This is the code with 3 outputs; PB7 = sine wave, PB6 and PB8 = square wave, sine wave is not synchronized with square waves when PB6,PB8 are in - void loop(), so I want to take them from the loop and put them outside of it.
#define SAMPLES 77
#include <libmaple/dma.h>
dma_tube_config dma_cfg, dma_cfg2;
int flag = 0;
int flag1 = 0;
int out = PB6;
int out2 = PB8;
int out1 = PB7;
int val[SAMPLES];
int val1[SAMPLES];
int16 shift = 0;
int amp = 40;
int cnt = 0;
int time_track = 0;
float stp = 6.2831 / SAMPLES;
int ret = 17;
timer_dev *dev = PIN_MAP[out].timer_device;
uint8 cc_channel = PIN_MAP[out].timer_channel;
timer_dev *dev1 = PIN_MAP[out1].timer_device;
uint8 cc_channel1 = PIN_MAP[out1].timer_channel;
void fun()
flag++;
void fun1()
flag1++;
void timer_conf()
timer_dma_set_base_addr(dev, TIMER_DMA_BASE_CCR2);
timer_dma_set_burst_len(dev1, 1);
timer_dma_enable_req(dev, cc_channel1);
timer_set_reload(dev, 102);
timer_set_prescaler(dev, 0);
timer_dma_set_base_addr(dev1, TIMER_DMA_BASE_CCR2);
timer_dma_enable_req(dev1, cc_channel1);
timer_set_reload(dev1, 102);
timer_set_prescaler(dev1, 0);
void dma_conf()
dma_init(DMA1);
dma_cfg.tube_dst = &(dev->regs.gen->DMAR);
dma_cfg.tube_dst = &(dev1->regs.gen->DMAR);
dma_cfg.tube_dst_size = DMA_SIZE_32BITS;
dma_cfg.tube_src = val;
dma_cfg.tube_src = val1;
dma_cfg.tube_src_size = DMA_SIZE_32BITS;
dma_cfg.tube_nr_xfers = SAMPLES;
dma_cfg.tube_flags = DMA_CFG_SRC_INC | DMA_CFG_CIRC | DMA_CFG_CMPLT_IE;
dma_cfg.tube_req_src = DMA_REQ_SRC_TIM4_CH1;
dma_cfg.tube_req_src = DMA_REQ_SRC_TIM4_CH2;
dma_cfg.target_data = 0;
ret = dma_tube_cfg(DMA1, DMA_CH4, &dma_cfg);
void dma_start()
dma_attach_interrupt(DMA1, DMA_CH4, fun);
dma_enable(DMA1, DMA_CH4);
timer_resume(dev1);
dma_enable(DMA1, DMA_CH1);
dma_enable(DMA1, DMA_CH2);
void init_wave()
int i;
for (i = 0; i < SAMPLES; i++)
val[i] = 40 + amp * sin(stp * i);
val1[i] = 40 + amp * cos(stp * i);
void init_LEDwave()
int i;
if ( val[i] < 40)
digitalWrite(PB8, HIGH);
else
digitalWrite(PB8, LOW);
if ( val1[i] > 40)
digitalWrite(PB6, HIGH);
else
digitalWrite(PB6, LOW);
int i;
pinMode(out1, PWM);
pinMode(out, OUTPUT);
pinMode(out2, OUTPUT);
timer_conf();
dma_conf();
dma_start();
init_wave();
int i;
nothing on PB6,PB8
