SD Card Using SPI2
Answers: 109
Re: SD Card Using SPI2
bockesj wrote: Tue Sep 24, 2024 12:59 am
I modified the "pins_arduino.h" file located in folder
..\Arduino15\packages\STMicroelectronics\hardware\stm32\2.8.1\cores\arduino
You should avoid to change core's file. Next time you will update you will loose your change moreover it impact all other variants.
Simply use the API to change the pins:
https://github.com/stm32duino/Arduino_C ... tance-pins
