Some confusion around the ordering/mapping of the pins in the variant.cpp PinName array
fredbox
Re: Some confusion around the ordering/mapping of the pins in the variant.cpp PinName array
Post by fredbox »
I posted a more complete example here.
bockesj
Post by bockesj »
Description of digitl i/o problems on nucleo F767zi (with the STM32duino core)
The pins are referenced into two different ways - one has an underscore and the other does not
For example pin C-9 in referred to as PC9 (the "Pin Number") and PC_9 (the "Pin Name")
all of the digital I/O functions (PinMode, digitalRead/Write) use the "Pin Number" ie. - the
value without the underscore.
But here's the twist - with the Nucleo F767zi - not all of the pin numbers are defined, however,
pinNames are defined @!#$%
So in order to use all of the pins, I use the PinName and convert it to the Pin Number as follows
int pinE0 = pinNametoDigitalPin(PE_0)
pinMode( pinE0, INPUT_PULLUP);
digitalWrite( pinE0, true);
