Page 2 of 4
Re: I need to return a single value from incoming serial data...
Posted: Sat Nov 28, 2020 6:06 am
by LORDHADES
int inByte;
const int buttonPin = PA0;
const int ledPin = PC13;
int is_button_press = 0;
int debounce_delay = 300;
pinMode(ledPin, OUTPUT);
pinMode(buttonPin, INPUT_PULLUP);
Serial2.begin(9600);
is_button_press = digitalRead(buttonPin);
if (Serial2 || is_button_press == HIGH)
delay(debounce_delay);
if(is_button_press == HIGH)
digitalWrite(ledPin, HIGH);
inByte = Serial2.read();
Serial.write(inByte);
delay(100);
else
digitalWrite(ledPin, LOW);
This is not working...
output is :
0
0
2
for 0.022 kg. When I remove the delay, the output is:
000.020?????????????????????????????????????????????????????????????????
I thank all for being so grateful. It seems I have to wage a war against the setup. Thanks again...
P.S. If someone suggest me a best e-book to learn arduino programming, I'll be so grateful to ya. Thanks in advance.
Posted: Sat Nov 28, 2020 6:18 am
by LORDHADES
I am explaining my requirement again.
* I have an electronic scale connected to stm32 via max232.
* Stm32 is connected to pc via ftdi.
* I'm using arduino ide for programming and i'm using cores and board managers from stm32duino.
* I need to print the weight from scale on a thermal printer only once per button press.
* To check whether it's working, I'm testing it via serial monitor.
* But weight gets printed more than once on button press, or weight gets printed continuously, even if I don't press button.
* If someone has any Idea, please help me. Or if you have any other ways for implementing this, Please help me. This is killing me...
Thanks in advance. Have a nice day...
Posted: Sat Nov 28, 2020 6:45 am
by fredbox
The book I started with many years ago and still use as a reference is "Arduino Cookbook."
See
https://books.google.com/books?id=raHyK ... &q&f=false page 142 for an example on how to detect a switch closure.
Posted: Sat Nov 28, 2020 8:55 am
by stevestrong
Try this:
if (Serial2.received()>=0) // serial data available?
if (is_button_press==LOW && !digitalRead(buttonPin)) // button pressed?
is_button_press = HIGH;
digitalWrite(ledPin, LOW); // turn LED on
if (is_button_press==HIGH && digitalRead(buttonPin)) // button released?
is_button_press = LOW;
digitalWrite(ledPin, HIGH); // turn LED off
Posted: Sat Nov 28, 2020 9:07 am
by mlundin
So without bothering about code syntax lets consider what you want to do.
So first lets be clear that button up and down is not quite the same as button pressed and released.
Second dont mix up
loop() /* do this forever */
Read any new characters from the scales, Serial2, and store them in an array. save this array as current weight when you read end of line.
Read and debounce button state, up or down, remember what it was last time
Test if button falling, if it was up last time and down this time
If presssed print the current weight value
Notice that you have all of these functions in your previous posts, the trick is to disentangle things and also not to mix them up because, its important to keep each logical part of your requirements separate. Also notice this is exactly your requirements as stated.
Now this must be turned into arduino C/C++ code.
First go back and read and UNDERSTAND how the previous code you have tested works, why does it do as it does like printing all the time button is pressed or not printing complete weight values or not. Read all if statements carefully and draw logical diagrams. You can find the button logic in
@GonzoG's first post, the reading of weight sentences is in your first post
Posted: Sat Nov 28, 2020 10:42 am
by LORDHADES
stevestrong wrote: Sat Nov 28, 2020 8:55 am
Try this:
Output renders one inverted question mark per button press...
I'm having hard time with this bro. I'm working with other ways and methods, still no luck... Seems this has to be dropped...
Thanks a lot for spending your time for me.
Posted: Sat Nov 28, 2020 11:01 am
by stevestrong
The question is what is a "value" returned by the scale? Which format has the value? Is it a single byte or they are several bytes? In which order are they sent?
I assume that there must be several bytes, so that my example has to be extended with receiving them one by one. I can do that but only after knowing more information.
Can you post a link to the used scale or user manual?
Posted: Sat Nov 28, 2020 11:05 am
by LORDHADES
stevestrong wrote: Sat Nov 28, 2020 11:01 am
Can you post a link to the used scale?
It is a custom built scale, known as Acurel, brother. It renders value like "000.112" (in Kgs on serial monitor)
Posted: Sat Nov 28, 2020 11:07 am
by stevestrong
Are there always 7 bytes? In which interval are they sent? Each second or once each time you put someting on it?
Posted: Sat Nov 28, 2020 11:13 am
by LORDHADES
stevestrong wrote: Sat Nov 28, 2020 11:07 am
Each Second, I think... Weight on the scale deviates by +or- 2 over time. This is also continuously updated on the serial monitor.
https://www.acurelweighingindia.com/pre ... ion-scales"
My scale is similar to first scale listed on the above website.
