Problems writing to Client using EthernetWebServer_SSL_STM32 and SdFat libraries
exdes
Post by exdes »
This seems to be a problem similar to the one posted by ahorow, "Write to Ethernet truncated using EthernetWebServer_SSL_STM32 library".
I am attempting to write a file found on an SD card to a connected Ethernet client. The file opens fine, and I have no problems writing to the client. For testing purposes I also write the lines read from the file to the serial port at the same time as being written to the client. What is happening though, is that a larger portion of file contents are displayed in the serial monitor, but the browser only receives about 2900 characters. The actual file, not including the header, sent separately, is about 260000 bytes long. I ran a test sending the file's content via 8000 "client.print(...)" statements and this worked fine.
I have attached code. Anything not necessary to the basic function of the code has been stripped out to give us the minimum required to debug plus additional code for debug purposes. I am using the libraries EthernetWebServer_SSL_STM32 & SdFat. My code is derived from the WebServer example. No errors are registered during operation.
Links to the libraries are: https://github.com/greiman/SdFat & https://github.com/khoih-prog/EthernetW ... _SSL_STM32
Serial printout at startup:
Start WebServer on NUCLEO_F767ZI, using LAN8742A Ethernet & STM32Ethernet Library
EthernetWebServer_SSL_STM32 v1.3.0
You're connected to the network, IP = 192.168.2.164
#include "defines.h"
#include "SdFat.h"
  WebServer.ino - Simple Arduino web server sample for ESP8266 AT-command shield
  For STM32F/L/H/G/WB/MP1 with built-in Ethernet LAN8742A (Nucleo-144, DISCOVERY, etc) or W5x00/ENC28J60 shield/module
  EthernetWebServer_SSL_STM32 is a library for STM32 using the Ethernet shields to run WebServer and Client with/without SSL
  Use SSLClient Library code from https://github.com/OPEnSLab-OSU/SSLClient
  Built by Khoi Hoang https://github.com/khoih-prog/EthernetWebServer_SSL_STM32
  Licensed under MIT license
#define REPLY_HEADER    "HTTP/1.1 200 OK\r\nContent-Type: text/html\r\nConnection: close\r\n\r\n"
    void Process_Client_Request()
        FsFile      file;
        char        line[500];
        char        Received_Character = '\0';
        uint32_t    Character_Index    =   0;
        uint32_t    n;
        uint32_t    File_Length_Bytes;
        uint32_t    File_Length_Lines;
        // listen for incoming clients
        EthernetClient client = server.available();
        static  ArduinoOutStream cout(Serial);
        if (client)
            // an http request ends with a blank line
            bool currentLineIsBlank = true;
            while (client.connected())
                if (client.available())
                    char c = client.read();
                    Serial.write(c);
                    // if you've gotten to the end of the line (received a newline
                    // character) and the line is blank, the http request has ended,
                    // so you can send a reply
                    if (c == '\n' && currentLineIsBlank)
                        Serial.println(F("Sending response:\n"));
                        // send a standard http response header
                        // use \r\n instead of many println statements to speedup data send
                        client.print(REPLY_HEADER);
                        Serial.println(F(REPLY_HEADER));
                        // Open the SD card
                        if (!sd.begin(SD_CONFIG))
                            sd.initErrorHalt(&Serial);
                        // Specify the file to read
                        char fileName[] = "test.htm";
                        // Open the file to READ from the SD card
                        if (!file.open(fileName, O_READ))
                            sd.errorHalt(&Serial, F("open failed"));
                        File_Length_Bytes = file.fileSize();
                        File_Length_Lines = 0;
                        Serial.print(__DATE__); Serial.print(", "); Serial.println(__TIME__);
                        while ((n = file.fgets(line, sizeof(line))) > 0)
                            // Write the line to the client
                            client.print(line);
                            // Print the line
                            Serial.print(line);
                            File_Length_Lines++;
                        file.close();
                        break;
                    if (c == '\n')
                        // you're starting a new line
                    else if (c != '\r')
                        // you've gotten a character on the current line
                        currentLineIsBlank = false;
            // give the web browser time to receive the data
            delay(10);
            // close the connection:
            client.stop();
            Serial.println(F("\n\nClient disconnected"));
            Serial.println("\n");
            Serial.print("Total bytes read: "); Serial.println(File_Length_Bytes);
            Serial.print("Total lines read: "); Serial.println(File_Length_Lines);
            Serial.println("");
Abbreviated contents of the file test.htm
<html><body>
This is line number: 1<br>
This is line number: 2<br>
This is line number: 3<br>
This is line number: 4<br>
This is line number: 5<br>
This is line number: 7997<br>
This is line number: 7998<br>
This is line number: 7999<br>
This is line number: 8000<br>
</html></body>
Abbreviated output to the Serial monitor:
<html><body>
This is line number: 198<br>
This is line number: 199<br>
This is line number: 200<br>
This is line number: 201<br>
This is line number: 202<br>
Writes to the serial monitor stop here.
Abbreviated output to the web client:
<html><body>
This is line number: 99<br>
This is line number: 100<br>
This is line number: 101<br>
This is line number: 102<br>
This is line number: 103<br>
This i
Writes to the client stop here.
These are things that I have tried:
  • Different makes & sizes of SD cards using different formats - no change
  • Modified to file.fgets(line, sizeof(line), "\n")) & client.write(line, countOfBytesReadWithfget); - no change
  • I looked into https://github.com/OPEnSLab-OSU/SSLClie ... on-gotchas. They mention changes to allow for larger output buffer sizes to the Ethernet.h file. I have determined that the code is using the ethernet.h file found here: Arduino/libraries/STM32duino_LwIP/src/netif/ethernet.h. This file does not have the options to increase the buffer size. Tried going through the various header files referenced but have not been able to find a setting for send buffering.
  • To illiminate possible timing issues I have added a delay of varying lengths to the inner while() loop. These had an adverse effect and were again removed.
  • I have tried client.write(line, n);, client.print(line); and cout << line; methods - identical results using all three.
  • I tried to use the standard Arduino SD library instead of the SdFat library. I also did a client.write(myFile.read()); instead of reading to the 'line' string variable, otherwise code unchanged. Same results - output to the client stops after about 104 of the 8000 line transferred.
I haven't programmed for a number of years, so I am a bit rusty and probably overlooking something obvious.
Re: Problems writing to Client using EthernetWebServer_SSL_STM32 and SdFat libraries
I think you should post an issue on the github page of khoih.
Juraj
Post by Juraj »
@stevestrong the code doesn't use the WebServer library
Juraj
Post by Juraj »
my advice on SO was client.write(line, n);
Juraj wrote: Wed May 26, 2021 5:16 am @stevestrong the code doesn't use the WebServer library
Well, then what about this sentence:
exdes wrote: Tue May 25, 2021 5:00 pm I am using the libraries EthernetWebServer_SSL_STM32 & SdFat.
exdes
Post by exdes »
My experience has been that when something doesn't work, it's because of something I did wrong or misinterpreted. I wanted to put out a sanity check before posting an issue on GitHub.
khoih-prog
Post by khoih-prog »
Thanks @Juraj for specify the problem code just uses the plain STMEthernet library, and not any feature of EthernetWebServer_SSL_STM32
I think the issue is your code (dealing with SD, etc), not the SM32Ethernet library. Check
1. Your code if there is any issue
2. If there is conflict in using SPI bus (SD card + LAN8742A, etc)
I just have some time to test and it seems OK for writing multiple of 10,000 lines from memory (not SD) and OK, using the following simple code
#define HTML_DATA_START       "<!DOCTYPE HTML>\r\n"
#define HTML_DATA_BODY        "<h4>Hello World from F767ZI running WebServer!</h4>\r\n"
#define HTML_DATA_END         "</html>\r\n"
  if (client)
    Serial.println(F("New client"));
        Serial.write(c);
          Serial.println(F("Sending response"));
          client.print(HTML_DATA_START);
#define TOTAL_LINES     10000
          for (uint16_t i = 0; i < TOTAL_LINES; i++)
            client.print(HTML_DATA_BODY);
            Serial.print("Line # : "); Serial.print(i); Serial.print(" => ");
            Serial.println(HTML_DATA_BODY);
          client.print(HTML_DATA_END);
          break;
        if (c == '\n')
        else if (c != '\r')
    delay(10);
    client.stop();
    Serial.println(F("Client disconnected"));
and terminal output
[ETHERNET_WEBSERVER] Board : NUCLEO_F767ZI , setCsPin: 10
[ETHERNET_WEBSERVER] Default SPI pinout:
[ETHERNET_WEBSERVER] MOSI: 11
[ETHERNET_WEBSERVER] MISO: 12
[ETHERNET_WEBSERVER] SCK: 13
[ETHERNET_WEBSERVER] SS: 10
[ETHERNET_WEBSERVER] =========================
You're connected to the network, IP = 192.168.2.154
New client
GET / HTTP/1.1
Host: 192.168.2.154
Connection: keep-alive
Cache-Control: max-age=0
DNT: 1
Upgrade-Insecure-Requests: 1
User-Agent: Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/91.0.4472.77 Safari/537.36
Accept: text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.9
Referer: http://192.168.2.154/
Accept-Encoding: gzip, deflate
Accept-Language: en-GB,en-US;q=0.9,en;q=0.8,vi;q=0.7
Sending response
Line # : 0 => <h4>Hello World from F767ZI running WebServer!</h4>
Line # : 1 => <h4>Hello World from F767ZI running WebServer!</h4>
Line # : 2 => <h4>Hello World from F767ZI running WebServer!</h4>
Line # : 3 => <h4>Hello World from F767ZI running WebServer!</h4>
Line # : 4 => <h4>Hello World from F767ZI running WebServer!</h4>
Line # : 5 => <h4>Hello World from F767ZI running WebServer!</h4>
Line # : 9989 => <h4>Hello World from F767ZI running WebServer!</h4>
Line # : 9990 => <h4>Hello World from F767ZI running WebServer!</h4>
Line # : 9991 => <h4>Hello World from F767ZI running WebServer!</h4>
Line # : 9992 => <h4>Hello World from F767ZI running WebServer!</h4>
Line # : 9993 => <h4>Hello World from F767ZI running WebServer!</h4>
Line # : 9994 => <h4>Hello World from F767ZI running WebServer!</h4>
Line # : 9995 => <h4>Hello World from F767ZI running WebServer!</h4>
Line # : 9996 => <h4>Hello World from F767ZI running WebServer!</h4>
Line # : 9997 => <h4>Hello World from F767ZI running WebServer!</h4>
Line # : 9998 => <h4>Hello World from F767ZI running WebServer!</h4>
Line # : 9999 => <h4>Hello World from F767ZI running WebServer!</h4>
Client disconnected
New client
GET /favicon.ico HTTP/1.1
Host: 192.168.2.154
Pragma: no-cache
Cache-Control: no-cache
DNT: 1
Accept: image/avif,image/webp,image/apng,image/svg+xml,image/*,*/*;q=0.8
Sending response
Client disconnected
khoih-prog
Possibly too late, but for the record
1. Did you use the same SPI bus for SD-card and LAN8742A (pin 10-13) ?
2. Did you use the type of badly-designed SD card, which monopolizes the MISO signal and not to be tri-state when not selected via CS/SS? If so, you have to use the fix as described in Unable to access 2 SD cards with Arduino Mega 2560 Rev3
