Compile time so slow
Eldi4
Post by Eldi4 »
Did anyone had any idea on this problem?, I am using Arduino IDE 1.8.10, STM32Core, compiling time always take 1 minute or more, which is absolutely annoying, i havent tested on another core though, but it doesnt matter, i just use stm32core these times.
Re: Compile time so slow
Hi Eldi4,
I guess you build under Windows ?
This is related to Arduino IDE.
If you have an antivirus (mainly real-time protection) you can try to disable it.
For example on Linux, I build a sketch in few seconds while the same one on Windows builds in one or more minutes.
Eldi4
Post by Eldi4 »
fpiSTM wrote: Fri Jan 10, 2020 2:26 pm Hi Eldi4,
Yes, i use version 1903 of Windows 10 Pro, My computer didnt have any antivirus installed.
While uploading on normal arduino board it was pretty fast (under 10 seconds), but when uploading to stm32core board, it slows down.
I know, but I could not do anything, it relies to the Arduino IDE and how it manages third party core.
I've already had several feedback about that but always the same, Arduino IDE issue.
Answers: 24
if you are using the arduino IDE
there is this little documented
https://github.com/arduino/Arduino/blob ... es.txt#L53
build.path
option.
normally Arduino IDE builds in a temporary folder, i dislike that very much as well
i think using this option would place the builds in a fixed path
so try setting this path.
i think arduino ide could do incremental builds if the compiled object files are there. i.e. during an initial build, it parses and compiles all the files.
subsequently, incremental. if it is it would help a lot
if you use VSCode there is also a way to specify the output folder
viewtopic.php?f=18&p=430#p352
I don't think this change the build time.
Eldi4
Post by Eldi4 »
So, all we have to do is just wait for Arduino IDE to be patched?
Eldi4 wrote: Sat Jan 11, 2020 3:13 am So, all we have to do is just wait for Arduino IDE to be patched?
Yes... but this point is open since a long time, so I don't think this will be solved soon. Maybe this will be better with the new IDE...
Eldi4
Post by Eldi4 »
fpiSTM wrote: Sat Jan 11, 2020 5:29 am
You mean using other IDE rather than Arduino IDE?, do you have any recommendation on that?
No, I talk about the new Arduino Pro IDE which is actually in beta version and based on Theia
