SPI working on STM32F401, not on STM32F405
Bakisha
Re: SPI working on STM32F401, not on STM32F405
Post by Bakisha »
Actually, this thread helped me finally figure out why my ST7735 wasn't working so far on my STM32F411CE with Adafruit library:
Working:
#define TFT_DC       PA_3
#define TFT_CS       PA_4
#define TFT_RST     PA_2
#define TFT_SCLK    PA_5
#define TFT_MISO    PA_6
#define TFT_MOSI    PA_7
Not working:
#define TFT_DC       PA3
#define TFT_CS       PA4
#define TFT_RST     PA2
#define TFT_SCLK    PA5
#define TFT_MISO    PA6
#define TFT_MOSI    PA7
Thanks!
@Bakisha
Seems strange as PYn is the pin number while PY_n is the PinName all standard Arduino API uses pin number. Some few extra API use directly PinName.
it works for @mrguen as it uses the SPI.setXXX which handles both notations.
Bakisha
Post by Bakisha »
@fpiSTM
I don't think i has anything to do with SPI.
If called by hardware SPI,
Adafruit_ST7735 tft = Adafruit_ST7735(TFT_CS, TFT_DC, TFT_RST);
then it only needs
#define TFT_DC PA_3
#define TFT_CS PA_4
to be able to work (example sketches from library).
I can't say why, i'm just glad that @mrguen posted both non-working and working sketches, so i was able to spot and test difference.
@Bakisha
I didn't tell it is linked to SPI, just an example.
Anyway, there is a mistake here as PY_n should not be used in your case... or with a lot of luck they have the same value PYn == PY_n which is highly improbable.
PYn is converted to PY_n. So if PY_n is used then it is converted to another value or a default error value.
mrguen
Post by mrguen »
Frankly, I was far from the theory. I wanted to be coherent and use the #define in the Pin configuration table. Using the pin number was throwing a compilation error so I changed everything to pin names.
mrguen wrote: Tue May 11, 2021 4:53 pm Frankly, I was far from the theory. I wanted to be coherent and use the #define in the Pin configuration table. Using the pin number was throwing a compilation error so I changed everything to pin names.
Frankly, I know. And IMHO your are not coherent that's probably why you have so much (false) "issue" :mrgreen:
mrguen
Post by mrguen »
fpiSTM wrote: Tue May 11, 2021 4:16 pm @Bakisha
Well if you consider that "PA_10" might be different than "PA10" ... well we don't have the same understanding of the word "coherence". And concerning the code I submitted, using the "pin number" results in a compilation error, because IMHO there is no coherence between the pin definition files and the "standard" coding using pin numbers.
mrguen wrote: Tue May 11, 2021 7:46 pm Well if you consider that "PA_10" might be different than "PA10" ... well we don't have the same understanding of the word "coherence".
PinName value are the same for all variants
  PA_0  = (PortA << 4) + 0x00,
while PA0 is defined for each variant and can have different value.
#define PA0 0
mrguen wrote: Tue May 11, 2021 7:46 pm And concerning the code I submitted, using the "pin number" results in a compilation error, because IMHO there is no coherence between the pin definition files and the "standard" coding using pin numbers.
Well, without log nor full sketch hard to tell what's you made wrong.
Anyway I guess here we add not the same definitions. If "pin definition files" is PeripheralPins.c it is not correct, it is simply a database of all capabilities of a pins.
