(usart_f1.c.o)
.text.usart_foreach
0x00000000 0x38 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(usart_f1.c.o)
.text 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(usart_private.c.o)
.data 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(usart_private.c.o)
.bss 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(usart_private.c.o)
.text._usart_clock_freq
0x00000000 0x24 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(usart_private.c.o)
.text 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(util.c.o)
.data 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(util.c.o)
.bss 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(util.c.o)
.text.usart_putc
0x00000000 0x1c C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(util.c.o)
.text.usart_putstr
0x00000000 0x16 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(util.c.o)
.text._fail 0x00000000 0x64 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(util.c.o)
.text.__assert_func
0x00000000 0x8 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(util.c.o)
.text.abort 0x00000000 0x1c C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(util.c.o)
.rodata.str1.1
0x00000000 0x42 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(util.c.o)
.group 0x00000000 0x8 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(HardwareSerial.cpp.o)
.text 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(HardwareSerial.cpp.o)
.data 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(HardwareSerial.cpp.o)
.bss 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(HardwareSerial.cpp.o)
.text._ZN14HardwareSerial5beginEmh
0x00000000 0x78 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(HardwareSerial.cpp.o)
0x00000000 0x6 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(HardwareSerial.cpp.o)
.text._ZN14HardwareSerial3endEv
.text._ZN14HardwareSerial17availableForWriteEv
0x00000000 0x4 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(HardwareSerial.cpp.o)
.rodata._ZTV6Stream
0x00000000 0x28 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(HardwareSerial.cpp.o)
.text 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(Print.cpp.o)
.data 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(Print.cpp.o)
.bss 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(Print.cpp.o)
.text._ZN5Print5printERK6String
0x00000000 0x10 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(Print.cpp.o)
.text._ZN5Print5printEc
0x00000000 0xa C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(Print.cpp.o)
.text._ZN5Print5printEPKc
.text._ZN5Print7printlnEv
0x00000000 0x18 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(Print.cpp.o)
.text._ZN5Print7printlnERK6String
0x00000000 0x14 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(Print.cpp.o)
.text._ZN5Print7printlnEc
.text._ZN5Print7printlnEPKc
.text._ZN5Print11printNumberEyh
0x00000000 0x84 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(Print.cpp.o)
.text._ZN5Print5printExi
0x00000000 0x40 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(Print.cpp.o)
.text._ZN5Print5printEii
0x00000000 0x12 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(Print.cpp.o)
.text._ZN5Print7printlnEii
.text._ZN5Print5printEli
.text._ZN5Print7printlnEli
0x00000000 0x1c C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(Print.cpp.o)
.text._ZN5Print7printlnExi
0x00000000 0x1a C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(Print.cpp.o)
.text._ZN5Print5printEyi
.text._ZN5Print5printEhi
.text._ZN5Print7printlnEhi
.text._ZN5Print5printEji
.text._ZN5Print7printlnEji
.text._ZN5Print5printEmi
.text._ZN5Print7printlnEmi
.text._ZN5Print7printlnEyi
.text._ZN5Print10printFloatEdh
0x00000000 0x158 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(Print.cpp.o)
.text._ZN5Print5printEdi
.text._ZN5Print7printlnEdi
.rodata._ZTV5Print
.rodata.str1.1
0x00000000 0x11 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(Print.cpp.o)
.text 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(cxxabi-compat.cpp.o)
.data 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(cxxabi-compat.cpp.o)
.bss 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(cxxabi-compat.cpp.o)
.text.__cxa_pure_virtual
0x00000000 0x2 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(cxxabi-compat.cpp.o)
.text 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(main.cpp.o)
.data 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(main.cpp.o)
.bss 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(main.cpp.o)
.text 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(wirish_digital_f1.cpp.o)
.data 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(wirish_digital_f1.cpp.o)
.bss 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(wirish_digital_f1.cpp.o)
.group 0x00000000 0x8 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(usb_serial.cpp.o)
.text 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(usb_serial.cpp.o)
.data 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(usb_serial.cpp.o)
.bss 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(usb_serial.cpp.o)
.text._ZN9USBSerial5beginEm
0x00000000 0xa C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(usb_serial.cpp.o)
.text._ZN9USBSerial5beginEmh
0x00000000 0x12 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(usb_serial.cpp.o)
.text._ZN9USBSerial3endEv
0x00000000 0x1c C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(usb_serial.cpp.o)
.text._ZN9USBSerial7pendingEv
.text._ZN9USBSerial6getDTREv
0x00000000 0x4 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(usb_serial.cpp.o)
.text._ZN9USBSerial6getRTSEv
.rodata._ZTV6Stream
0x00000000 0x28 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(usb_serial.cpp.o)
.text 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(wirish_digital.cpp.o)
.data 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(wirish_digital.cpp.o)
.bss 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(wirish_digital.cpp.o)
.text._Z11digitalReadh
0x00000000 0x2c C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(wirish_digital.cpp.o)
.text 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(wirish_time.cpp.o)
.data 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(wirish_time.cpp.o)
.bss 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(wirish_time.cpp.o)
.text._Z17delayMicrosecondsm
0x00000000 0xe C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(wirish_time.cpp.o)
.text 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(gpio.c.o)
.data 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(gpio.c.o)
.bss 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(gpio.c.o)
.text 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(iwdg.c.o)
.data 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(iwdg.c.o)
.bss 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(iwdg.c.o)
.text.iwdg_feed
0x00000000 0x10 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(iwdg.c.o)
.text 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(usart.c.o)
.data 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(usart.c.o)
.bss 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(usart.c.o)
.text.usart_init
0x00000000 0x44 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(usart.c.o)
.text.usart_enable
0x00000000 0x14 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(usart.c.o)
.text.usart_disable
0x00000000 0x1e C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(usart.c.o)
.text.usart_rx
0x00000000 0x4e C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(usart.c.o)
.text.usart_putudec
.text 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(usb.c.o)
.data 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(usb.c.o)
.bss 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(usb.c.o)
.text 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(usb_cdcacm.c.o)
.data 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(usb_cdcacm.c.o)
.bss 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(usb_cdcacm.c.o)
.text.usb_cdcacm_disable
0x00000000 0x1c C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(usb_cdcacm.c.o)
.text.usb_cdcacm_putc
0x00000000 0x1a C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(usb_cdcacm.c.o)
.text.usb_cdcacm_is_transmitting
0x00000000 0xc C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(usb_cdcacm.c.o)
.text.usb_cdcacm_get_pending
.text.usb_cdcacm_peek_char
0x00000000 0x24 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(usb_cdcacm.c.o)
.text.usb_cdcacm_get_rts
0x00000000 0x10 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(usb_cdcacm.c.o)
.text.usb_cdcacm_get_line_coding
0x00000000 0x18 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(usb_cdcacm.c.o)
.text.usb_cdcacm_get_stop_bits
.text.usb_cdcacm_get_parity
.text.usb_cdcacm_get_n_data_bits
.text 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(usb_reg_map.c.o)
.data 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(usb_reg_map.c.o)
.bss 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(usb_reg_map.c.o)
.text.usb_set_ep_rx_buf0_count
0x00000000 0x1c C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(usb_reg_map.c.o)
.text 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(usb_core.c.o)
.data 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(usb_core.c.o)
.bss 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(usb_core.c.o)
.text 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(usb_init.c.o)
.data 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(usb_init.c.o)
.bss 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(usb_init.c.o)
.text.USB_Init
0x00000000 0x38 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(usb_init.c.o)
.text 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(usb_mem.c.o)
.data 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(usb_mem.c.o)
.bss 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(usb_mem.c.o)
.text 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(usb_regs.c.o)
.data 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(usb_regs.c.o)
.bss 0x00000000 0x0 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(usb_regs.c.o)
.text.SetCNTR 0x00000000 0xc C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(usb_regs.c.o)
.text.GetCNTR 0x00000000 0xc C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(usb_regs.c.o)
.text.SetISTR 0x00000000 0xc C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(usb_regs.c.o)
.text.GetISTR 0x00000000 0xc C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(usb_regs.c.o)
.text.GetFNR 0x00000000 0xc C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(usb_regs.c.o)
.text.SetDADDR
.text.GetDADDR
.text.SetBTABLE
0x00000000 0x10 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(usb_regs.c.o)
.text.GetBTABLE
.text.SetENDPOINT
0x00000000 0xe C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(usb_regs.c.o)
.text.GetENDPOINT
.text.SetEPType
0x00000000 0x1c C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(usb_regs.c.o)
.text.GetEPType
0x00000000 0x12 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(usb_regs.c.o)
.text.SetEPRxStatus
0x00000000 0x2a C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(usb_regs.c.o)
.text.SetDouBleBuffEPStall
0x00000000 0x24 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(usb_regs.c.o)
.text.GetEPTxStatus
.text.GetEPRxStatus
.text.SetEPTxValid
0x00000000 0x1e C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(usb_regs.c.o)
.text.SetEPRxValid
.text.SetEP_KIND
.text.ClearEP_KIND
.text.Clear_Status_Out
.text.Set_Status_Out
.text.SetEPDoubleBuff
.text.ClearEPDoubleBuff
.text.GetTxStallStatus
0x00000000 0x1a C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(usb_regs.c.o)
.text.GetRxStallStatus
.text.ClearEP_CTR_RX
0x00000000 0x18 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(usb_regs.c.o)
.text.ClearEP_CTR_TX
.text.ToggleDTOG_RX
0x00000000 0x20 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(usb_regs.c.o)
.text.ToggleDTOG_TX
.text.SetEPAddress
.text.GetEPAddress
.text.SetEPTxAddr
.text.SetEPRxAddr
.text.SetEPCountRxReg
0x00000000 0x26 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(usb_regs.c.o)
.text.GetEPTxCount
.text.GetEPRxCount
.text.SetEPDblBuffAddr
0x00000000 0x38 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(usb_regs.c.o)
.text.SetEPDblBuf0Addr
.text.SetEPDblBuf1Addr
.text.GetEPDblBuf0Addr
.text.GetEPDblBuf1Addr
.text.SetEPDblBuffCount
0x00000000 0xa8 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(usb_regs.c.o)
.text.SetEPDblBuf0Count
0x00000000 0x5c C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(usb_regs.c.o)
.text.SetEPDblBuf1Count
.text.GetEPDblBuf0Count
.text.GetEPDblBuf1Count
.text.GetEPDblBufDir
0x00000000 0x44 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(usb_regs.c.o)
.text.FreeUserBuffer
0x00000000 0x3a C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(usb_regs.c.o)
.text.ToWord 0x00000000 0x6 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(usb_regs.c.o)
.text 0x00000000 0x370 c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/armv7-m\libgcc.a(_arm_addsubdf3.o)
.data 0x00000000 0x0 c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/armv7-m\libgcc.a(_arm_addsubdf3.o)
.bss 0x00000000 0x0 c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/armv7-m\libgcc.a(_arm_addsubdf3.o)
.text 0x00000000 0x424 c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/armv7-m\libgcc.a(_arm_muldivdf3.o)
.data 0x00000000 0x0 c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/armv7-m\libgcc.a(_arm_muldivdf3.o)
.bss 0x00000000 0x0 c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/armv7-m\libgcc.a(_arm_muldivdf3.o)
.text 0x00000000 0x110 c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/armv7-m\libgcc.a(_arm_cmpdf2.o)
.data 0x00000000 0x0 c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/armv7-m\libgcc.a(_arm_cmpdf2.o)
.bss 0x00000000 0x0 c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/armv7-m\libgcc.a(_arm_cmpdf2.o)
.text 0x00000000 0x50 c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/armv7-m\libgcc.a(_arm_fixdfsi.o)
.data 0x00000000 0x0 c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/armv7-m\libgcc.a(_arm_fixdfsi.o)
.bss 0x00000000 0x0 c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/armv7-m\libgcc.a(_arm_fixdfsi.o)
.text 0x00000000 0x2c c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/armv7-m\libgcc.a(_aeabi_uldivmod.o)
.data 0x00000000 0x0 c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/armv7-m\libgcc.a(_aeabi_uldivmod.o)
.bss 0x00000000 0x0 c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/armv7-m\libgcc.a(_aeabi_uldivmod.o)
.text 0x00000000 0x30 c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/armv7-m\libgcc.a(_fixdfdi.o)
.data 0x00000000 0x0 c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/armv7-m\libgcc.a(_fixdfdi.o)
.bss 0x00000000 0x0 c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/armv7-m\libgcc.a(_fixdfdi.o)
.text 0x00000000 0x44 c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/armv7-m\libgcc.a(_fixunsdfdi.o)
.data 0x00000000 0x0 c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/armv7-m\libgcc.a(_fixunsdfdi.o)
.bss 0x00000000 0x0 c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/armv7-m\libgcc.a(_fixunsdfdi.o)
.text 0x00000000 0x60 c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/armv7-m\libgcc.a(bpabi.o)
.data 0x00000000 0x0 c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/armv7-m\libgcc.a(bpabi.o)
.bss 0x00000000 0x0 c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/armv7-m\libgcc.a(bpabi.o)
.text 0x00000000 0x4 c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/armv7-m\libgcc.a(_dvmd_tls.o)
.data 0x00000000 0x0 c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/armv7-m\libgcc.a(_dvmd_tls.o)
.bss 0x00000000 0x0 c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/armv7-m\libgcc.a(_dvmd_tls.o)
.text 0x00000000 0x40 c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/armv7-m\libgcc.a(_arm_fixunsdfsi.o)
.data 0x00000000 0x0 c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/armv7-m\libgcc.a(_arm_fixunsdfsi.o)
.bss 0x00000000 0x0 c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/armv7-m\libgcc.a(_arm_fixunsdfsi.o)
.text 0x00000000 0x2a0 c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/armv7-m\libgcc.a(_divdi3.o)
.data 0x00000000 0x0 c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/armv7-m\libgcc.a(_divdi3.o)
.bss 0x00000000 0x0 c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/armv7-m\libgcc.a(_divdi3.o)
.ARM.extab 0x00000000 0x0 c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/armv7-m\libgcc.a(_divdi3.o)
.ARM.exidx 0x00000000 0x8 c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/armv7-m\libgcc.a(_divdi3.o)
.text 0x00000000 0x290 c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/armv7-m\libgcc.a(_udivdi3.o)
.data 0x00000000 0x0 c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/armv7-m\libgcc.a(_udivdi3.o)
.bss 0x00000000 0x0 c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/armv7-m\libgcc.a(_udivdi3.o)
.ARM.extab 0x00000000 0x0 c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/armv7-m\libgcc.a(_udivdi3.o)
.ARM.exidx 0x00000000 0x8 c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/armv7-m\libgcc.a(_udivdi3.o)
.text 0x00000000 0x0 c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv7-m\libc.a(lib_a-errno.o)
.data 0x00000000 0x0 c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv7-m\libc.a(lib_a-errno.o)
.bss 0x00000000 0x0 c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv7-m\libc.a(lib_a-errno.o)
.text.__errno 0x00000000 0xc c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv7-m\libc.a(lib_a-errno.o)
.text 0x00000000 0x0 c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv7-m\libc.a(lib_a-exit.o)
.data 0x00000000 0x0 c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv7-m\libc.a(lib_a-exit.o)
.bss 0x00000000 0x0 c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv7-m\libc.a(lib_a-exit.o)
.text 0x00000000 0x0 c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv7-m\libc.a(lib_a-impure.o)
.data 0x00000000 0x0 c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv7-m\libc.a(lib_a-impure.o)
.bss 0x00000000 0x0 c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv7-m\libc.a(lib_a-impure.o)
.data._impure_ptr
0x00000000 0x4 c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv7-m\libc.a(lib_a-impure.o)
.text 0x00000000 0x0 c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv7-m\libc.a(lib_a-init.o)
.data 0x00000000 0x0 c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv7-m\libc.a(lib_a-init.o)
.bss 0x00000000 0x0 c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv7-m\libc.a(lib_a-init.o)
.text 0x00000000 0x0 c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv7-m\libc.a(lib_a-memset.o)
.data 0x00000000 0x0 c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv7-m\libc.a(lib_a-memset.o)
.bss 0x00000000 0x0 c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv7-m\libc.a(lib_a-memset.o)
.text.memset 0x00000000 0x94 c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv7-m\libc.a(lib_a-memset.o)
.text 0x00000000 0x0 c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv7-m\libc.a(lib_a-strlen.o)
.data 0x00000000 0x0 c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv7-m\libc.a(lib_a-strlen.o)
.bss 0x00000000 0x0 c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv7-m\libc.a(lib_a-strlen.o)
.text 0x00000000 0x0 c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv7-m\libc.a(lib_a-__call_atexit.o)
.data 0x00000000 0x0 c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv7-m\libc.a(lib_a-__call_atexit.o)
.bss 0x00000000 0x0 c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv7-m\libc.a(lib_a-__call_atexit.o)
.text 0x00000000 0x0 c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv7-m\libc.a(lib_a-atexit.o)
.data 0x00000000 0x0 c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv7-m\libc.a(lib_a-atexit.o)
.bss 0x00000000 0x0 c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv7-m\libc.a(lib_a-atexit.o)
.text 0x00000000 0x0 c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv7-m\libc.a(lib_a-fini.o)
.data 0x00000000 0x0 c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv7-m\libc.a(lib_a-fini.o)
.bss 0x00000000 0x0 c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv7-m\libc.a(lib_a-fini.o)
.text 0x00000000 0x0 c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv7-m\libc.a(lib_a-__atexit.o)
.data 0x00000000 0x0 c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv7-m\libc.a(lib_a-__atexit.o)
.bss 0x00000000 0x0 c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv7-m\libc.a(lib_a-__atexit.o)
.text 0x00000000 0x0 c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/armv7-m/crtend.o
.data 0x00000000 0x0 c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/armv7-m/crtend.o
.bss 0x00000000 0x0 c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/armv7-m/crtend.o
.eh_frame 0x00000000 0x4 c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/armv7-m/crtend.o
.jcr 0x00000000 0x4 c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/armv7-m/crtend.o
.text 0x00000000 0x0 c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/armv7-m/crtn.o
.data 0x00000000 0x0 c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/armv7-m/crtn.o
.bss 0x00000000 0x0 c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/armv7-m/crtn.o
Memory Configuration
Name Origin Length Attributes
ram 0x20000000 0x00010000 xrw
rom 0x08010000 0x00070000 xr
*default* 0x00000000 0xffffffff
Linker script and memory map
LOAD c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/armv7-m/crti.o
LOAD c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/armv7-m/crtbegin.o
LOAD c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv7-m/crt0.o
LOAD c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/armv7-m\libgcc.a
START GROUP
LOAD C:\Users\AMP_SAI\Desktop\hexfile\sketch\usermks.ino.cpp.o
LOAD C:\Users\AMP_SAI\Desktop\hexfile\core\wirish\start.S.o
LOAD C:\Users\AMP_SAI\Desktop\hexfile\core\wirish\start_c.c.o
LOAD C:\Users\AMP_SAI\Desktop\hexfile\core\wirish\syscalls.c.o
LOAD C:\Users\AMP_SAI\Desktop\hexfile\core\board.cpp.o
LOAD C:\Users\AMP_SAI\Desktop\hexfile\core\wirish\boards.cpp.o
LOAD C:\Users\AMP_SAI\Desktop\hexfile\core\wirish\boards_setup.cpp.o
LOAD C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a
END GROUP
LOAD c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv7-m\libstdc++.a
LOAD c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv7-m\libm.a
START GROUP
LOAD c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv7-m\libc.a
END GROUP
LOAD c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/armv7-m/crtend.o
LOAD c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/armv7-m/crtn.o
START GROUP
END GROUP
START GROUP
LOAD c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv7-m\libnosys.a
END GROUP
0x20010000 PROVIDE (__msp_init, (ORIGIN (ram) + 0x10000))
0x080101b4 PROVIDE (__exc_reset, __start__)
.text 0x08010000 0x2840
0x08010000 __text_start__ = .
*(.stm32.interrupt_vector)
0x08010000 0x130 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(vector_table.S.o)
0x08010000 __stm32_vector_table
*(.text .text.* .gnu.linkonce.t.*)
.text 0x08010130 0x54 c:/users/amp_sai/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/armv7-m/crtbegin.o
.text._Z5setupv
0x08010184 0x8 C:\Users\AMP_SAI\Desktop\hexfile\sketch\usermks.ino.cpp.o
0x08010184 setup()
.text._Z4loopv
0x0801018c 0x26 C:\Users\AMP_SAI\Desktop\hexfile\sketch\usermks.ino.cpp.o
0x0801018c loop()
*fill* 0x080101b2 0x2
.text 0x080101b4 0x10 C:\Users\AMP_SAI\Desktop\hexfile\core\wirish\start.S.o
0x080101b4 __start__
.text.start_c 0x080101c4 0x64 C:\Users\AMP_SAI\Desktop\hexfile\core\wirish\start_c.c.o
0x080101c4 start_c
.text._exit 0x08010228 0x2 C:\Users\AMP_SAI\Desktop\hexfile\core\wirish\syscalls.c.o
0x08010228 _exit
*fill* 0x0801022a 0x2
.text.startup._GLOBAL__sub_I_PIN_MAP
0x0801022c 0x74 C:\Users\AMP_SAI\Desktop\hexfile\core\board.cpp.o
.text._ZL18adc_default_configPK7adc_dev
0x080102a0 0x1c C:\Users\AMP_SAI\Desktop\hexfile\core\wirish\boards.cpp.o
.text._ZL20timer_default_configP9timer_dev
0x080102bc 0x9e C:\Users\AMP_SAI\Desktop\hexfile\core\wirish\boards.cpp.o
.text._Z9boardInitv
0x0801035a 0x2 C:\Users\AMP_SAI\Desktop\hexfile\core\wirish\boards.cpp.o
0x0801035a boardInit()
.text._Z4initv
0x0801035c 0xbc C:\Users\AMP_SAI\Desktop\hexfile\core\wirish\boards.cpp.o
0x0801035c init()
.text._ZN6wirish4priv15board_reset_pllEv
0x08010418 0x2 C:\Users\AMP_SAI\Desktop\hexfile\core\wirish\boards_setup.cpp.o
0x08010418 wirish::priv::board_reset_pll()
.text._ZN6wirish4priv28board_setup_clock_prescalersEv
0x0801041a 0x2e C:\Users\AMP_SAI\Desktop\hexfile\core\wirish\boards_setup.cpp.o
0x0801041a wirish::priv::board_setup_clock_prescalers()
.text._ZN6wirish4priv16board_setup_gpioEv
0x08010448 0x4 C:\Users\AMP_SAI\Desktop\hexfile\core\wirish\boards_setup.cpp.o
0x08010448 wirish::priv::board_setup_gpio()
.text._ZN6wirish4priv15board_setup_usbEv
0x0801044c 0x54 C:\Users\AMP_SAI\Desktop\hexfile\core\wirish\boards_setup.cpp.o
0x0801044c wirish::priv::board_setup_usb()
.text._ZN6wirish4priv11series_initEv
0x080104a0 0x4 C:\Users\AMP_SAI\Desktop\hexfile\core\wirish\boards_setup.cpp.o
0x080104a0 wirish::priv::series_init()
*fill* 0x080104a4 0xc
.text 0x080104b0 0x60 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(exc.S.o)
0x080104b0 __exc_nmi
0x080104b4 __exc_hardfault
0x080104b8 __exc_memmanage
0x080104bc __exc_busfault
0x080104c0 __exc_usagefault
.text 0x08010510 0x2 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(isrs.S.o)
0x08010510 __stm32reservedexception9
0x08010510 __irq_dma1_channel3
0x08010510 __irq_i2c2_er
0x08010510 __irq_i2c1_er
0x08010510 __irq_sdio
0x08010510 __irq_fsmc
0x08010510 __irq_dma1_channel6
0x08010510 __exc_debug_monitor
0x08010510 __irq_dma1_channel1
0x08010510 __irq_adc3
0x08010510 __irq_dma2_channel2
0x08010510 __exc_svc
0x08010510 __irq_dma1_channel4
0x08010510 __irq_dma1_channel7
0x08010510 __irq_exti0
0x08010510 __irq_can_rx1
0x08010510 __irq_spi2
0x08010510 __irq_can_sce
0x08010510 __irq_exti2
0x08010510 __irq_exti3
0x08010510 __irq_exti9_5
0x08010510 __irq_dma2_channel4_5
0x08010510 __irq_pvd
0x08010510 __irq_tamper
0x08010510 __default_handler
0x08010510 __irq_wwdg
0x08010510 __stm32reservedexception10
0x08010510 __irq_flash
0x08010510 __irq_i2c2_ev
0x08010510 __irq_dma1_channel2
0x08010510 __irq_dma1_channel5
0x08010510 __stm32reservedexception13
0x08010510 __irq_rtc
0x08010510 __irq_spi1
0x08010510 __stm32reservedexception7
0x08010510 __irq_usb_hp_can_tx
0x08010510 __irq_exti15_10
0x08010510 __irq_exti4
0x08010510 __irq_dma2_channel3
0x08010510 __irq_rtcalarm
0x08010510 __irq_spi3
0x08010510 __stm32reservedexception8
0x08010510 __irq_dma2_channel1
0x08010510 __exc_pendsv
0x08010510 __irq_i2c1_ev
0x08010510 __irq_usbwakeup
0x08010510 __irq_rcc
.text.adc_init
0x08010512 0x14 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(adc.c.o)
0x08010512 adc_init
.text.adc_set_extsel
0x08010526 0xe C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(adc.c.o)
0x08010526 adc_set_extsel
.text.adc_set_sample_rate
0x08010534 0x30 C:\Users\AMP_SAI\Desktop\hexfile/..\..\AppData\Local\Temp\arduino_cache_727569\core\core_5b0bd59db35eb2205b9735ec041d5f36.a(adc.c.o)
0x08010534 adc_set_sample_rate
.text.adc_calibrate
