Serial1 usage
RolfSte
Serial1 usage
Post by RolfSte »
I'm using an NUCLEO F103 board and try to send monitor data over Serial1.
This works in setup:
	HardwareSerial Serial1(PA10, PA9);
	Serial1.begin(9600);
        Serial1.println("Testpoint 1");
but I have found no way to use Serial1 in other functions
or globally for classes in other files.
Re: Serial1 usage
You have to define the Serial1 outside the setup function to be global else it is local at the function.
