Pito
Post by Pito »
A rather long thread on how we messed with stm32F407 FPU in 2017
https://web.archive.org/web/20170715084 ... c23d399868
There are some gcc settings recommended, like
-mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant
CMSIS FFT with pictures (@240MHz):
https://web.archive.org/web/20190316193 ... =80#p26827
Btw, the last post is from an user ag123 :)
Bingo600
Post by Bingo600 »
So the only difference between a m4 & a m7 is m4 = 3 stage pipeline & m7 = 6 stage pipeline.
m4 & m7 both can have an optional sp-fpu , and m7 can have an optional/additional dp-fpu.
/Bingo
Maybe the cmsis library helps on this...
Pito
Post by Pito »
Another argument for -Os is when you start experiments with those hw switches. With higher optimisation you may lose track.
Bingo600
Post by Bingo600 »
But according to the ARM or arm-gcc doc it is NOT wrong to specify
-march=armv7e-m+fp. -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant
We might have to add
 -mcpu=cortex-m4
to the above , in order confuse arm-gcc (thinking it's a cortex-m7)
But unless someone "speculates" in coding against the pipeline , then it seems like a m4 & a m7 should be instruction compatible.
But for now i do agree we should leave the ST Core untouched , and use the default
/Bingo
Bingo600
Post by Bingo600 »
fpiSTM wrote: Sun Jan 26, 2020 6:32 pm Maybe the cmsis library helps on this...
You mean this one ??
GenF4.build.cmsis_lib_gcc=arm_cortexM4lf_math
Seems like the F7 uses this one cmsis_lib_gcc=arm_cortexM7lfsp_math
Is the source available for those math libs ??
/Bingo
Pito
Post by Pito »
Look at my above link - I did CMSIS FFT on 407, you may download sources of libraries for DSP and other math with FPU.
https://www.st.com/content/st_com/en/pr ... t-software
https://developer.arm.com/tools-and-sof ... dded/cmsis
i think i saw this table somewhere prior
https://wiki.gentoo.org/wiki/User:Daemon/Sandbox/ARM
* Architecture options usage *
This toolchain is built and optimized for Cortex-A/R/M bare metal development.
the following table shows how to invoke GCC/G++ with correct command line
options for variants of Cortex-A/R and Cortex-M architectures.
| Arm core   | Command Line Options                       | multilib     |
| Cortex-M0+ | -mthumb -mcpu=cortex-m0plus                | thumb        |
| Cortex-M0  | -mthumb -mcpu=cortex-m0                    | /v6-m        |
| Cortex-M1  | -mthumb -mcpu=cortex-m1                    | /nofp        |
|            | -mthumb -march=armv6-m                     |              |
| Cortex-M3  | -mthumb -mcpu=cortex-m3                    | thumb        |
|            |--------------------------------------------| /v7-m        |
|            | -mthumb -march=armv7-m                     | /nofp        |
| Cortex-M4  | -mthumb -mcpu=cortex-m4                    | thumb        |
| (No FP)    |--------------------------------------------| /v7e-m       |
|            | -mthumb -march=armv7e-m                    | /nofp        |
| Cortex-M4  | -mthumb -mcpu=cortex-m4 -mfloat-abi=softfp | thumb        |
| (Soft FP)  | -mfpu=fpv4-sp-d16                          | /v7e-m+fp    |
|            |--------------------------------------------| /softfp      |
|            | -mthumb -march=armv7e-m -mfloat-abi=softfp |              |
|            | -mfpu=fpv4-sp-d16                          |              |
| Cortex-M4  | -mthumb -mcpu=cortex-m4 -mfloat-abi=hard   | thumb        |
| (Hard FP)  | -mfpu=fpv4-sp-d16                          | /v7e-m+fp    |
|            |--------------------------------------------| /hard        |
|            | -mthumb -march=armv7e-m -mfloat-abi=hard   |              |
| Cortex-M7  | -mthumb -mcpu=cortex-m7                    | thumb        |
| Cortex-M7  | -mthumb -mcpu=cortex-m7 -mfloat-abi=softfp | thumb        |
| (Soft FP)  | -mfpu=fpv5-sp-d16                          | /v7e-m+fp    |
|            | -mfpu=fpv5-sp-d16                          |              |
|            | -mfpu=fpv5-d16                             | /v7e-m+dp    |
|            | -mfpu=fpv5-d16                             |              |
| Cortex-M7  | -mthumb -mcpu=cortex-m7 -mfloat-abi=hard   | thumb        |
| (Hard FP)  | -mfpu=fpv5-sp-d16                          | /v7e-m+fp    |
|            | -mfpu=fpv5-d16                             |              |
well found it in the gcc-arm-none-eabi installed directory in share/doc directory
it is the readme.txt file
Bingo600
Post by Bingo600 »
I had to ....
Built F411 but as a cortex-m7
boards.txt :oops:
GenF4.name=Generic STM32F4 series
GenF4.build.vid=0x0483
GenF4.build.core=arduino
GenF4.build.board=GenF4
GenF4.build.extra_flags=-D{build.product_line} {build.enable_usb} {build.xSerial} {build.bootloader_flags}
#GenF4.build.mcu=cortex-m4
GenF4.build.mcu=cortex-m7
GenF4.build.flags.fp=-mfpu=fpv4-sp-d16 -mfloat-abi=hard
#GenF4.build.flags.fp=-march=armv7e-m+fp+fpv5+fp.dp -mfloat-abi=hard -mfpu=fpv5-d16 -fsingle-precision-constant
GenF4.build.series=STM32F4xx
#GenF4.build.cmsis_lib_gcc=arm_cortexM4lf_math
GenF4.build.cmsis_lib_gcc=arm_cortexM7lfsp_math
-O2
Calibrate
       0.15 Seconds          1   Passes (x 100)
       0.77 Seconds          5   Passes (x 100)
       3.86 Seconds         25   Passes (x 100)
Use 64  passes (x 100)
N1 floating point     -1.12475013732910156        48.000              0.026
N2 floating point     -1.12274742126464844        33.340              0.258
N3 if then else        1.00000000000000000                  94.628    0.070
N4 fixed point        12.00000000000000000                 160.001    0.126
N5 sin,cos etc.        0.49909299612045288                   0.924    5.764
N6 floating point      0.99999982118606567        31.994              1.079
N7 assignments         3.00000000000000000                  41.210    0.287
N8 exp,sqrt etc.       0.75110614299774170                   1.052    2.264
MWIPS                                             64.819              9.874
And specifying a m7 V5 fpu
#GenF4.build.flags.fp=-mfpu=fpv4-sp-d16 -mfloat-abi=hard
GenF4.build.flags.fp=-mfpu=fpv5-sp-d16 -mfloat-abi=hard
-O2
Calibrate
N3 if then else        1.00000000000000000                  96.000    0.069
N8 exp,sqrt etc.       0.75110614299774170                   1.051    2.265
MWIPS                                             64.819              9.874
Seems like the result is the same for the m4 fpu vs the m7 fpu - The m4 runs with both.
Build-F411-as-m7.log.zip
(12.33 KiB) Downloaded 274 times
Bingo600 wrote: Sun Jan 26, 2020 6:35 pm You mean this one ??
/Bingo
Yes, this is the one supporting float and for CMSIS version 5.5.1.
This is provided by ARM:
https://github.com/ARM-software/CMSIS_5 ... SP/Lib/GCC
