Multiple i2c port drive & Multiple SPI port drive
Re: Multiple i2c port drive & Multiple SPI port drive
a couple of things, u'd need to state the eeprom that you are using
if you're buying from the likes of aliexpress beware of some vendors selling boards with substitutes and labeling after the real original chips.
i'm not familiar with i2c hence have little to contribute here.
but that you've tried spi flash, and you may like to continue that attempt
viewtopic.php?f=63&t=1085
i2c is 100-300 kbps max and unless you are keeping only a little data, you would likely run out of bandwidth trying to store adc data.
the main thing about i2c is using less wires, that's about it.
then you may like to try sdio that uses SPI, this won't be easier than the others,
viewtopic.php?f=7&t=911
it is in fact more complex due to dealing with a fat file system and sd cards. so you can expect more problems.
but then these days sd cards provides gigabytes of storage and that's the main attraction
madhavan
Post by madhavan »
//Christensen v3.0 extEEPROM.h
#include <extEEPROM.h>
//24C02 EEPROM 2kbits, 256 bytes, 16 byte page length
//constructor
//extEEPROM(eeprom_size_t deviceCapacity, byte nDevice, unsigned int pageSize, byte eepromAddr = 0x50);
extEEPROM eep(kbits_2, 1, 16, 0x50);
char test[] = {
  "Hello-1234567890-and-abcdefghijklmnopqrstuvwxyz-Goodbye\n"
};//null terminated character array
char buffer[100]; //output buffer
  Wire.begin();
  int length = sizeof(test);
  Serial.print("Length   ");
  Serial.print(length);
  Serial.println();
  //return byte z for error checking on write over end of EEPROM
  //EEPROM_ADDR_ERR defined as 9 in library
  byte error = eep.write (0, test, sizeof(test)); //included null terminator
  Serial.print("Error status returned = ");
  Serial.println(error);
  if (error == 9) {
    Serial.println("ERROR ADDRESS TOO LARGE FOR EEPROM");
    return;
  if (error != 0 && error != 9) {
    Serial.println("I2C ERROR");
    return;
  if (error == 0) {
    Serial.println("No Errors");
  eep.read(0, buffer, sizeof(test));
  Serial.println(buffer);
  Serial.println();
getting following error please correct the code if i am wrong
Arduino: 1.8.13 (Windows 10), Board: "Generic STM32F103C series, STM32F103C8 (20k RAM. 64k Flash), STM32duino bootloader, 72Mhz (Normal), Smallest (default)"
C:\Users\ELCOT\Desktop\test\test.ino: In function 'void setup()':
test:30:48: error: invalid conversion from 'char*' to 'byte* {aka unsigned char*}' [-fpermissive]
In file included from C:\Users\ELCOT\Desktop\test\test.ino:3:0:
C:\Users\ELCOT\Documents\Arduino\libraries\extEEPROM/extEEPROM.h:96:14: error: initializing argument 2 of 'byte extEEPROM::write(long unsigned int, byte*, unsigned int)' [-fpermissive]
byte write(unsigned long addr, byte *values, unsigned int nBytes);
test:45:35: error: invalid conversion from 'char*' to 'byte* {aka unsigned char*}' [-fpermissive]
C:\Users\ELCOT\Documents\Arduino\libraries\extEEPROM/extEEPROM.h:98:14: error: initializing argument 2 of 'byte extEEPROM::read(long unsigned int, byte*, unsigned int)' [-fpermissive]
byte read(unsigned long addr, byte *values, unsigned int nBytes);
Multiple libraries were found for "Wire.h"
Used: C:\Users\ELCOT\AppData\Local\Arduino15\packages\stm32duino\hardware\STM32F1\2021.3.18\libraries\Wire
Not used: C:\Users\ELCOT\AppData\Local\Arduino15\packages\stm32duino\hardware\STM32F1\2021.3.18\libraries\WireSlave
Multiple libraries were found for "extEEPROM.h"
Used: C:\Users\ELCOT\Documents\Arduino\libraries\extEEPROM
Not used: C:\Users\ELCOT\Documents\Arduino\libraries\extEEPROM-master
exit status 1
The error message is clear: you have to cast the second parameters of the function calls to
byte error = eep.write( 0, (byte*)test, sizeof(test));
and
eep.read( 0, (byte*)bufer, sizeof(test));
In addition, you have to change the size of buffer to:
char buffer[sizeof(test)+1];
