Page 2 of 3
Re: recipe.preproc.macros pattern is missing error
Posted: Sun Nov 06, 2022 9:15 pm
On my side no issue. So I guess in your environment issue is raised. Path Length, proxy, antiviral...
Posted: Sun Nov 06, 2022 9:23 pm
by OldManNoob
Path length issues??? What is max permissible path length? Path to which folder?
No AV probs
No proxy
Posted: Mon Nov 07, 2022 9:42 am
It is just a thought.
Anyway, it seems really strange and linked to the IDE. But don't know why you have it.
Here the Arduino platform specification:
https://arduino.github.io/arduino-cli/0 ... eprocessor
As stated:
If recipe.preproc.macros is not defined, it is automatically generated from recipe.cpp.o.pattern.
So, I don't know why it is not generated. Having a full log of Arduino IDE would help.
To launch from a console, simply open a cmd or powershell window and call arduino.exe from its folder.
You can also call arduino_debug.exe.
When you told Teensy is ok, this means you used Arudino IDE from Teensy ? it is not the official one ? Right ?
Posted: Mon Nov 07, 2022 10:33 am
by OldManNoob
fpiSTM wrote: Mon Nov 07, 2022 9:42 am
: No, if I understand you correctly I'm thinking you are referring to IDE1.8.xx. I mean the Teensy board compiled
from within IDE2.0.1, which, unlike the 1.8.xx version does not require me to mount a teensyduino instance. I am now, since unmounting IDE2.0.1 and IDE 1.8.19 before re-loading both, unable to get past the recipe.preproc.macros pattern is missing error on EITHER platform whereras prior to re-mounting 2.0.1 it was an error confined to the 1.8.19 only, with a different symptom on 2.0.1. In the case of 2.0.1 the error was something like "Unable to query board type", but I cannot be certain of the exact wording.
Posted: Mon Nov 07, 2022 10:58 am
Seems an issue linked to the arduino-cli which is used on backstage by each IDE. Maybe a conflict.
You can try to isolate them by using the Arduino 1.8.19 as standalone:
https://docs.arduino.cc/software/ide-v1 ... ortableIDE
Posted: Mon Nov 07, 2022 11:26 am
by OldManNoob
Arduino IDE run from CMD console using _debug.exe:
C:\Program Files (x86)\Arduino>arduino_debug.exe
Loading configuration...
Initializing packages...
Preparing boards...
Starting...
Error compiling for board Generic STM32F1 series.
Is there more of a "log" expected than this, and if so where would I locate it please.
fpiSTM wrote: Mon Nov 07, 2022 10:58 am
Ok, I will attempt this as a solution and get back. Please be patient with me as I am not totally au fait with the processes you are referring to.
Posted: Mon Nov 07, 2022 4:15 pm
by OldManNoob
seems to have worked, but
damn!, it's really s l o w off a USB stick.
Now to work on re-jigging the setup here to cope with the 2 x IDE instances (1.8.19 & 2.0.1). I have fallen head-over-heels with 2.x.x and hope I do not have to forego its use for legacy versions in order to progress my project!
Thank you for getting me this far, and hopefully I'll be able to report back with good news by and by.
Posted: Mon Nov 07, 2022 5:01 pm
So if it works it is linked to your install. Hard to tell what is wrong. I would open an issue to Arduino about this they could probably help better.
Posted: Mon Nov 07, 2022 5:23 pm
by OldManNoob
All good now!
I uninstalled the libraries from both platforms. Rebooted.
Then I uninstalled both platforms. Rebooted.
Cleared my PC of ANY and ALL instances of the IDE packages and once again - rebooted.
Then I re-installed 1.8.19 and rebooted. Re-installed the libraries, updating as I went. Here I had my first clue: JAVA was reported corrupt.
So I re-installed JAVA and made sure I had it fully up to date before proceeding.
1.8.19 worked with the STM32 library, so I re-installed the 2.0.1 and YaY!
All good now it seems
Again, thank you for sticking with me through these last few days - much appreciated.
Posted: Mon Nov 07, 2022 6:15 pm
Welcome. Happy you found the issue.
