NUCLEO-G474RE BMP183 Output Problem
I want to use BMP183 pressure sensor with NUCLEO-G474RE. I coded it with Arduino IDE. I used Adafruit BMP183 library. When i open the serial monitor, i see wrong values like -600 celcius. I thought its about sensor but i tried it with Arduino, and there was not any problem. I tried all pins but i cant solve that problem. Can you help me? Do you have any suggestions? I add an image of serial monitor and codes.
Re: NUCLEO-G474RE BMP183 Output Problem
I don't see image.
Could you share your sketch and how you wire the BMP to the board.
#include <f401reMap.h>
#include <SPI.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_BMP183.h>
// For hardware SPI:
// Connect SCK to SPI Clock, SDO to SPI MISO, and SDI to SPI MOSI
// See http://arduino.cc/en/Reference/SPI for your Arduino's SPI pins!
// On UNO, Clock is #13, SDO/MISO is #12 and SDI/MOSI is #11
// You can also use software SPI and define your own pins!
#define BMP183_CLK pinMap(12)
#define BMP183_SDO pinMap(13) // AKA MISO
#define BMP183_SDI pinMap(14) // AKA MOSI
// You'll also need a chip-select pin, use any pin!
#define BMP183_CS pinMap(9)
// initialize with hardware SPI
//Adafruit_BMP183 bmp = Adafruit_BMP183(BMP183_CS);
// or initialize with software SPI and use any 4 pins
Adafruit_BMP183 bmp = Adafruit_BMP183(BMP183_CLK, BMP183_SDO, BMP183_SDI, BMP183_CS);
Arduino setup function (automatically called at startup)
void setup(void)
Serial.println("BMP183 Pressure Sensor Test"); Serial.println("");
/* Initialise the sensor */
if(!bmp.begin())
/* There was a problem detecting the BMP183 ... check your connections */
Serial.print("Ooops, no BMP183 detected ... Check your wiring!");
while(1);
Arduino loop function, called once 'setup' is complete (your own code
should go here)
void loop(void)
/* Display atmospheric pressue in Pascals */
Serial.print("Pressure: ");
Serial.print(bmp.getPressure());
Serial.print(" Pascals / ");
Serial.print(bmp.getPressure() / 100);
Serial.println(" millibar (hPa)");
/* First we get the current temperature from the BMP085 */
float temperature;
temperature = bmp.getTemperature();
Serial.print("Temperature: ");
Serial.print(temperature);
Serial.println(" C");
/* Calculating altitude with reasonable accuracy requires pressure *
* sea level pressure for your position at the moment the data is *
* converted. If you don't have these values, a 'generic' value of *
* 1013.25 mbar can be used (defined as SENSORS_PRESSURE_SEALEVELHPA *
* in sensors.h), but this isn't ideal and will give variable *
* results from one day to the next. *
* You can usually find the current SLP value by looking at weather *
* websites or from environmental information centers near any major *
* airport. *
* For example, for Paris, France you can check the current mean *
* pressure and sea level at: http://bit.ly/16Au8ol */
/* Then convert the atmospheric pressure, SLP and temp to altitude */
/* Update this next line with the current SLP for better results */
float seaLevelPressure = SENSORS_PRESSURE_SEALEVELHPA; // should be ~1000
Serial.print("Sea level pressure: ");
Serial.print(SENSORS_PRESSURE_SEALEVELHPA);
Serial.println(" millibar/hPa");
Serial.print("Altitude: ");
Serial.print(bmp.getAltitude(seaLevelPressure));
Serial.println(" m");
Serial.println("");
As it's written on the board: D14 and D15 are SDA, SCL pins. Those are I2C pins.
SPI uses MOSI/MISO pins: D10 and D11.
You used the software SPI. Try hw SPI as described in the sketch. Like the uno.
So you set this in your sketch and wire on the correct pins ?
In you sketch you have #include <f401reMap.h> but this is not part of official library of Adafruit: https://github.com/adafruit/Adafruit_BMP183_Library
Idem for pinMap(), don't know why you get this but seems not correct.
Which core you used?
#define BMP183_CLK 13
#define BMP183_SDO 12 // AKA MISO
#define BMP183_SDI 11 // AKA MOSI
#define BMP183_CS 9
//Adafruit_BMP183 bmp = Adafruit_BMP183(BMP183_CLK, BMP183_SDO, BMP183_SDI, BMP183_CS);
fpiSTM wrote: ↑Sat May 22, 2021 4:57 pm So you set this in your sketch and wire on the correct pins ?
In you sketch you have #include <f401reMap.h> but this is not part of official library of Adafruit: https://github.com/adafruit/Adafruit_BMP183_LibraryCode: Select all
// You can also use software SPI and define your own pins! #define BMP183_CLK 13 #define BMP183_SDO 12 // AKA MISO #define BMP183_SDI 11 // AKA MOSI // You'll also need a chip-select pin, use any pin! #define BMP183_CS 9 // initialize with hardware SPI Adafruit_BMP183 bmp = Adafruit_BMP183(BMP183_CS); // or initialize with software SPI and use any 4 pins //Adafruit_BMP183 bmp = Adafruit_BMP183(BMP183_CLK, BMP183_SDO, BMP183_SDI, BMP183_CS);
Yes i did what you said. I deleted that library, i changed the code and pins like what you show. But output is same. I really cant understand why. Im sure sensor is working normal.
Is there any possibility of a problem in this part?
