Libraries for the STM32F746G Discovery screen?
Patrick
Re: Libraries for the STM32F746G Discovery screen?
Post by Patrick »
Hello @fpiSTM,
There is a problem with the buffer allocation for the examples:
 uint16_t *buffer = (uint16_t *)malloc(LTDC_F746_ROKOTECH.width * LTDC_F746_ROKOTECH.height);
Should be:
 uint16_t *buffer = (uint16_t *)malloc(LTDC_F746_ROKOTECH.width * LTDC_F746_ROKOTECH.height  * sizeof(uint16_t));
The buffer allocated was half the size of the real one.
With this fix, it works well even without D_CACHE_DISABLED in build_opt.h.
I will not provide a PR as it is not an official repository.
Answers: 109
Hi @Patrick
Thanks. I will fix that.
Patrick
Post by Patrick »
Hi @fpiSTM,
Sorry, but it seems that apart the buffer fix, D_CACHE_DISABLED is still needed in normal use.
I have done some tests today;
  • With D_CACHE_DISABLED display is perfect with Adafruit_GFX standard tests.
  • Without D_CACHE_DISABLED there is display glitch with same tests.
Yesterday, I have done display tests with LVGL and DMA2D use.
In this case, D_CACHE_DISABLED is not needed.
Answers: 109
I've updated the branch. Thanks again for the feedback ;)
mlundin
Post by mlundin »
If you want D_CACHE enabled the screen buffer can be cleared in the cache using
 void SCB_CleanDCache_by_Addr( uint32_t * addr, int32_t dsize)
