I'm using a the STM32L412KB board in a project, and one of the reasons I picked it is due to its low current consumption.
But then I did some measurements and found out that the consumption is much higher than expected: approximately 16 mA in operation and 600 uA in deep sleep (using the
LowPower.deepSleep()
I'm thinking that this has to be due to "wrong" configuration of the MCU for this case?
Can someone help me what I need to check?
I will for sure first try and set all unused pins to output LOW or input with pull-down. What is actually the default state of pins?
Should I also look into unused clocks and unused peripherals?
It is a bit difficult for me to find out what is going on in the core. Which files should I look at? Is it everything related to my board under the system and variants folders? The thing is I don't see where do the peripheral clocks get enabled.
I must say I don't have that much experience with STM32 MCUs, so perhaps there are obvious things I'm missing.
