Single pin Hardware serial
Re: Single pin Hardware serial
Probably a HAL or LL functions exist for that. You can try to generate the code with CubeMX.
Alextrical
Post by Alextrical »
I just found the solution, and then saw your response. You are 100% correct. This allows me to set Bit15 of CR2, :D
It turns out that also calling
__HAL_RCC_USART2_CLK_ENABLE();
before setting the bit works
TX is now using the RX Pin. Woo
  Serial2.begin(9600);
  USART2->CR1 &= ~(1 << 0); // UE = 0... disable USART
  USART2->CR2 |= (1 << 15); //Set RX TX Swap
  USART2->CR1 |= (1 << 0); // UE = 1... Enable USART
Next to follow the guides for HalfDuplex and see how that goes
