[Solved] Multiple serial port at the same time doesn't work
mwon
Re: [Solved] Multiple serial port at the same time doesn't work
Post by mwon »
Ok, thanks. That makes sense and I now understand that I can't use Serial simultaneously in PA9, PA10 and PB6, PB7 with STM32F411CEU. I have now tried with USART2 and it worked fine. The code:
HardwareSerial RPI(PB7,PB6);
HardwareSerial DEBUG(USART2);
  RPI.begin(115200);
  DEBUG.begin(115200); // begin Serial
  DEBUG.println("debug");
  RPI.println("RPI");
another suggestion name your ports Serial1 and Serial2 after their respective uarts, it isn't necessary but that it'd save yourself some confusion at some later point after you have forgotten where each those definitions RPI and DEBUG is pointing to.
you can always indicate RPI or DEBUG as a comment next to the definitions.
