Page 2 of 2
Re: Goertzel for stm32f103 LCD
Posted: Fri Dec 18, 2020 6:44 pm
by ozcar
stan wrote: Fri Dec 18, 2020 4:42 pm
it is compiling but not working I added LCD, in uno LCD it is alive in stm32 it is dead just displays 0.00 and do on respond to signal on PA6.
How are you generating the signal on PA6, and are you sure there is really something to see there?
This is the sampling routine in Goertzel.cpp:
/* Sample some test data. */
void Goertzel::sample(int sensorPin)
for (int index = 0; index < _N; index++)
testData[index] = analogRead(sensorPin);
You could insert some debugging code there to see what is being returned by the analogRead(), or put an analogRead() in your loop() to see if the value ever changes.
If you can see the value changing, perhaps the sampling rate you have specified (8900) is just too different to what you are actually getting. This is the issue as mentioned already by Feluga and Fredfox. The sampling code simply spins around as fast as it can, and the rate is likely to be very different to what you get on a 16MHz Uno.
You could insert some code into Goertzel::sample() to see how long it takes, and from that work out the rate. It is going to also depend on the compiler and optimisation. Hopefully the actual rate you get is at least 10kHz to detect a 5kHz signal.
There is probably a better way to sample at a known rate, but may require drastic surgery to the code.
Posted: Fri Dec 18, 2020 7:18 pm
by stan
Here is fft bin 12 = 3.6kHz, and SAMPLING FREQUENCY 40000, so I put 40000 to Goertzel but nothing changes. In fft LCD is responding to PA6, numbers are jumping without signal from noise in Goertzel on LCD is 28.3 steady.
#include "arduinoFFT.h"
#include <LiquidCrystal.h>
LiquidCrystal lcd(PB15, PB5, PA2, PB6, PB8, PB9);
#define SAMPLES1 128
#define SAMPLING_FREQUENCY 40000
arduinoFFT FFT = arduinoFFT();
unsigned int sampling_period_us;
unsigned long microseconds;
double vReal[SAMPLES1];
double vImag[SAMPLES1];
lcd.begin( 16, 2 );
sampling_period_us = round(1000000 * (1.0 / SAMPLING_FREQUENCY));
/*SAMPLING*/
for (int i = 0; i < SAMPLES1; i++)
microseconds = micros(); //Overflows after around 70 minutes!
vReal[i] = analogRead(PA6);
vImag[i] = 0;
while (micros() < (microseconds + sampling_period_us)) {
/*FFT*/
FFT.Windowing(vReal, SAMPLES1, FFT_WIN_TYP_HAMMING, FFT_FORWARD);
FFT.Compute(vReal, vImag, SAMPLES1, FFT_FORWARD);
FFT.ComplexToMagnitude(vReal, vImag, SAMPLES1);
double peak = FFT.MajorPeak(vReal, SAMPLES1, SAMPLING_FREQUENCY);
/*PRINT RESULTS*/
//Serial.print(" ");
Serial.println(vReal[40], 1);
lcd.setCursor(0, 0);
lcd.print(vReal[12], 1);// 10 - 3kHz, 12 = 3.63kHz
Posted: Fri Dec 18, 2020 7:25 pm
by stan
ozcar wrote: Fri Dec 18, 2020 6:44 pm
I have signal generator and oscilloscope.
Posted: Fri Dec 18, 2020 7:41 pm
by stan
I added sensorValue and numbers are changing when generator is turned on /off
// Set things up
//http://play.fallows.ca/wp/radio/ham-radio/signal-analysis-morse-decoder/
#include <Goertzel.h>
int sensorPin = PA6;
//int sensorPin =A0;
int led = PC13;
//int led = 13;
//const float TARGET_FREQUENCY = 500;
const float TARGET_FREQUENCY = 5000;
const int N = 100;
const float THRESHOLD = 4000;
const float SAMPLING_FREQUENCY = 40000;
// Create the filter
//Goertzel goertzel = Goertzel(TARGET_FREQUENCY, N, SAMPLING_FREQUENCY);
//LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
int sensorValue = 0;
pinMode(led, OUTPUT);
lcd.begin( 16, 2 );
sensorValue = analogRead(sensorPin);
goertzel.sample(sensorPin);
// Check samples for tone at target
float magnitude = goertzel.detect();
// if the tone is present, light LED
if (magnitude > THRESHOLD)
digitalWrite(led, HIGH);
else
digitalWrite(led, LOW);
// Serial.println(magnitude);
lcd.print(magnitude);
lcd.setCursor(0, 1);
lcd.print( sensorValue );
Posted: Fri Dec 18, 2020 7:58 pm
by fredbox
You might find some useful info here:
https://github.com/jmharvey1/STM32_CWDecoder. The tone detection has been solved using a timer interrupt.
Posted: Fri Dec 18, 2020 8:20 pm
by ozcar
stan wrote: Fri Dec 18, 2020 7:18 pm
The fft sampling at least tries to do it at a known rate. Why would you expect the Goertzel rate to be the same?
Posted: Fri Dec 18, 2020 8:29 pm
by stan
Thanks for link. now I have to make it shorter , it has 1760 lines, I think just tone detect part will be about 100 lines.
Posted: Fri Dec 18, 2020 8:37 pm
by stan
I am trying different frequencies, i think this is not issue, with 40000 the highest input frequency = 2000 Hz, 1 bin is 312Hz wide..... So sampling frequency is changing the numbers but this doesn't make the Goertzel work or not.
