Page 2 of 2
Re: incorrect micros() value for stm32f411re
Posted: Fri Nov 27, 2020 1:49 am
by ldelana
I think that stm32duino sets everything for their need to tune F_CPU 216000000 but may I am wrong...
I not used cubemx btw for stm32f767zi following is the default clock config
Posted: Fri Nov 27, 2020 10:01 am
by mlundin
If you check the STM32Duino source code for the variant NUCLEO_F767ZI:
https://github.com/stm32duino/Arduino_C ... ariant.cpp you can see that it is configured with the HSI clock as source for the PLL. This clock has an accuracy on the order of 0.5 to 1% that can explain your results, that would mean your results are not a problem with the micros() code, but depends on the core clock configuration for the board.
Posted: Fri Nov 27, 2020 10:06 am
You could not compare mbed and Arduino. They are really different and does not have the same goal and behaviour. MBED is an OS not the STM32 core.
I guess one of your issue is simply the usage of the Serial.
Serial uses IT with a priority of 1 while EXTI uses a priority of 6 per default. So your isr can be blocked/interrupted by the Serial one.
You can try to change those priorities.
https://github.com/stm32duino/wiki/wiki ... ity-values
-DEXTI_IRQ_PRIO=2 -DUART_IRQ_PRIO=3
Posted: Fri Nov 27, 2020 10:07 am
Also, your OP is about F411? why talking about F7 ?
For the system core clock config you can redefine your one in the sketch.
Posted: Fri Nov 27, 2020 10:23 am
by mlundin
Sorry, I dont have a problem, but @ldelana did mention the 767ZI in some earlier posts and I was simply explaning his results. Interference from Serial IRQ so make measured intervals both longer and shorter, depending on whether the first or second time sample is delayed.
Posted: Fri Nov 27, 2020 12:56 pm
by ldelana
F7 included because then I tried the same code with 3 boards, including F767zi with follow summary results:
- stm32f103 ( correct )
- stm32f446re ( problem )
- stm32f767zi ( problem )
actually I have wires connected to F7.
That's true I was only wondering if they used some different clock setting (
https://github.com/ARMmbed/mbed-os/blob ... l_rcc_ex.h ) but watching at source of read_us()
https://github.com/ARMmbed/mbed-os/blob ... api.c#L439 and
https://github.com/ARMmbed/mbed-os/blob ... api.c#L145 I'm realizing that the value of `us` retrieved through mbed might not affected by the intrinsic 1% accuracy of 16mhz internal rc oscillator of nucleo-144 stm32f767zi as correctly stated by `mlundin` and also described in `Clocks and startup` datasheet section of mcu, because the read_us() value constantly smooth that error in the time while with stm32duino I read the true actual clock info subjected by the error.
I wondering if using an external 16Mhz clock could fix the issue, I don't know exactly how to do this, I read the user manual of the nucleo-144 in the `Oscillator from external PF0/PH0` and I understand about how to toggle SB8/9/112/148/149 but I don't understand exactly how to connect the two pin crystal to the only pin 29 of CN11... In the past I did used external crystal with atmega that have two pin for that XTAL1, XTAL2.
Thanks `fpiSTM` for suggestion, I tried changing these in boards.txt flags, recompiled checking they used but results still the same.
Posted: Fri Nov 27, 2020 1:04 pm
You can try to use the HSE by pass on the nucleo F7.
Simply add the new configuration generated thanks CubeMx on top of your sketch:
extern "C" void SystemClock_Config(void) {
// HSE bypass config
Posted: Fri Nov 27, 2020 11:53 pm
by dannyf
stm32f1
those chips have DWT and you can get timing resolution down to ns -> at 72Mhz, you get 13.9ns
Posted: Fri Feb 05, 2021 6:08 pm
by MoDu
I've had trouble with DWT timing in the past, because of naughty Arduino libraries blocking the interrupts and skeweing the timer counter. Nowadays I just use the RTC if I want accurate time in periods longer than ~100 ms.
