Arduino IDE 2.0
Re: Arduino IDE 2.0
I installed the Arduino IDE 2.0 Beta on my Win10Pro HP i7 (4core-8tread) notebook from ZIP. No issue until...
During the unzip, I got a nasty warning from the AV:
Seems that Windows AV decided there was a threat: *graphic attached at end.
Anyway, that was instantly quarantined.
I suspect Arduino will look into this but I'm not overly concerned. My dev box is backed up and there is nothing on this PC that cannot be remastered easily.
The next issue came from the firewall complaining that Arduino-cli.exe was attempting to open a port for communication. I allowed this to proceed.
So, time to test some STM32duino code from stuff I wrote years ago for Roger's core as sample programs.
Example, loop through all analog values the Arduino way...
// MapleMini analog test by Ray Burnette
// Arduino 1.7.8 on Linux Mint 17.3 tested on 20160215
int aValue ;
int settlingmS = 5000;
    // Configure the ADC pins
    for (int x =3; x < 12; x++) {
      pinMode(x, INPUT_ANALOG);
  delay(settlingmS);
  for ( int analogInPin = 3; analogInPin < 12; analogInPin++)
    // read the analog in value:
    aValue = analogRead(analogInPin);
    // print the results to the serial monitor:
    Serial.print("Analog pin#");
    Serial.print(analogInPin);
    Serial.print("\t = ");
    Serial.println(aValue);
  delay(settlingmS);
Which yielded the following console messages:
Using board 'mapleMini' from platform in folder: C:\Users\Ray\Documents\Arduino\hardware\STM32\STM32F1
Using core 'maple' from platform in folder: C:\Users\Ray\Documents\Arduino\hardware\STM32\STM32F1
Detecting libraries used...
"C:\\Users\\Ray\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-g++" -c -g -Os -w -DDEBUG_LEVEL=DEBUG_NONE -std=gnu++11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -fno-use-cxa-atexit -DBOARD_maple_mini -DVECT_TAB_ADDR=0x8005000 -DERROR_LED_PORT=GPIOB -DERROR_LED_PIN=1 -w -x c++ -E -CC -mcpu=cortex-m3 -DF_CPU=72000000L -DARDUINO=10607 -DARDUINO_MAPLE_MINI -DARDUINO_ARCH_STM32F1 -DMCU_STM32F103CB -DSERIAL_USB -mthumb -march=armv7-m -D__STM32F1__ -DMCU_STM32F103CB -DSERIAL_USB -mthumb -march=armv7-m -D__STM32F1__ "-IC:\\Users\\Ray\\Documents\\Arduino\\hardware\\STM32\\STM32F1\\system/libmaple" "-IC:\\Users\\Ray\\Documents\\Arduino\\hardware\\STM32\\STM32F1\\system/libmaple/include" "-IC:\\Users\\Ray\\Documents\\Arduino\\hardware\\STM32\\STM32F1\\system/libmaple/stm32f1/include" "-IC:\\Users\\Ray\\Documents\\Arduino\\hardware\\STM32\\STM32F1\\system/libmaple/usb/stm32f1" "-IC:\\Users\\Ray\\Documents\\Arduino\\hardware\\STM32\\STM32F1\\system/libmaple/usb/usb_lib" "-IC:\\Users\\Ray\\Documents\\Arduino\\hardware\\STM32\\STM32F1\\cores\\maple" "-IC:\\Users\\Ray\\Documents\\Arduino\\hardware\\STM32\\STM32F1\\variants\\maple_mini" "C:\\Users\\Ray\\AppData\\Local\\Temp\\arduino-sketch-7C9F19D26B063DA5C2264F74A92FEDD0\\sketch\\AnalogTest.ino.cpp" -o nul
Generating function prototypes...
"C:\\Users\\Ray\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-g++" -c -g -Os -w -DDEBUG_LEVEL=DEBUG_NONE -std=gnu++11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -fno-use-cxa-atexit -DBOARD_maple_mini -DVECT_TAB_ADDR=0x8005000 -DERROR_LED_PORT=GPIOB -DERROR_LED_PIN=1 -w -x c++ -E -CC -mcpu=cortex-m3 -DF_CPU=72000000L -DARDUINO=10607 -DARDUINO_MAPLE_MINI -DARDUINO_ARCH_STM32F1 -DMCU_STM32F103CB -DSERIAL_USB -mthumb -march=armv7-m -D__STM32F1__ -DMCU_STM32F103CB -DSERIAL_USB -mthumb -march=armv7-m -D__STM32F1__ "-IC:\\Users\\Ray\\Documents\\Arduino\\hardware\\STM32\\STM32F1\\system/libmaple" "-IC:\\Users\\Ray\\Documents\\Arduino\\hardware\\STM32\\STM32F1\\system/libmaple/include" "-IC:\\Users\\Ray\\Documents\\Arduino\\hardware\\STM32\\STM32F1\\system/libmaple/stm32f1/include" "-IC:\\Users\\Ray\\Documents\\Arduino\\hardware\\STM32\\STM32F1\\system/libmaple/usb/stm32f1" "-IC:\\Users\\Ray\\Documents\\Arduino\\hardware\\STM32\\STM32F1\\system/libmaple/usb/usb_lib" "-IC:\\Users\\Ray\\Documents\\Arduino\\hardware\\STM32\\STM32F1\\cores\\maple" "-IC:\\Users\\Ray\\Documents\\Arduino\\hardware\\STM32\\STM32F1\\variants\\maple_mini" "C:\\Users\\Ray\\AppData\\Local\\Temp\\arduino-sketch-7C9F19D26B063DA5C2264F74A92FEDD0\\sketch\\AnalogTest.ino.cpp" -o "C:\\Users\\Ray\\AppData\\Local\\Temp\\arduino-sketch-7C9F19D26B063DA5C2264F74A92FEDD0\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\Users\\Ray\\AppData\\Local\\Arduino15\\packages\\builtin\\tools\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\Ray\\AppData\\Local\\Temp\\arduino-sketch-7C9F19D26B063DA5C2264F74A92FEDD0\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Users\\Ray\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-g++" -c -g -Os -Wall -Wextra -DDEBUG_LEVEL=DEBUG_ALL -std=gnu++11 -MMD -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -fno-use-cxa-atexit -DBOARD_maple_mini -DVECT_TAB_ADDR=0x8005000 -DERROR_LED_PORT=GPIOB -DERROR_LED_PIN=1 -mcpu=cortex-m3 -DF_CPU=72000000L -DARDUINO=10607 -DARDUINO_MAPLE_MINI -DARDUINO_ARCH_STM32F1 -DMCU_STM32F103CB -DSERIAL_USB -mthumb -march=armv7-m -D__STM32F1__ -DMCU_STM32F103CB -DSERIAL_USB -mthumb -march=armv7-m -D__STM32F1__ "-IC:\\Users\\Ray\\Documents\\Arduino\\hardware\\STM32\\STM32F1\\system/libmaple" "-IC:\\Users\\Ray\\Documents\\Arduino\\hardware\\STM32\\STM32F1\\system/libmaple/include" "-IC:\\Users\\Ray\\Documents\\Arduino\\hardware\\STM32\\STM32F1\\system/libmaple/stm32f1/include" "-IC:\\Users\\Ray\\Documents\\Arduino\\hardware\\STM32\\STM32F1\\system/libmaple/usb/stm32f1" "-IC:\\Users\\Ray\\Documents\\Arduino\\hardware\\STM32\\STM32F1\\system/libmaple/usb/usb_lib" "-IC:\\Users\\Ray\\Documents\\Arduino\\hardware\\STM32\\STM32F1\\cores\\maple" "-IC:\\Users\\Ray\\Documents\\Arduino\\hardware\\STM32\\STM32F1\\variants\\maple_mini" "C:\\Users\\Ray\\AppData\\Local\\Temp\\arduino-sketch-7C9F19D26B063DA5C2264F74A92FEDD0\\sketch\\AnalogTest.ino.cpp" -o "C:\\Users\\Ray\\AppData\\Local\\Temp\\arduino-sketch-7C9F19D26B063DA5C2264F74A92FEDD0\\sketch\\AnalogTest.ino.cpp.o"
Compiling libraries...
Compiling core...
Using previously compiled file: C:\Users\Ray\AppData\Local\Temp\arduino-sketch-7C9F19D26B063DA5C2264F74A92FEDD0\core\wirish\start.S.o
Using previously compiled file: C:\Users\Ray\AppData\Local\Temp\arduino-sketch-7C9F19D26B063DA5C2264F74A92FEDD0\core\wirish\start_c.c.o
Using previously compiled file: C:\Users\Ray\AppData\Local\Temp\arduino-sketch-7C9F19D26B063DA5C2264F74A92FEDD0\core\wirish\syscalls.c.o
Using previously compiled file: C:\Users\Ray\AppData\Local\Temp\arduino-sketch-7C9F19D26B063DA5C2264F74A92FEDD0\core\wirish\boards.cpp.o
Using previously compiled file: C:\Users\Ray\AppData\Local\Temp\arduino-sketch-7C9F19D26B063DA5C2264F74A92FEDD0\core\board.cpp.o
Using previously compiled file: C:\Users\Ray\AppData\Local\Temp\arduino-sketch-7C9F19D26B063DA5C2264F74A92FEDD0\core\wirish\boards_setup.cpp.o
Using precompiled core: C:\Users\Ray\AppData\Local\Temp\arduino-core-cache\core_STM32_STM32F1_mapleMini_2d4a391f166aa6403f9ab47e6d350f31.a
Linking everything together...
"C:\\Users\\Ray\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-g++" -Os -Wl,--gc-sections -mcpu=cortex-m3 "-TC:\\Users\\Ray\\Documents\\Arduino\\hardware\\STM32\\STM32F1\\variants\\maple_mini/ld/flash.ld" "-Wl,-Map,C:\\Users\\Ray\\AppData\\Local\\Temp\\arduino-sketch-7C9F19D26B063DA5C2264F74A92FEDD0/AnalogTest.ino.map" "-LC:\\Users\\Ray\\Documents\\Arduino\\hardware\\STM32\\STM32F1\\variants\\maple_mini/ld" -o "C:\\Users\\Ray\\AppData\\Local\\Temp\\arduino-sketch-7C9F19D26B063DA5C2264F74A92FEDD0/AnalogTest.ino.elf" "-LC:\\Users\\Ray\\AppData\\Local\\Temp\\arduino-sketch-7C9F19D26B063DA5C2264F74A92FEDD0" -lm -lgcc -mthumb -Wl,--cref -Wl,--check-sections -Wl,--gc-sections -Wl,--unresolved-symbols=report-all -Wl,--warn-common -Wl,--warn-section-align -Wl,--warn-unresolved-symbols -Wl,--start-group "C:\\Users\\Ray\\AppData\\Local\\Temp\\arduino-sketch-7C9F19D26B063DA5C2264F74A92FEDD0\\sketch\\AnalogTest.ino.cpp.o" "C:\\Users\\Ray\\AppData\\Local\\Temp\\arduino-sketch-7C9F19D26B063DA5C2264F74A92FEDD0\\core\\wirish\\start.S.o" "C:\\Users\\Ray\\AppData\\Local\\Temp\\arduino-sketch-7C9F19D26B063DA5C2264F74A92FEDD0\\core\\wirish\\start_c.c.o" "C:\\Users\\Ray\\AppData\\Local\\Temp\\arduino-sketch-7C9F19D26B063DA5C2264F74A92FEDD0\\core\\wirish\\syscalls.c.o" "C:\\Users\\Ray\\AppData\\Local\\Temp\\arduino-sketch-7C9F19D26B063DA5C2264F74A92FEDD0\\core\\board.cpp.o" "C:\\Users\\Ray\\AppData\\Local\\Temp\\arduino-sketch-7C9F19D26B063DA5C2264F74A92FEDD0\\core\\wirish\\boards.cpp.o" "C:\\Users\\Ray\\AppData\\Local\\Temp\\arduino-sketch-7C9F19D26B063DA5C2264F74A92FEDD0\\core\\wirish\\boards_setup.cpp.o" "C:\\Users\\Ray\\AppData\\Local\\Temp\\arduino-core-cache\\core_STM32_STM32F1_mapleMini_2d4a391f166aa6403f9ab47e6d350f31.a" -Wl,--end-group
"C:\\Users\\Ray\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-objcopy" -O binary "C:\\Users\\Ray\\AppData\\Local\\Temp\\arduino-sketch-7C9F19D26B063DA5C2264F74A92FEDD0/AnalogTest.ino.elf" "C:\\Users\\Ray\\AppData\\Local\\Temp\\arduino-sketch-7C9F19D26B063DA5C2264F74A92FEDD0/AnalogTest.ino.bin"
"C:\\Users\\Ray\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-size" -A "C:\\Users\\Ray\\AppData\\Local\\Temp\\arduino-sketch-7C9F19D26B063DA5C2264F74A92FEDD0/AnalogTest.ino.elf"
Sketch uses 16276 bytes (14%) of program storage space. Maximum is 110592 bytes.
Global variables use 3136 bytes (18%) of dynamic memory, leaving 14272 bytes for local variables. Maximum is 17408 bytes.
Compilation complete.
Nice.
I made absolutely no changes to the Arduino file structure or core installation made by the standard IDE .13
IDE 2 Arduino test.JPG (26.77 KiB) Viewed 8940 times
Things just seem to work for the Beta. No, I did not run down to the lab and grab a MapleMini to upload the code, I'll try that later on. But I was just curious about Roger's Core being off in the <home>/Arduino/hardware folder and how IDE 2.0 Beta would react. So far, so good.
Re: Arduino IDE 2.0
after a bummer in linux
just got it running
https://forum.arduino.cc/index.php?topi ... msg4938938
it is huge nearly 800 megs uncompressed
in an eagerness to try new things out i deleted my dot arduino15 folder. well lets reinstall from scratch
ok this instruction here still works the same
https://github.com/stm32duino/wiki/wiki ... tm32-cores
1- Launch Arduino.cc IDE. Click on "File" menu and then "Preferences".
The "Preferences" dialog will open, then add the following link to the "Additional Boards Managers URLs" field:
then in the board manager search field:
select latest click install and wait ...
downloading STM32:xpack-arm-none-eabi-gcc@9.2.1-1.1
downloading STM32:STM32Tools@1.4.0
downloading STM32:CMSIS@5.5.1
downloading STM32:stm32@1.9.0
strangely no 'finished' but on the board manager menu it shows 'INSTALLED'
next select a board - select other board and port
lets pick my favorite Generic STM32F4 series
next goto tools board part number > blackpill f401ccu
ok done click the [tick] compile
Sketch uses 10776 bytes (4%) of program storage space. Maximum is 262144 bytes.
Global variables use 880 bytes (1%) of dynamic memory, leaving 64656 bytes for local variables. Maximum is 65536 bytes.
update config
tools > usb support > CDC (generic 'Serial')
click [tick] (compile)
Sketch uses 22116 bytes (8%) of program storage space. Maximum is 262144 bytes.
Global variables use 3624 bytes (5%) of dynamic memory, leaving 61912 bytes for local variables. Maximum is 65536 bytes.
so smooth!
last part stm32cubeprogrammer cost 100 megs compressed, i'd make do with my old favourite dfu-util for now
cd /tmp/arduino-sketch-D57625....
dfu-util -a 0 -s 0x08000000 -RD sketch.ino.bin
yay it blinks :)
Re: Arduino IDE 2.0
testing the more 'advanced' features, reference jumps don't seem working
right click digitalWrite(..) > goto definition
no definition found
fredbox
Re: Arduino IDE 2.0
Post by fredbox »
I installed on my Mint 20 system and see the same thing.
Definitions work for standard Arduino boards. For STM32, most everything is underlined but it still compiles ok.
There is already an open issue on the 2.0 Github.
As far as size, 1.8.13 is 581 mb, 2.0_beta4 is 808mb, so its not that much bigger than the previous version.
Re: Arduino IDE 2.0
mrburnette wrote: Thu Mar 25, 2021 1:41 pm I installed the Arduino IDE 2.0 Beta on my Win10Pro HP i7 (4core-8tread) notebook from ZIP. No issue until...
i'd suggest make it known on arduino.cc forums etc, it may help for them to investigate it. at least to confirm that it is just a benign piece of code.
this is given the recent solarwinds and ms exchange hack. it seemed some threat actors used the less noted platforms for their attacks.
Re: Arduino IDE 2.0
while playing with Arduino IDE 2.0 beta 4, i found in
/tmp/arduino-core-cache/core_bdc163ff97f8266.....a
> ar -t core_bdc163ff97f82660450f5a0d8e958d0b.a
startup_stm32yyxx.S.o
dtostrf.c.o
board.c.o
hooks.c.o
itoa.c.o
pins_arduino.c.o
device.c.o
ok so it builds a .a lib file after all - on linux - i'm not sure if it does the same on windows
and the other thing is using /tmp directories for pre-compiled libs really isn't a good idea.
i'm not sure where can the build folder be set so that the intermediate built object files, .a libraries etc can be left in the project folder in the build subfolder.
it doesn't make sense to rebuild each time the /tmp folder is cleared
Re: Arduino IDE 2.0
next test i test this sketch
viewtopic.php?p=6334#p6334
use a hardware timer, this kind of shows that the dependencies are correctly linked
#include <Arduino.h>
#include <HardwareTimer.h>
HardwareTimer *pTimer2 = new HardwareTimer(TIM2);
int16_t count;
int8_t dir;
void ledon() {
	int8_t channel = 1;
	if(count > 100) {
		dir = -1;
		count = 100;
	} else if (count < 1) {
		dir = 1;
		count = 1;
	pTimer2->setCaptureCompare(channel, count, PERCENT_COMPARE_FORMAT); // count here is the duty cycle 1-100
void ledoff() {
	count += dir;
	count = 0;
	dir = 1;
	pinMode(LED_BUILTIN, OUTPUT);
	uint8_t channel = 1;
	pTimer2->pause(); // pause the timer
	pTimer2->setMode(channel, TIMER_OUTPUT_COMPARE_PWM1); //output compare mode, got this from reading the api notes
	pTimer2->setOverflow(50, HERTZ_FORMAT); // call back at 50 hz
	pTimer2->attachInterrupt(ledon); // attach ledon() every cycle turn on the led
	pTimer2->attachInterrupt(channel, ledoff); // attach ledoff() end of duty cycle turn off the led
	pTimer2->refresh(); //reset the counters
	pTimer2->resume();
then download/flash to board, now I have a 'breathing' led display :)
on a side note i found that on linux the /tmp folders are identified by
/tmp/arduino-sketch-33482DDA232A7A142....
that in a way identifies each sketch by a uuid, this is pretty much same as using 'project folders' for the build
they might as well use project folders rather than tmp folders, at least the builds are left in a static location rather than being cleared say when the os decides to do some housekeeping (e.g. deleting /tmp files).
i'm not sure if it is the same on windows.
Re: Arduino IDE 2.0
i seemed to have found a root cause for the undeclared identifier issue
https://github.com/arduino/arduino-ide/ ... -809254807
https://forum.arduino.cc/index.php?topic=734627.0
https://github.com/arduino/arduino-cli/issues/1245
the language server toolchain architecture apparently seem to be
arduino-ide2 -> vscode-arduino-tools (module) -> arduino-language-server -> clangd
in inols-err.log
--> initialize(file:///home/user/Arduino/sketch_mar28b)
running: /opt1/arduino/arduino-ide_2.0.0-beta.4-snapshot.51195eb_Linux_64bit/resources/app/node_modules/arduino-ide-extension/build/arduino-cli compile --fqbn STM32:stm32:GenF4 --only-compilation-database --clean --source-override /tmp/071191930 --build-path /tmp/arduino-language-server071191930 --format json /home/user/Arduino/sketch_mar28b
if arduino-cli compile is run with --only-compilation-database ends in error, compile_commands.json is not generated
however if arduino-cli compile is run without --only-compilation-database the build completes, though with a success : false status and a detailed compile_commands.json file is successfully generated
  "directory": "/tmp/arduino-language-server071191930",
  "arguments": [
   "/opt1/arduino/dotarduino15/packages/STM32/tools/xpack-arm-none-eabi-gcc/9.2.1-1.1/bin/arm-none-eabi-g++",
   "-mcpu=cortex-m4",
   "-mfpu=fpv4-sp-d16",
   "-mfloat-abi=hard",
   "-mthumb",
   "@./sketch/build_opt.h",
   "-c",
   "-Os",
   "-w",
   "-std=gnu++14",
   "-ffunction-sections",
   "-fdata-sections",
   "-nostdlib",
   "-fno-threadsafe-statics",
   "--param",
   "max-inline-insns-single=500",
   "-fno-rtti",
   "-fno-exceptions",
   "-fno-use-cxa-atexit",
   "-MMD",
   "-I/home/user/Arduino/sketch_mar28b",
   "-I/opt1/arduino/dotarduino15/packages/STM32/hardware/stm32/1.9.0/cores/arduino/avr",
   "-I/opt1/arduino/dotarduino15/packages/STM32/hardware/stm32/1.9.0/cores/arduino/stm32",
   "-I/opt1/arduino/dotarduino15/packages/STM32/hardware/stm32/1.9.0/cores/arduino/stm32/LL",
   "-I/opt1/arduino/dotarduino15/packages/STM32/hardware/stm32/1.9.0/cores/arduino/stm32/usb",
   "-I/opt1/arduino/dotarduino15/packages/STM32/hardware/stm32/1.9.0/cores/arduino/stm32/OpenAMP",
it otherwise generates a 'blank' compile_commands.json file and all definition and symbol lookups fail
compile_commands.json is used by clangd to figure out where are all the files
https://clangd.llvm.org/installation.html
parse them and make the symbol and reference lookup index
koen
Re: Arduino IDE 2.0
Post by koen »
fyi: an early build of arduino-ide 2 on raspberry pi os 64bit, and an stm32 board support package.
Home directory on usb external disk recommended; home directory con internal sdcard can be painfully slow.
I'm using this for a small blue pill project. No 32bit version. sorry.
https://github.com/koendv/arduino-ide-raspberrypi
Return to “IDE's”
