Modifying library for the WSSFM10 Sigfox module for compatibility with STM32L476RG
luka.banfi
Re: Modifying library for the WSSFM10 Sigfox module for compatibility with STM32L476RG
Post by luka.banfi »
fpiSTM wrote: Mon Jan 04, 2021 8:56 am Hi,
on Nucleo L476RG D0 and D1 are not connected by default:
SB 62/63 are opened by default as PA2 and PA3 are used by the STLink.
So that's the reason it didn't work before?
luka.banfi wrote: Mon Jan 04, 2021 9:19 am
Yes if you do not closed the SB and use the D0/D1 connector then it could not work...
paulportohernan
Post by paulportohernan »
luka.banfi wrote: Mon Jan 04, 2021 8:32 am
paulportohernan wrote: Sun Jan 03, 2021 9:59 pm you dont get the message on the sigfox backend? are you sure the module its connected to the right Tx and Rx pins? your modules have leds to let you know when its transmitting?
also, you are using the
 wisol.send_rcv()
funtion, if you dont have a downlink configured use
wisol.send()
I commented out:
//String valor_recibido = wisol.SEND_RCV(valor); //aproximandamente esperar 1 minuto
//Serial.println(valor_recibido);
and uncommented:
Serial.println(wisol.SEND(valor));
Apparently the module wasn't connected to the right TX and RX pins, because I received no message in the Sigfox backend when TX (BRKWS01) was connected to RX/D0 (PA_3) and RX (BRKWS01) was connected to TX/D1 (PA_2), so I switched it so that TX (BRKWS01) is connected to D2 (PA_10) and RX (BRKWS01) is connected to D6 (PB_10). I received messages: Image
good. its working now : )
paulportohernan
i have upload a new example for STM32L476RG to the library in case anyone need this:
#include <Tinyfox.h>
#define btn   PC13 // boton usuario azul / blue user button
#define RXLED  PA5
#define rstPin PC12
//nucleo-64 STM32L476RG:
//HardwareSerial Serial2(USART2);
HardwareSerial Serial3(USART3);
Tiny<HardwareSerial,HardwareSerial> wisol(&Serial3,&Serial,rstPin,false);
  pinMode(btn,INPUT_PULLUP);
  pinMode(RXLED,OUTPUT);
  Serial.println("");
  Serial.println("boot");
  wisol.begin(9600);
  while(!Serial);  //comentar si usará una fuente de energía externa
 Serial.println("-Presione botón PC13-");
  if(digitalRead(btn)==0){
    digitalWrite(RXLED,LOW);
    Serial.println("Tx");
    wisol.RST();
    uint32_t valor =10;
    digitalWrite(RXLED,HIGH);
    wisol.SLEEP();
    delay(3000);
