STM32F103C8 and NEO-M6N gps module
What are you developing?
Re: STM32F103C8 and NEO-M6N gps module
Post by Pito »
I've been using bluepill with NEO7M.
Different code however (it writes directly in binary some settings).
Put 470-1kohm resistors in series with Rx/Tx lines to be safe.
Troubleshooting serial is always a mess :)
Post by Pito »
I've been sending binary packets to the NEO7 via Serial1 (9600).
I think you have to switch it to the NMEA instead (unless it is done in your driver).
How?? Hmm..
jxid
Post by jxid »
I tried the tip with the leds.
In TX pin the led Blinks but it never goes off.Just change its ilumination.
In RX pin the led stays on with low ilumination.
Is this normal?
Post by Pito »
I think the NEO module sends a message every second by default.
So I would not expect NEO's TX will continual lit.
BPills Serial1 TX shall blink when your code sends something out (otherwise LED is off).
PS: remove both delay() in your loop() code..
PPS: as I wrote above your LEDs have to be wired this way
Vcc(3.3V)-----[1kohm]------|>|-------RX or TX line
thus the LED lits when RX or TX is low (0V).
jxid
Post by jxid »
Can you please sent the code for M7N?
I would like to test it.
Post by Pito »
My code sets the output of the 1PPS to 20kHz, that is all. It does not read anything off the NEO.
There are examples in the TinyGPS++ library - it should work when all wired properly.
Also doublecheck the diodes - that is the best indicator. Confirm they work.
For example write a simple loop sending "Hello World" via Serial1 configured 9600 once a second and you should see the Serial1_TX led blink shortly once a second. If not working that way you do something wrong..
    Serial1.begin(9600);
    delay(2000);
    Serial.println("Hello World!!");  // prints out in terminal
    Serial1.println("Hello World!!");  // Serial1_TX line LED blinks shortly once per second
jxid
Post by jxid »
Friend Pito thanks for your help.
Suddenly the project works as it should.
I didn't change anything exept from removing the delay at "no gps data" (the first delay in my code)
Post by Pito »
Great, even I recommended to you to better remove both delays() in the loop() :P
jxid
Post by jxid »
Pito wrote: Sun Apr 05, 2020 5:49 pm Great, even I recommended to you to better remove both delays() in the loop() :P
Thanks for everything friend.
jxid
Post by jxid »
Tried my sketch with M6N M7N and M8N.
Everything works fine.
I display the data in a 240X240 display.
Return to “Projects”
