application start address
omaroski
Re: application start address
Post by omaroski »
Don't know, don't have the right knowledge to link (no pun intended) the missing dots :D
However if I replace this line :
_estack = ORIGIN(RAM) + LENGTH(RAM)
with this:
_estack = 0x2001c000;
the application (simple blink) starts from address I set.
All the rest is almost the same.
The memory declaration remains the same as with STM files except from LD_FLASH_OFFSET replaced by offset 0x8000:
MEMORY
  CCMRAM    (xrw)    : ORIGIN = 0x10000000,   LENGTH = 64K
  RAM    (xrw)    : ORIGIN = 0x20000000,   LENGTH = LD_MAX_DATA_SIZE
  FLASH    (rx)    : ORIGIN = 0x8000000 + 0x8000, LENGTH = LD_MAX_SIZE - 0x8000
Do you think I can declare LD_FLASH_OFFSET in build_opt.h file? Still have to try that.
Thank you
Omar
Vassilis
Post by Vassilis »
An easy way to do that is to modify only the boards.txt file by adding the following 2 lines:
# DISCO_F407VG board
Disco.menu.pnum.DISCO_F407VG=STM32F407G-DISC1
Disco.menu.pnum.DISCO_F407VG.node=DIS_F407VG
Disco.menu.pnum.DISCO_F407VG.upload.maximum_size=1048576
Disco.menu.pnum.DISCO_F407VG.upload.maximum_data_size=131072
Disco.menu.pnum.DISCO_F407VG.build.mcu=cortex-m4
Disco.menu.pnum.DISCO_F407VG.build.fpu=-mfpu=fpv4-sp-d16
Disco.menu.pnum.DISCO_F407VG.build.float-abi=-mfloat-abi=hard
Disco.menu.pnum.DISCO_F407VG.build.board=DISCO_F407VG
Disco.menu.pnum.DISCO_F407VG.build.series=STM32F4xx
Disco.menu.pnum.DISCO_F407VG.build.product_line=STM32F407xx
Disco.menu.pnum.DISCO_F407VG.build.variant=STM32F4xx/F407V(E-G)T_F417V(E-G)T
Disco.menu.pnum.DISCO_F407VG.build.cmsis_lib_gcc=arm_cortexM4lf_math
Disco.menu.pnum.DISCO_F407VG.build.flash_offset=0x8000
Disco.menu.pnum.DISCO_F407VG.build.st_extra_flags=-D{build.product_line} {build.enable_usb} {build.xSerial} -DVECT_TAB_OFFSET={build.flash_offset}
It would be better not to modify any core file like "system_stm32f4xx.c"
Of course, you could add a new custom board, but there is a known bug in Arduino IDE V2.00 - 2.04 that does not update the menu with the new board. But it works with legacy Arduino IDE version 1.8.19
Vassilis Serasidis
https://www.serasidis.gr
There are 2 SRAM: SRAM1 and SRAM2.
They are contiguous so normally, you should have 112k(SRAM1) + 16k(SRAM2).
Setting the estack at 0x2001 C000 is to use only SRAM1. Maybe a config issue on your board.
omaroski
Post by omaroski »
Vassilis wrote: Wed Apr 05, 2023 7:56 pm An easy way to do that is to modify only the boards.txt file by adding the following 2 lines:
Thank you, this is helpful. I will try with the legacy IDE
omaroski
Post by omaroski »
fpiSTM wrote: Thu Apr 06, 2023 7:31 am There are 2 SRAM: SRAM1 and SRAM2.
Ok thank you, I've noticed that, so I should set it to 0x2001FFFF (or 0x20020000 ?) to include SRAM2
It seems it's not work as by default estack is set to 128k. So set it to 112k if it works.
