Nucleo-64 STM32L476RG I2C not working
nbourre
Post by nbourre »
Hi guys,
I have a Nucleo-64 STM32L476RG and I did a simple program using the Cube[MX|IDE] to communicate with an I2C device and it works on pins A4 and A5.
On the other side using the Arduino IDE, I can't figure out what I'm doing wrong. The I2C scanner is not working in my case.
I'm surely missing something out.
Can someone guide me?
thank you
Re: Nucleo-64 STM32L476RG I2C not working
Scanner example uses the default pins which are:
#define PB9 14
#define PB8 15
Which are D14 ans D15 not A4 and A5.
See the wiki to known how to change default Wire instance pins.
And of course you need pull up on each I2C lines.
nbourre
Post by nbourre »
Thanks!
I managed to make it work using the following code before the begin():
  Wire.setSDA(A4);
  Wire.setSCL(A5);
  if (!wire.begin()) {
It works until, it starts to give plenty of 0s as values. I guess this is due to the lack of pullups.
