Issues with AD Conversion
What are you developing?
Re: Issues with AD Conversion
Sorry for the delay ... I was in the process of rebuilding my W10 i7 dev box and now that is done, I installed IDE 1.8.15 and compiled the looping analog sketch from my post previously.
Here are the compiler/link/upload for an original BAITE clone with bootloader 2.0:
Sketch uses 17544 bytes (14%) of program storage space. Maximum is 122880 bytes.
Global variables use 3136 bytes (15%) of dynamic memory, leaving 17344 bytes for local variables. Maximum is 20480 bytes.
maple_loader v0.1
Found it!
Found Runtime: [0x1eaf:0x0003] devnum=1, cfg=0, intf=0, alt=2, name="Bootloader 2.0 Upload to Flash address 0x8002000"
Setting Configuration 1...
Claiming USB DFU Interface...
Setting Alternate Setting ...
dfuIDLE, continuing
Transfer Size = 0x0400
bytes_per_hash=350
error resetting after download: usb_reset: could not reset device, win error: A device which does not exist was specified.
Done!
And here is what the serial console output looks like: (All pins floating...)
Analog pin#3	 = 2138
Analog pin#4	 = 1891
Analog pin#5	 = 2022
Analog pin#6	 = 2846
Analog pin#7	 = 2807
Analog pin#8	 = 2747
Analog pin#9	 = 2713
Analog pin#10	 = 1929
Analog pin#11	 = 1988
I am using Roger's core dated/downloaded on or around: 4/17/2020
The SysInternal utility USBview shows:
The "rest of the USB info..."
[Port1]  :  Maple Serial
Is Port User Connectable:         yes
Is Port Debug Capable:            no
Companion Port Number:            17
Companion Hub Symbolic Link Name: USB#ROOT_HUB30#4&152880df&0&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
Protocols Supported:
 USB 1.1:                         yes
 USB 2.0:                         yes
 USB 3.0:                         no
Device Power State:               PowerDeviceD0
       ---===>Device Information<===---
English product name: "Maple"
ConnectionStatus:
Current Config Value:              0x01  -> Device Bus Speed: Full (is not SuperSpeed or higher capable)
Device Address:                    0x13
Open Pipes:                           3
          ===>Device Descriptor<===
bLength:                           0x12
bDescriptorType:                   0x01
bcdUSB:                          0x0200
bDeviceClass:                      0x02  -> This is a Communication Device
bDeviceSubClass:                   0x00
bDeviceProtocol:                   0x00
bMaxPacketSize0:                   0x40 = (64) Bytes
idVendor:                        0x1EAF = Continental Trading GmbH
idProduct:                       0x0004
bcdDevice:                       0x0200
iManufacturer:                     0x01
     English (United States)  "LeafLabs"
iProduct:                          0x02
     English (United States)  "Maple"
iSerialNumber:                     0x00
bNumConfigurations:                0x01
          ---===>Open Pipes<===---
          ===>Endpoint Descriptor<===
bLength:                           0x07
bDescriptorType:                   0x05
bEndpointAddress:                  0x82  -> Direction: IN - EndpointID: 2
bmAttributes:                      0x03  -> Interrupt Transfer Type
wMaxPacketSize:                  0x0040 = 0x40 bytes
bInterval:                         0xFF
bLength:                           0x07
bEndpointAddress:                  0x03  -> Direction: OUT - EndpointID: 3
bmAttributes:                      0x02  -> Bulk Transfer Type
bInterval:                         0x00
bLength:                           0x07
bEndpointAddress:                  0x81  -> Direction: IN - EndpointID: 1
bInterval:                         0x00
       ---===>Full Configuration Descriptor<===---
          ===>Configuration Descriptor<===
bLength:                           0x09
bDescriptorType:                   0x02
wTotalLength:                    0x0043  -> Validated
bNumInterfaces:                    0x02
bConfigurationValue:               0x01
iConfiguration:                    0x00
bmAttributes:                      0xC0  -> Self Powered
MaxPower:                          0x32 = 100 mA
          ===>Interface Descriptor<===
bLength:                           0x09
bDescriptorType:                   0x04
bInterfaceNumber:                  0x00
bAlternateSetting:                 0x00
bNumEndpoints:                     0x01
bInterfaceClass:                   0x02  -> This is Communications (CDC Control) USB Device Interface Class
bInterfaceSubClass:                0x02
bInterfaceProtocol:                0x01
iInterface:                        0x00
  -> This is a Communications (CDC Control) USB Device Interface Class
          ===>Descriptor Hex Dump<===
bLength:                           0x05
bDescriptorType:                   0x24
05 24 00 01 10
bLength:                           0x05
05 24 01 03 01
bLength:                           0x04
04 24 02 06
bLength:                           0x05
05 24 06 00 01
bLength:                           0x07
bInterval:                         0xFF
bLength:                           0x09
bInterfaceNumber:                  0x01
bNumEndpoints:                     0x02
bInterfaceClass:                   0x0A  -> This is a CDC Data USB Device Interface Class
bInterfaceSubClass:                0x00
bInterfaceProtocol:                0x00
iInterface:                        0x00
bLength:                           0x07
bInterval:                         0x00
bLength:                           0x07
bInterval:                         0x00
Return to “Projects”
