STM32 F407VET6 and BME280 I2C how to choose SDA and SCL pins?
Orion1398
Re: STM32 F407VET6 and BME280 I2C how to choose SDA and SCL pins?
Post by Orion1398 »
fredbox wrote: Tue May 04, 2021 11:06 pm Here is a nice picture of the data lines without pull-up resistors: https://electronics.stackexchange.com/q ... al-pullups. With the right pull-up, the signals are nice and square.
I will try use pullups)).
I turned off the screen sensor and everything worked (at least BME280 works).
I don't know if the 0-DOF IMU Sensor will work but tomorrow I'll try to connect it.
This is pins what I was use for Touch.
#define t_SCK PB3 // T_CLK
#define t_CS PB7 // T_CS
#define t_MOSI PB5 // T_DIN
#define t_MISO PB4 // T_DOUT
#define t_IRQ PB8 // T_IRQ
If I need a touchscreen then I think I will use other pins (like SPI2).
The result I got
https://drive.google.com/file/d/1T-d_6I ... sp=sharing
Code:
#include "Adafruit_GFX.h"
#include "Adafruit_ILI9341.h"
#include "Adafruit_Sensor.h"
#include "Adafruit_BME280.h"
#include <SPI.h>
#include <SoftwareSerial.h>
#include <TinyGPS++.h>
#define SEALEVELPRESSURE_HPA (1015.92)
Adafruit_BME280 bme; // I2C
#define TFT_DC PD5
#define TFT_CS PD7
//#define TFT_RST PA3
#define TFT_RST -1
#define TFT_MISO PB14
#define TFT_MOSI PB15
#define TFT_CLK PB13
Adafruit_ILI9341 tft = Adafruit_ILI9341(TFT_CS, TFT_DC, TFT_MOSI, TFT_CLK, TFT_RST, TFT_MISO);
#define PERIOD 5000
uint32_t timer = 0;
static const int RXPin = PA9, TXPin = PA10;
static const uint32_t GPSBaud = 9600;
TinyGPSPlus gps;
SoftwareSerial ss(RXPin, TXPin);
bool errL = false;
bool errD = false;
bool errT = false;
  //Serial.begin(115200);
  ss.begin(GPSBaud);
  while (!Serial);
  unsigned status;
  status = bme.begin(0x76);
  //bme.begin();
  tft.begin();
  tft.setRotation(0);
  tft.fillScreen(ILI9341_BLACK);
  tft.setTextColor(ILI9341_WHITE);
  tft.setTextSize(2);
  tft.setCursor(72, 5);
  tft.print("Testing");
  tft.setTextColor(ILI9341_GREEN);
  tft.setCursor(102, 300);
  tft.print("STM");
  if (!status)
    tft.setTextSize(1);
    tft.setCursor(20, 45);
    tft.print("Could not find a valid BME280 sensor, check wiring, address, sensor ID!");
    tft.setCursor(20, 65);
    tft.print("SensorID was: 0x");
    tft.print(bme.sensorID(), 16);
    tft.setCursor(20, 75);
    tft.print("        ID of 0xFF probably means a bad address, a BMP 180 or BMP 085\n");
    tft.setCursor(20, 95);
    tft.print("   ID of 0x56-0x58 represents a BMP 280,\n");
    tft.setCursor(20, 105);
    tft.print("        ID of 0x60 represents a BME 280.\n");
    tft.setCursor(20, 115);
    tft.print("        ID of 0x61 represents a BME 680.\n");
    tft.setCursor(20, 125);
    while (1) delay(10);
  if (millis() - timer >= PERIOD)
    funcBME280();
    do
      timer += PERIOD;
      if (timer < PERIOD) break;
    while (timer < millis() - PERIOD);
  while (ss.available() > 0)
    if (gps.encode(ss.read()))
      displayInfo();
  if (millis() > 5000 && gps.charsProcessed() < 10)
    tft.setTextColor(ILI9341_RED);
    tft.setTextSize(1);
    tft.setCursor(10, 35);
    tft.print(F("GPS NEO-7M"));
    tft.setCursor(10, 55);
    tft.print(F("No GPS detected: check wiring."));
    while (true);
void funcBME280()
  tft.setTextSize(1);
  tft.setCursor(10, 165);
  tft.print("BME280");
  tft.setCursor(10, 185);
  tft.print("Temperature:");
  tft.fillRect(90, 185, 100, 7, 0x0000);
  tft.setCursor(90, 185);
  tft.print(bme.readTemperature());
  tft.setCursor(10, 195);
  tft.print("Pressure:");
  tft.fillRect(90, 195, 100, 7, 0x0000);
  tft.setCursor(90, 195);
  tft.print(bme.readPressure() / 100);
  tft.setCursor(10, 205);
  tft.print("Altitude:");
  tft.fillRect(90, 205, 100, 7, 0x0000);
  tft.setCursor(90, 205);
  tft.print(bme.readAltitude(SEALEVELPRESSURE_HPA));
  tft.setCursor(10, 215);
  tft.print("Humidity:");
  tft.fillRect(90, 215, 100, 7, 0x0000);
  tft.setCursor(90, 215);
  tft.print(bme.readHumidity());
void displayInfo()
  tft.setTextSize(1);
  tft.setCursor(10, 25);
  tft.print("GPS NEO-7M");
  tft.setCursor(10, 45);
  tft.print("LOCATION");
  if (gps.location.isValid())
    if (errL)
      tft.fillRect(10, 55, 260, 7, 0x0000);
    tft.setTextSize(1);
    tft.print("LAT: ");
    tft.fillRect(35, 55, 60, 7, 0x0000);
    tft.setCursor(35, 55);
    tft.print(gps.location.lat(), 6);
    tft.setCursor(135, 55);
    tft.print("LGN: ");
    tft.fillRect(160, 55, 60, 7, 0x0000);
    tft.setCursor(160, 55);
    tft.print(gps.location.lng(), 6);
  else
    errL = true;
    tft.setTextSize(1);
    tft.print("INVALID LOCATION");
  tft.setTextSize(1);
  tft.setCursor(10, 65);
  tft.print("DATE");
  if (gps.date.isValid())
    if (errD)
      tft.fillRect(10, 75, 260, 7, 0x0000);
    tft.setTextSize(1);
    tft.setCursor(10, 75);
    tft.print("Month/Day/Year:");
    tft.setCursor(105, 75);
    tft.print(gps.date.month());
    tft.setCursor(110, 75);
    tft.print("/");
    tft.setCursor(115, 75);
    tft.print(gps.date.day());
    tft.setCursor(120, 75);
    tft.print("/");
    tft.setCursor(125, 75);
    tft.print(gps.date.year());
  else
    errD = true;
    tft.setTextSize(1);
    tft.print("INVALID DATE");
  tft.setTextSize(1);
  tft.setCursor(10, 85);
  tft.print("TIME UTC");
  if (gps.time.isValid())
    if (errT)
      tft.fillRect(10, 95, 260, 7, 0x0000);
    if (gps.time.hour() < 10)
      tft.fillRect(10, 95, 25, 7, 0x0000);
      tft.setTextSize(1);
      tft.setCursor(10, 95);
      tft.print("0");
      tft.setCursor(16, 95);
      tft.print( gps.time.hour());
    else
      tft.setTextSize(1);
      tft.print(gps.time.hour());
    if (gps.time.minute() < 10)
      tft.fillRect(25, 95, 25, 7, 0x0000);
      tft.setTextSize(1);
      tft.setCursor(25, 95);
      tft.print("0");
      tft.setCursor(31, 95);
      tft.print(gps.time.minute());
    else
      tft.setTextSize(1);
    if (gps.time.second() < 10)
      tft.fillRect(40, 95, 25, 7, 0x0000);
      tft.setTextSize(1);
      tft.setCursor(40, 95);
      tft.print("0");
      tft.setCursor(46, 95);
      tft.print(gps.time.second());
    else
      tft.setTextSize(1);
  else
    errT = true;
    tft.setTextSize(1);
    tft.print("INVALID TIME");
  Serial.println();
AndrewBCN
Post by AndrewBCN »
Usually these small BMP280/BME280 modules, as well as many other I2C modules, already have their own 4.7k or 10k pullup resistors. You can test with a multimeter, the resistance between SDA/SCL and Vcc.
Orion1398
Post by Orion1398 »
10 DOF IMU Sensor (D) didn't work.
I try connect too Arduino Duo but gyroscope and accelerometer don't work and I think I dont need them.
I replaced it with a QMC5883L I2C GY-271.
BME280 works correctly but QMC doesn't.
I connect QMC to PB6, PB7.
I use this pinout shem.
https://os.mbed.com/users/hudakz/code/S ... /shortlog/
In QMC5883LCompass.cpp I find this but I don't know what needs to change.
// Set I2C Address if different then default.
void QMC5883LCompass::setADDR(byte b){
	_ADDR = b;
If I connect HMC to that same pins like BME then he works fine.
What can I do to make the two work?
Maybe someone has some ideas ?
Orion1398
Post by Orion1398 »
Heh :shock:
They work.
I don't know how but they work.
I just steamed the SDA and SCL outputs.
I know it's wrong but it work.
https://drive.google.com/file/d/10n4UB7 ... sp=sharing
Thanks Everybody. For now, that will be enough.
Escrich
Post by Escrich »
Could you please share your code with me?, I'm interested on the accelerometer, I'm experiencing great problems to connect it and make it work, your code will be a great help.
